ECF504B-UAB
ECF504B-UAB
    L-COM(诺通)
ECF504B-UAB 数据手册
8 6 7 4 5 3 .43 .75 19.1 2X .125 1.40 1.142 35.6 29.00 PIN 4 USB TYPE "A" JACK "J1" DATE APPROVED E ECN 4740: CN RELEASE 5/13/10 F ECN 6458: USE NEW LOGO 10/12/12 D.FRISIELLO G ECN 6692: ADDED BOTTOM VIEW FOR CLARITY 2/20/13 D.FRISIELLO H ECN 8409: UPDATE TEMPERATURE RATING TO -10~70°C 7/15/16 S.LI D. CASTRO 10.8 D .10 3.18 C 1 DESCRIPTION REV 1.48 37.7 D 2 REVISIONS THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED. 2.5 PIN 4 PIN 3 PIN 1 PIN 2 PIN 1 C USB TYPE "B" JACK "J2" 2X #4-40 UNC-2B NOTES: B MATERIAL: COUPLER HOUSING: ABS, UL94V-0. CONNECTOR INSULATORS: WHITE, PBT WITH GLASS FIBER. TYPE "A" CONNECTOR CONTACTS: PHOSPHOR BRONZE. TYPE "A" CONNECTOR SHELL: BRASS. TYPE "B" CONNECTOR CONTACTS: PHOSPHOR BRONZE. TYPE "B" CONNECTOR SHELL FRONT: BRASS. TYPE "B" CONNECTOR SHELL BACK: STEEL. PCB: EPOXY GLASS FP-4, 94V-0 FLAMMABILITY RATING. FINISH: COUPLER HOUSING: COLOR, BLACK. CONNECTOR CONTACTS: GOLD, 30µ INCHES. CONNECTOR SHELLS: NICKEL. WIRING MAP "J1" .905 22.99 "J2" 1 1 POWER 2 2 3 3 + DATA 4 4 GROUND CONNECTOR SHELL 1.142 29.00 - DATA .675 17.15 CONNECTOR SHELL ELECTRICAL: CURRENT RATING: 2 AMP MAX. VOLTAGE RATING: 140 VDC. A ENVIRONMENTAL: OPERATING TEMPERATURE: -10 C TO +70 C. RECOMMENDED PANEL CUTOUT UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES [mm] H OVERALL CABLE LENGTH TOLERANCE: ≤12 [305] = +1 [25] / -0 >12 [305] ≤60 [1524] = +2 [51] / -0 >60 [1524] ≤120 [3048] = +4 [102] / -0 >120 [3048] ≤300 [7620] = +6 [152] / -0 >300 [7620] = +5% / -0% MISCELLANEOUS: COUPLER SHALL BE TESTED FOR CONTINUITY. COUPLER SHALL BE INDIVIDUALLY PACKAGED IN ACCORDANCE WITH L-COM PACKAGING SPEC PS-0031. ALL OTHER DIMENSIONAL TOLERANCES: .X = ± .2 [5.08] .XX = ± .02 [.51] .XXX = ±.005 [.13] PROJECTION REGULATORY COMPLIANCE: CE2011/65/EU(RoHS DIRECTIVE) 8 7 B APPROVALS 50 HIGH STREET NORTH ANDOVER, MA 01845 DATE DRAWN BY 5/4/2001 C. MCCORMICK CHECKED BY 5/4/2001 D. PARHAM USB 5/4/2001 R. CARRICK CONFIGURATION DETAILS OF UNDIMENSIONED FEATURES MAY VARY COLOR VARIATIONS MAY OCCUR PRODUCT DESCRIPTION USB A-B PANEL ADPT BLACK SIZE A FSCM NO. 43321 SCALE: NONE 6 5 4 3 A CATEGORY APPROVED BY DWG. NO. CAD FILE: 2 ECF504B-UAB ECF504B-UAB.SLDDRW REV. H SHEET 1 OF 1 1
ECF504B-UAB 价格&库存
很抱歉,暂时无法提供与“ECF504B-UAB”相匹配的价格&库存,您可以联系我们找货
ECF504B-UAB
    • 1+128.53799
    库存:19
