ECF504-UABS
ECF504-UABS
    L-COM(诺通)
ECF504-UABS 数据手册
8 6 7 C 2X 37.7 10.8 .125 .10 3.18 1.40 1.142 35.6 29.00 USB TYPE "A" JACK "J1" 2 1 DATE DESCRIPTION REV 1.48 .43 19.1 PIN 4 3 REVISIONS .75 D 4 5 THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED. APPROVED F ECN 4740: CN RELEASE 5/13/10 G ECN 6458: USE NEW LOGO 10/12/12 D.FRISIELLO H ECN 6692: ADDED BOTTOM VIEW FOR CLARITY 2/20/13 D.FRISIELLO J ECN 8409: UPDATE TEMPERATURE RATING TO -10~70°C 7/15/16 S.LI D. CASTRO D 2.5 PIN 4 PIN 3 PIN 1 PIN 2 PIN 1 USB TYPE "B" JACK "J2" C 2X #4-40 UNC-2B NOTES: B MATERIAL: COUPLER HOUSING: ABS, UL94V-0. CONNECTOR INSULATORS: WHITE, PBT WITH GLASS FIBER. TYPE "A" CONNECTOR CONTACTS: PHOSPHOR BRONZE. TYPE "A" CONNECTOR SHELL: BRASS. TYPE "B" CONNECTOR CONTACTS: PHOSPHOR BRONZE. TYPE "B" CONNECTOR SHELL FRONT: BRASS. TYPE "B" CONNECTOR SHELL BACK: STEEL. PCB: EPOXY GLASS FP-4, 94V-0 FLAMMABILITY RATING. FINISH: COUPLER HOUSING: CHROME. CONNECTOR CONTACTS: GOLD, 30µ INCHES. CONNECTOR SHELLS: NICKEL. WIRING MAP "J1" "J2" 1 1 POWER 2 2 3 3 + DATA .905 23.0 - DATA 1.142 29.00 4 GROUND 4 CONNECTOR SHELL CONNECTOR SHELL .675 17.1 HOUSING ELECTRICAL: CURRENT RATING: 2 AMP MAX. VOLTAGE RATING: 140 VDC. ENVIRONMENTAL: OPERATING TEMPERATURE: -10 C TO +70 C. A RECOMMENDED PANEL CUTOUT J OVERALL CABLE LENGTH TOLERANCE: ≤12 [305] = +1 [25] / -0 >12 [305] ≤60 [1524] = +2 [51] / -0 >60 [1524] ≤120 [3048] = +4 [102] / -0 >120 [3048] ≤300 [7620] = +6 [152] / -0 >300 [7620] = +5% / -0% ALL OTHER DIMENSIONAL TOLERANCES: .X = ± .2 [5.08] .XX = ± .02 [.51] .XXX = ±.005 [.13] PROJECTION REGULATORY COMPLIANCE: CE2011/65/EU(RoHS DIRECTIVE) 7 APPROVALS UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES [mm] MISCELLANEOUS: COUPLER SHALL BE TESTED FOR CONTINUITY. COUPLER SHALL BE INDIVIDUALLY PACKAGED IN ACCORDANCE WITH L-COM PACKAGING SPEC PS-0031. 8 B 50 HIGH STREET NORTH ANDOVER, MA 01845 DATE DRAWN BY 06/29/2001 C. MCCORMICK CHECKED BY 06/29/2001 R. CARRICK USB 06/29/2001 ZW CONFIGURATION DETAILS OF UNDIMENSIONED FEATURES MAY VARY COLOR VARIATIONS MAY OCCUR PRODUCT DESCRIPTION USB A-B PANEL ADPT SHIELDED SIZE A FSCM NO. 43321 SCALE: NONE 6 5 4 3 A CATEGORY APPROVED BY DWG. NO. CAD FILE: 2 ECF504-UABS ECF504-UABS.SLDDRW REV. J SHEET 1 OF 1 1
ECF504-UABS 价格&库存
很抱歉,暂时无法提供与“ECF504-UABS”相匹配的价格&库存,您可以联系我们找货
ECF504-UABS
    • 1+173.51536
    库存:64
    ECF504-UABS
      库存:96
