TDG1026KC6
TDG1026KC6
    L-COM(诺通)
TDG1026KC6 数据手册
8 6 7 4 5 3 2 1 REVISIONS THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED. DESCRIPTION REV F DATE APPROVED ECN 6881: REVISED PANEL OPENING. UPD DIMENSIONS. ADDED COMPLIANCE 6/14/13 D. DESJARDIN G ECN 7409: UPDATED PER NEW SUPPLIER SPEC 5/19/14 D. CASTRO H ECN 11115; REVISE 100u" TO 50u" MIN. FOR NICKEL PLATE, NEW FORMAT 04/28/2021 DGUST D D 1.17 29.8 .57 14.6 C 2X.31 8 .76 19.2 .64 16.2 C POSITION 1 POSITION 1 .580 14.73 NOTES: B B MATERIAL: HOUSING: PC UL94V-0 COLOR: BLACK. CONTACTS: PHOSPHOR BRONZE, 50 μINCHES GOLD PLATE OVER H 50 μINCHES MIN. NICKEL PLATE. .756 19.20 ELECTRICAL: DC CURRENT RATING: 1.5 AMP DIELECTRIC WITHSTANDING VOLTAGE: 1000 VOLTS DC. RECOMMENDED PANEL OPENING MISCELLANEOUS: WIRING: STRAIGHT THROUGH OPERATING TEMPERATURE RANGE: -10 C TO +60 C. APPLICATION: CATEGORY 6. PANEL THICKNESS: .06" [1.6mm] MAX. A UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES [mm] APPROVALS OVERALL CABLE LENGTH TOLERANCE: ≤12 [305] = +1 [25] / -0 B.MAZEJKA CHECKED BY >12 [305] ≤60 [1524] = +2 [51] / -0 >60 [1524] ≤120 [3048] = +4 [102] / -0 D.PARHAM >120 [3048] ≤300 [7620] = +6 [152] / -0 APPROVED BY >300 [7620] = +5% / -0 COMPONENT SHALL BE INDIVIDUALLY PACKAGED IN ACCORDANCE WITH L-COM SPECIFICATION PS-0031. ALL OTHER DIMENSIONAL TOLERANCES: FRACTIONS .X = .2 [5] .XX = .02 [.5] ± 1/32 .XXX = .005 [.13] ANGLES ± 1° ALL DIMENSIONS ARE FOR REFERENCE ONLY. THIRD-ANGLE PROJECTION 50 High Street, West Mill, North Andover, MA 01845 USA. Phone: 1.800.341.5266 1.978.682.6936 DATE DRAWN BY 06/16/2003 07/03/2003 TELECOM/MODULAR 07/03/2003 CONFIGURATION DETAILS OF UNDIMENSIONED FEATURES MAY VARY COLOR VARIATIONS MAY OCCUR PRODUCT DESCRIPTION CAT 6 KEYSTONE FEED-THRU CPLR SIZE A CAGE CODE 43321 SCALE: NONE T-Rev.D 8 7 6 5 4 3 A CATEGORY REV. DWG. NO. TDG1026KC6 CAD FILE: TDG1026KC6.SLDDRW 2 H SHEET 1 OF 1 1
TDG1026KC6 价格&库存
很抱歉,暂时无法提供与“TDG1026KC6”相匹配的价格&库存,您可以联系我们找货
TDG1026KC6
    • 1+119.57168
    • 10+109.66812
    库存:15
    TDG1026KC6
    • 1+154.491951+19.98590
