ECJ504B-UB
ECJ504B-UB
    L-COM(诺通)
ECJ504B-UB 数据手册
8 6 7 4 5 3 D .125 DATE APPROVED G ECN 5200: CN RELEASE 12/9/10 H ECN 5796: REMOVE "SHIELDED DRAIN WIRE" FROM TOP VIEW 10/24/11 D.FRISIELLO J ECN 6692: REVISED MODEL TO SNAP-ON COVERS 2/20/13 D.FRISIELLO K ECN 8409: UPDATE TEMPERATURE RATING TO -10~70°C 7/18/16 S.LI 1.48 3.18 29.00 1 DESCRIPTION REV 2X 1.142 2 REVISIONS THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED. D 10.00±.75 254.0±19.1 37.7 D. CASTRO GRAY PIN 1 RED WHITE .75 "J1" GREEN 19.1 BLACK .43 1.40 10.8 35.6 C .10 C 2.5 USB TYPE "B" JACK 2X #4-40 UNC-2B NOTES: B MATERIAL: COUPLER HOUSING: ABS, UL94V-0. CONNECTOR INSULATOR: WHITE, PBT WITH GLASS FIBER. CONNECTOR CONTACTS: PHOSPHOR BRONZE. CONNECTOR SHELL: BRASS. PCB: EPOXY GLASS FP-4, 94V-0 FLAMMABILITY RATING. FINISH: COUPLER HOUSING: COLOR, BLACK. CONNECTOR CONTACTS: GOLD, 30µ INCHES. CONNECTOR SHELLS: NICKEL. A POWER (RED, 20AWG) 2 - DATA (WHITE, 24AWG) 3 + DATA (GREEN, 24AWG) GND UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES [mm] K OVERALL CABLE LENGTH TOLERANCE: ≤12 [305] = +1 [25] / -0 >12 [305] ≤60 [1524] = +2 [51] / -0 >60 [1524] ≤120 [3048] = +4 [102] / -0 >120 [3048] ≤300 [7620] = +6 [152] / -0 >300 [7620] = +5% / -0% ALL OTHER DIMENSIONAL TOLERANCES: .X = ± .2 [5.08] .XX = ± .02 [.51] .XXX = ±.005 [.13] PROJECTION RECOMMENDED PANEL CUT OUT APPROVALS 50 HIGH STREET NORTH ANDOVER, MA 01845 DATE DRAWN BY 5/4/01 C. MCCORMICK CHECKED BY 5/4/01 D. PARHAM USB 5/4/01 R. CARRICK CONFIGURATION DETAILS OF UNDIMENSIONED FEATURES MAY VARY COLOR VARIATIONS MAY OCCUR 5 4 3 A CATEGORY APPROVED BY PRODUCT DESCRIPTION JK PNL MNT USB B, 10" WIRE LDS SIZE A FSCM NO. 43321 SCALE: NONE 6 B .675 17.15 DRAIN (GRAY, 24AWG) REGULATORY COMPLIANCE: CE2011/65/EU(RoHS DIRECTIVE) 7 1.142 29.00 POWER GND (BLACK, 20AWG) MISCELLANEOUS: COUPLER SHALL BE TESTED FOR CONTINUITY. COUPLER SHALL BE INDIVIDUALLY PACKAGED IN ACCORDANCE WITH L-COM PACKAGING SPEC PS-0031. 8 .905 22.99 1 4 ELECTRICAL: CURRENT RATING: 2 AMP MAX. VOLTAGE RATING: 140 VDC. ENVIRONMENTAL: OPERATING TEMPERATURE: -10 C TO +70 C. WIRING MAP "J1" DWG. NO. CAD FILE: 2 ECJ504B-UB ECJ504B-UB.SLDDRW REV. K SHEET 1 OF 1 1
ECJ504B-UB 价格&库存
很抱歉,暂时无法提供与“ECJ504B-UB”相匹配的价格&库存,您可以联系我们找货
ECJ504B-UB
库存:17
ECJ504B-UB
  • 1+125.352981+16.21633
