8
6
7
4
5
3
ECF504-12AAS
INCHES
MM
12.0
[304.8]
ECF504-24AAS
24.0
[609.6]
ECF504-36AAS
36.0
[914.4]
ECF504-72AAS
72.0
[1828.8]
120.0
[3048.0]
ECF504-120AAS
1
APPROVED
DATE
DESCRIPTION
REV
LENGTH
PART
NUMBER
D
2
REVISIONS
THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE
PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE
WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED.
J
ECN 8409: ADD TEMPERATURE RATING -10~70°C
7/15/16
S.LI
K
ECN 8666: REVISED ADAPTER TO USB 2.0 STANDARDS
3/9/17
D.FRISIELLO
L
ECN8674: REVISE STRAIN RELIEF FROM 2 PCS TO 1PC TYP. IN THE PNL MNT END. 03/15/2017 B.ZHANG
LENGTH
.463 MIN
D
HOUSING: ABS, UL94V-0
FINISH: CHROME.
11.75
.75
19.1
2X
.125
3.18
MOLDED STRAIN RELIEF
COLOR: LIGHT GRAY
(PANTONE 400C)
PIN 1
C
1.40
29
35.6
L
DIELECTRIC
"P1"
USB SERIES "A" PLUG
CONTACTS: 30 µINCHES
GOLD PLATING
MOLDED PVC HOOD,
COLOR: LIGHT GRAY
(PANTONE 400C)
B
1.142
"P1"
WIRING DIAGRAM
C
PIN 1
ONE 28AWG STRANDED TINNED COPPER TWISTED PAIR
TWO 20AWG STRANDED TINNED COPPER CONDUCTORS
OVERALL ALUMINIZED POLYESTER SHIELD WITH DRAIN WIRE
PLUS TINNED COPPER BRAIDED SHIELD.
PVC OUTER JACKET, LIGHT GRAY (PANTONE 400C)
"J1"
USB SERIES "A" RECEPTACLE
BULKHEAD ADAPTOR
GOLD PLATING
2X #4-40 UNC-2B
"J1"
.905
23
RED
1
1
WHITE
2
2 - DATA
VCC (CABLE POWER)
GREEN 3
3 + DATA
BLACK 4
4 GND (CABLE GROUND)
.675
17.1
RECOMMENDED
PANEL CUT OUT
DRAIN WIRE
HOUSING
NOTES:
A
1.
2.
3.
4.
5.
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES [mm]
OPERATING TEMPERATURE: -10°C TO +70°C
CABLE ASSEMBLY SHALL HAVE 360° SHIELD TERMINATION.
CABLE ASSEMBLY SHALL MEET USB 2.0 REQUIREMENTS.
CABLE ASSEMBLY SHALL BE TESTED FOR CONTINUITY.
CABLE ASSEMBLY SHALL BE INDIVIDUALLY PACKAGED IN
ACCORDANCE WITH L-COM SPECIFICATION PS-0031.
OVERALL CABLE LENGTH TOLERANCE:
≤12 [305] = +1 [25] / -0
>12 [305] ≤60 [1524] = +2 [51] / -0
>60 [1524] ≤120 [3048] = +4 [102] / -0
>120 [3048] ≤300 [7620] = +6 [152] / -0
>300 [7620] = +5% / -0%
ALL OTHER DIMENSIONAL TOLERANCES:
.X = ± .2 [5.08]
.XX = ± .02 [.51]
.XXX = ±.005 [.13]
PROJECTION
REGULATORY COMPLIANCE:
CE2011/65/EU(RoHS DIRECTIVE)
8
7
APPROVALS
50 HIGH STREET
NORTH ANDOVER, MA
01845
DATE
DRAWN BY
04/02/2003
C.MCCORMICK
CHECKED BY
04/02/2003
D.PARHAM
USB
04/02/2003
R.CARRICK
CONFIGURATION DETAILS OF
UNDIMENSIONED FEATURES
MAY VARY
COLOR VARIATIONS
MAY OCCUR
5
4
3
A
CATEGORY
APPROVED BY
PRODUCT DESCRIPTION
USB A-F PNL MNT/A-M SHLD
SIZE
A
FSCM NO.
43321
SCALE: NONE
6
B
1.142
29
DWG. NO.
CAD FILE:
2
ECF504-AAS
ECF504-AAS.SLDDRW
REV.
L
SHEET 1 OF 1
1
很抱歉,暂时无法提供与“ECF504-24AAS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+163.35145
- 10+149.67808
