X2509WV-04S-N0SN
X2509WV-04S-N0SN
    XKB(中国星坤)
    插件,P=2.5mm
    1X4P 间距:2.5MM 直插
X2509WV-04S-N0SN 数据手册
Test Report Client Name: No.: SZXPC23001911609 Date: Aug 23, 2023 Page 1 of 5 GUANGDONG XKB HOLDING CO.LTD Client Address: BUILDING 1, NO.36 XINZHOU MIDDLE STREET, LIN VILLAGE, TANGXIA TOWN, DONGGUAN CITY, GUANGDONG PROVINCE Sample Name: Gold plating The above sample(s) and information were provided by the client. ----------------------------------------------------------------------------------------------------------------------------- ---------------SGS Job No.: SZPC2308005157 Sample Receiving Date: Aug 15, 2023 Testing Period: Aug 15, 2023 ~ Aug 23, 2023 Test Requested: Select test(s) as requested by the client. Test Method(s): Please refer to next page(s). Test Result(s): Please refer to next page(s). Test Requirement EU RoHS Directive (EU) 2015/863 amending Annex II to Directive 2011/65/EU- Lead, Mercury, Cadmium and Hexavalent chromium Signed for and on behalf of SGS-CSTC Standards Technical Services Co., Ltd. Shenzhen Branch Ford Shi Approved Signatory Conclusion Pass Test Report No.: SZXPC23001911609 Date: Aug 23, 2023 Page 2 of 5 Test Result(s): Test Part Description: SN ID Sample No. SGS Sample ID SN1 005 SZX23-0019116-0001.C005 Remarks: (1) 1 mg/kg = 1 ppm = 0.0001% (2) MDL = Method Detection Limit (3) ND = Not Detected (< MDL) (4) “-“ = Not Regulated Description Silvery metal EU RoHS Directive (EU) 2015/863 amending Annex II to Directive 2011/65/EU- Lead, Mercury, Cadmium and Hexavalent chromium Test Method: With reference to IEC 62321-4:2013+AMD1:2017, IEC 62321-5:2013 and IEC 62321-71:2015, analysis was performed by ICP-OES and UV-Vis . Test Item(s) Cadmium(Cd) Lead(Pb) Mercury(Hg) Hexavalent Chromium (Cr(VI)) ▼ Limit 100 1000 1000 - Unit(s) mg/kg mg/kg mg/kg µg/cm² MDL 2 2 2 0.10 005 ND 42 ND ND Notes: (1) The maximum permissible limit is quoted from RoHS Directive (EU) 2015/863. (2) IEC 62321 series is equivalent to EN 62321 series. (3) ▼ = a. The sample is positive for Cr(VI) if the Cr(VI)concentration is greater than 0.13 μg/cm2. The sample coating is considered to contain Cr(VI) b. The sample is negative for Cr(VI) if Cr(VI) is ND (concentration less than 0.10 μg/cm2). The coating is considered a non-Cr(VI) based coating c. The result between 0.10 μg/cm2 and 0.13 μg/cm2 is considered to be inconclusive-unavoidable coating variations may influence the determination. Information on storage conditions and production date of the tested sample is unavailable and thus Cr(VI) results represent status of the sample at the time of testing. Unless otherwise stated, the decision rule for conformity reporting is based on Binary Statement for Simple Acceptance Rule (w=0) stated in ILAC-G8:09/2019. Test Report No.: Date: SZXPC23001911609 Aug 23, 2023 ATTACHMENTS Elements Testing Flow Chart These samples were dissolved totally by pre-conditioning method according to below flow chart. Sample Preparation Sample Measurement Acid digestion with microwave/ hotplate Filtration Solution Residue 1) Alkali Fusion / Dry Ashing 2) Acid to dissolve ICP-OES/AAS DATA Page 3 of 5 Test Report No.: SZXPC23001911609 Date: Aug 23, 2023 ATTACHMENTS Hexavalent Chromium (Cr(VI)) Testing Flow Chart Sample Preparation Sample Measurement Nonmetallic material ABS/PC/PVC Metallic material Others Boiling water extraction Digesting at 150~160°C Dissolving by ultrasonication Digesting at 60°C by ultrasonication Separating to get aqueous phase Adding 1,5diphenylcarba zide for color development UV-Vis pH adjustment DATA Adding 1,5diphenylcarbazide for color development UV-Vis DATA Page 4 of 5 Test Report No.: SZXPC23001911609 Date: Aug 23, 2023 Sample Photo: SZX23-0019116-0001.C005 SGS authenticate the photo on original report only *** End of Report *** Page 5 of 5
X2509WV-04S-N0SN 价格&库存
很抱歉,暂时无法提供与“X2509WV-04S-N0SN”相匹配的价格&库存,您可以联系我们找货
X2509WV-04S-N0SN
  • 5+0.96312
  • 50+0.75627
  • 150+0.66762
  • 1000+0.55701
  • 2000+0.50777
  • 5000+0.47812
库存:934
