AL-ECF504-AB
AL-ECF504-AB
    L-COM(诺通)
    L-COM(诺通)USB浪涌保护器,A 型/B 型面板安装式
AL-ECF504-AB 数据手册
8 6 7 3 2 37.7 .43 10.8 2X, CN RELEASE 02/26/2010 D.GRIFFIN B ECN 7180: REVISED MODEL TO SNAP VERSION, UPDATED ROHS, FORMAT 11/27/2013 D.FRISIELLO C ECN 11790: CORRECT OPERATING TEMPERATURE TO -10 TO +70°C 04/13/2022 D.REBECK D 2.5 3.2 PIN 4 1.14 35.6 29.0 PIN 3 PIN 1 PIN 4 APPROVED A .10 .13 1.40 DATE DESCRIPTION REV 1.48 19.1 C 1 REVISIONS .75 D 4 5 THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED. PIN 2 PIN 1 USB TYPE "B" JACK "J2" USB TYPE "A" JACK "J1" C 2X #4-40 UNC-2B "J1" NOTES: MATERIAL: COUPLER HOUSING: ABS, UL94V-0. CONNECTOR INSULATORS: WHITE PBT WITH GLASS FIBER. PCB: EPOXY GLASS FP-4, 94V-0 FLAMMABILITY RATING. B FINISH: COUPLER HOUSING: CHROME. CONNECTOR CONTACTS: GOLD, 30μ INCHES. CONNECTOR SHELLS: NICKEL. 1 1 2 2 3 3 4 A 1.142 29.0 .900 22.9 S D1 SD05 D2 ESD9L5 ESD9L5 OVERALL CABLE LENGTH TOLERANCE: ≤12 [305] = +1 [25] / -0 >12 [305] ≤60 [1524] = +2 [51] / -0 >60 [1524] ≤120 [3048] = +4 [102] / -0 >120 [3048] ≤300 [7620] = +6 [152] / -0 >300 [7620] = +5% / -0 C .675 17.1 D3 UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES [mm] MISCELLANEOUS: COUPLER SHALL BE TESTED FOR CONTINUITY. COUPLER SHALL BE INDIVIDUALLY PACKAGED IN ACCORDANCE WITH L-COM PACKAGING SPEC PS-0031. ALL OTHER DIMENSIONAL TOLERANCES: FRACTIONS .X = .2 [5] ± 1/32 .XX = .02 [.5] ANGLES ± 1° .XXX = .005 [.13] THIRD-ANGLE PROJECTION RECOMMENDED PANEL CUTOUT APPROVALS 50 High Street, West Mill, North Andover, MA 01845 USA. Phone: 1.800.341.5266 1.978.682.6936 DATE DRAWN BY 07/24/2009 D. CASTRO CHECKED BY 07/24/2009 D. PARHAM APPROVED BY CATEGORY LIGHTNING PROTECTORS 07/24/2009 S. SMITH CONFIGURATION DETAILS OF UNDIMENSIONED FEATURES MAY VARY COLOR VARIATIONS MAY OCCUR PRODUCT DESCRIPTION LP, USB A/B W/ECF HOUSING SIZE A CAGE CODE 43321 SCALE: NONE T-Rev.D 8 7 6 B 4 S ELECTRICAL: DATA LINE CLAMPING VOLTAGE: 5.4V. POWER LINE CLAMPING VOLTAGE: 6.5V. ENVIRONMENTAL: OPERATING TEMPERATURE: -10 C TO +70 C. "J2" WIRE MAP 5 4 3 DWG. NO. AL-ECF504-AB SHEET 1 OF 1 CAD FILE: AL-ECF504-AB.SLDDRW 2 REV. C 1 A
AL-ECF504-AB 价格&库存
很抱歉,暂时无法提供与“AL-ECF504-AB”相匹配的价格&库存,您可以联系我们找货
AL-ECF504-AB
    • 1+417.42825
    库存:3
