8
6
7
4
5
3
2
1
REVISIONS
THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE
PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE
WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED.
DESCRIPTION
REV
D
DATE
APPROVED
A
INITIAL RELEASE
08/25/2010 BPUCHASKI
B
ECN 9475: REVISED GAS TUBE BREAKDOWN FROM 90V TO 180 V
10/25/2018 DFRISIELLO
2.42
61.4
D
STAR LOCK WASHER
.87
22.1
SPLIT LOCK WASHER
GAS TUBE
HEX NUT
.512
13.00
C
5/8-24 UNEF
C
5/8-24 UNEF
CRIMP RING TERMINAL FOR
GROUNDING WIRE
N-FEMALE
N-FEMALE BULKHEAD
ELECTRICAL SPECIFICATIONS
B
FREQUENCY RANGE
VSWR
INSERTION LOSS
IMPEDANCE
GAS TUBE BREAKDOWN VOLTAGE
0 - 6 GHz
1 : 1.2 MAX (0 - 6 GHz)
0.6 dB MAX ( 0 - 6 GHz)
50 OHM
180 V ± 20%
B
B
MECHANICAL SPECIFICATIONS
CONNECTORS
CONNECTOR BODY MATERIAL
BODY MATERIAL
PIN MATERIAL
O"-RING
DIMENSIONS (MAX)
WEIGHT
N-FEMALE TO N-FEMALE BULKHEAD
NICKEL PLATED BRASS
NICKEL PLATED BRASS
GOLD PLATED BRASS
RUBBER
2.6 X 0.9 X 1.2 IN (68 X 23 X 31mm)
0.25 LBS (0.11 kg)
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES [mm]
OVERALL CABLE LENGTH TOLERANCE:
≤12 [305] = +1 [25] / -0
>12 [305] ≤60 [1524] = +2 [51] / -0
>60 [1524] ≤120 [3048] = +4 [102] / -0
>120 [3048] ≤300 [7620] = +6 [152] / -0
>300 [7620] = +5% / -0%
A
NOTES:
1. LIGHTNING PROTECTOR SHALL BE INDIVIDUALLY PACKAGED IN
ACCORDANCE WITH L-COM PACKAGING SPEC. PS-0031.
ALL OTHER DIMENSIONAL TOLERANCES:
.X = ± .2 [5.08]
.XX = ± .02 [.51]
.XXX = ±.005 [.13]
REGULATORY COMPLIANCE:
CE2011/65/EU(RoHS DIRECTIVE)
PROJECTION
APPROVALS
50 HIGH STREET
NORTH ANDOVER, MA
01845
DATE
DRAWN BY
08/23/2010
D.PARHAM
CHECKED BY
08/24/2010
K.BURGNER
LIGHTNING PROTECTOR
08/25/2010
K.BURGNER
CONFIGURATION DETAILS OF
UNDIMENSIONED FEATURES
MAY VARY
COLOR VARIATIONS
MAY OCCUR
PRODUCT DESCRIPTION
LP,N-FEMALE TO N-FEMALE 0-6GHz
SIZE
A
FSCM NO.
43321
SCALE: NONE
8
7
6
5
4
3
A
CATEGORY
APPROVED BY
DWG. NO.
CAD FILE:
2
AL6-NFNFBW-9
AL6-NFNFBW-9.SLDDRW
REV.
B
SHEET 1 OF 1
1
很抱歉,暂时无法提供与“AL6-NFNFBW-9”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+896.812001+116.08297
- 10+762.3360710+98.67646
- 25+714.6462025+92.50351
- 50+680.5786550+88.09382
- 100+648.14482100+83.89560
