BA039
BA039
    L-COM(诺通)
BA039 数据手册
8 6 7 4 5 D D 3 2 1 REVISIONS THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED. DATE APPROVED A RELEASED TO PRODUCTION 05/03/02 MCCORMICK B ECN 3112: UPDATE DWG FORMAT 12/14/07 D.GRIFFIN C ECN 7450: ADDED MATERIAL CHART, REVISED ALL NOTES, FORMAT, ROHS 5/21/14 D.FRISIELLO D ECN 7469: CHANGE WASHER MATERIAL FROM BRASS TO STEEL 6/4/14 D.FRISIELLO DESCRIPTION REV DESCRIPTION MATERIAL FINISH BODY BRASS NICKEL PLATE INSULATOR ACTEAL WHITE CENTER PIN BRASS GOLD PLATE WASHER STEEL NICKEL PLATE NUT BRASS NICKEL PLATE D 1.28 32.6 .62 15.7 HEX NUT INTERNAL TOOTH LOCK WASHER .84 21.4 C C 2X BNC FEMALE CONNECTOR FLAT AREA .500 12.70 1/2-28 THREAD B B NOTES: .470 11.94 ELECTRICAL: IMPEDANCE: 75 OHM RECOMMENDED PANEL OPENING MISCELLANEOUS: UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES [mm] ALL DIMENSIONS ARE FOR REFERENCE ONLY. A OVERALL CABLE LENGTH TOLERANCE: ≤12 [305] = +1 [25] / -0 >12 [305] ≤60 [1524] = +2 [51] / -0 >60 [1524] ≤120 [3048] = +4 [102] / -0 >120 [3048] ≤300 [7620] = +6 [152] / -0 >300 [7620] = +5% / -0% ACETAL MOUNTING FLANGE AND THREADED BARREL PROVIDE INSULATION FROM PANEL. ALL OTHER DIMENSIONAL TOLERANCES: .X = ± .2 [5.08] .XX = ± .02 [.51] .XXX = ±.005 [.13] COMPONENT SHALL BE INDIVIDUALLY PACKAGED IN ACCORDANCE WITH L-COM SPECIFICATION PS-0031. PROJECTION REGULATORY COMPLIANCE: CE2011/65/EU(RoHS DIRECTIVE) 8 7 APPROVALS 05/02/02 MCCORMICK CHECKED BY 05/02/02 D.PARHAM 5 CONFIGURATION DETAILS OF UNDIMENSIONED FEATURES MAY VARY COLOR VARIATIONS MAY OCCUR 4 AUDIO/VIDEO 05/02/02 R.CARRICK 3 A CATEGORY APPROVED BY 1AB05-106 6 45 BEECHWOOD DRIVE NORTH ANDOVER, MA 01845 DATE DRAWN BY PRODUCT DESCRIPTION BNC INSULATED BULKHEAD ADAPTOR SIZE A FSCM NO. 43321 SCALE: NONE DWG. NO. CAD FILE: 2 REV. D BA039 BA039.SLDDRW SHEET 1 OF 1 1
BA039 价格&库存
很抱歉,暂时无法提供与“BA039”相匹配的价格&库存,您可以联系我们找货
BA039
    • 1+122.11266
    • 10+118.46781
    库存:14
