ECJ504-UA
ECJ504-UA
    L-COM(诺通)
    USB 2.0 面板安装耦合器, A 型母头 / 10IN( 25.4 CM) 引线, 乳白色
ECJ504-UA 数据手册
8 6 7 4 5 2X, D 1.142 3 2 1 REVISIONS THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED. DATE DESCRIPTION REV APPROVED F ECN 5200: CN RELEASE 12/9/10 G ECN 6692: REVISED MODEL TO SNAP-ON COVERS 2/20/13 D.FRISIELLO H ECN 8409: UPDATE TEMPERATURE RATING TO -10~70°C 7/18/16 S.LI D. CASTRO .125 3.18 1.48 29.00 D 10.00±.75 254.0±19.1 37.7 BLACK GREEN WHITE .75 "J1" 19.1 RED GRAY PIN 1 .43 C SHIELDED DRAIN WIRE 10.8 1.40 .10 35.6 C 2.5 USB TYPE "A" JACK 2X #4-40 UNC-2B NOTES: B MATERIAL: COUPLER HOUSING: ABS, UL94V-0. CONNECTOR INSULATOR: WHITE, PBT WITH GLASS FIBER. CONNECTOR CONTACTS: PHOSPHOR BRONZE. CONNECTOR SHELL: BRASS. PCB: EPOXY GLASS FP-4, 94V-0 FLAMMABILITY RATING. FINISH: COUPLER HOUSING: COLOR, IVORY. CONNECTOR CONTACTS: GOLD, 30µ INCHES. CONNECTOR SHELLS: NICKEL. WIRING MAP 1 POWER (RED, 20AWG) 2 - DATA (WHITE, 24AWG) 3 + DATA (GREEN, 24AWG) 4 GND A DRAIN (GRAY, 24AWG) UNLESS OTHERWISE SPECIFIED, OVERALL CABLE LENGTH TOLERANCE: ≤12 [305] = +1 [25] / -0 >12 [305] ≤60 [1524] = +2 [51] / -0 >60 [1524] ≤120 [3048] = +4 [102] / -0 >120 [3048] ≤300 [7620] = +6 [152] / -0 >300 [7620] = +5% / -0% H ALL OTHER DIMENSIONAL TOLERANCES: .X = ± .2 [5.08] .XX = ± .02 [.51] .XXX = ±.005 [.13] PROJECTION REGULATORY COMPLIANCE: CE2011/65/EU(RoHS DIRECTIVE) 7 B .675 17.15 POWER GND (BLACK, 20AWG) DIMENSIONS ARE IN INCHES [mm] MISCELLANEOUS: COUPLER SHALL BE TESTED FOR CONTINUITY. COUPLER SHALL BE INDIVIDUALLY PACKAGED IN ACCORDANCE WITH L-COM PACKAGING SPEC PS-0031. 8 1.142 29.00 RECOMMENDED PANEL CUTOUT ELECTRICAL: CURRENT RATING: 2 AMP MAX. VOLTAGE RATING: 140 VDC. ENVIRONMENTAL: OPERATING TEMPERATURE: -10 C TO +70 C. .905 22.99 "J1" APPROVALS 50 HIGH STREET NORTH ANDOVER, MA 01845 DATE DRAWN BY 5/4/2001 C. MCCORMICK CHECKED BY 5/4/2001 D. PARHAM USB 5/4/2001 R. CARRICK CONFIGURATION DETAILS OF UNDIMENSIONED FEATURES MAY VARY COLOR VARIATIONS MAY OCCUR PRODUCT DESCRIPTION JK PNL MNT USB A, 10" WIRE LDS SIZE A FSCM NO. 43321 SCALE: NONE 6 5 4 3 A CATEGORY APPROVED BY DWG. NO. CAD FILE: 2 ECJ504-UA ECJ504-UA.SLDDRW REV. H SHEET 1 OF 1 1
ECJ504-UA 价格&库存
很抱歉,暂时无法提供与“ECJ504-UA”相匹配的价格&库存,您可以联系我们找货
ECJ504-UA
  • 1+136.180811+17.56768
  • 10+115.7494210+14.93197
  • 25+108.4998225+13.99676
  • 50+103.3189750+13.32841
  • 100+98.38893100+12.69243
  • 250+92.23390250+11.89841
  • 500+87.83605500+11.33108
  • 1000+83.649941000+10.79106
库存:2
