ECF504-36AAS
ECF504-36AAS
    L-COM(诺通)
ECF504-36AAS 数据手册
8 6 7 4 5 3 ECF504-12AAS INCHES MM 12.0 [304.8] ECF504-24AAS 24.0 [609.6] ECF504-36AAS 36.0 [914.4] ECF504-72AAS 72.0 [1828.8] 120.0 [3048.0] ECF504-120AAS 1 APPROVED DATE DESCRIPTION REV LENGTH PART NUMBER D 2 REVISIONS THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED. J ECN 8409: ADD TEMPERATURE RATING -10~70°C 7/15/16 S.LI K ECN 8666: REVISED ADAPTER TO USB 2.0 STANDARDS 3/9/17 D.FRISIELLO L ECN8674: REVISE STRAIN RELIEF FROM 2 PCS TO 1PC TYP. IN THE PNL MNT END. 03/15/2017 B.ZHANG LENGTH .463 MIN D HOUSING: ABS, UL94V-0 FINISH: CHROME. 11.75 .75 19.1 2X .125 3.18 MOLDED STRAIN RELIEF COLOR: LIGHT GRAY (PANTONE 400C) PIN 1 C 1.40 29 35.6 L DIELECTRIC "P1" USB SERIES "A" PLUG CONTACTS: 30 µINCHES GOLD PLATING MOLDED PVC HOOD, COLOR: LIGHT GRAY (PANTONE 400C) B 1.142 "P1" WIRING DIAGRAM C PIN 1 ONE 28AWG STRANDED TINNED COPPER TWISTED PAIR TWO 20AWG STRANDED TINNED COPPER CONDUCTORS OVERALL ALUMINIZED POLYESTER SHIELD WITH DRAIN WIRE PLUS TINNED COPPER BRAIDED SHIELD. PVC OUTER JACKET, LIGHT GRAY (PANTONE 400C) "J1" USB SERIES "A" RECEPTACLE BULKHEAD ADAPTOR CONTACTS: 30 µINCHES GOLD PLATING 2X #4-40 UNC-2B "J1" .905 23 RED 1 1 WHITE 2 2 - DATA VCC (CABLE POWER) GREEN 3 3 + DATA BLACK 4 4 GND (CABLE GROUND) .675 17.1 RECOMMENDED PANEL CUT OUT DRAIN WIRE HOUSING NOTES: A 1. 2. 3. 4. 5. UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES [mm] OPERATING TEMPERATURE: -10°C TO +70°C CABLE ASSEMBLY SHALL HAVE 360° SHIELD TERMINATION. CABLE ASSEMBLY SHALL MEET USB 2.0 REQUIREMENTS. CABLE ASSEMBLY SHALL BE TESTED FOR CONTINUITY. CABLE ASSEMBLY SHALL BE INDIVIDUALLY PACKAGED IN ACCORDANCE WITH L-COM SPECIFICATION PS-0031. OVERALL CABLE LENGTH TOLERANCE: ≤12 [305] = +1 [25] / -0 >12 [305] ≤60 [1524] = +2 [51] / -0 >60 [1524] ≤120 [3048] = +4 [102] / -0 >120 [3048] ≤300 [7620] = +6 [152] / -0 >300 [7620] = +5% / -0% ALL OTHER DIMENSIONAL TOLERANCES: .X = ± .2 [5.08] .XX = ± .02 [.51] .XXX = ±.005 [.13] PROJECTION REGULATORY COMPLIANCE: CE2011/65/EU(RoHS DIRECTIVE) 8 7 APPROVALS 50 HIGH STREET NORTH ANDOVER, MA 01845 DATE DRAWN BY 04/02/2003 C.MCCORMICK CHECKED BY 04/02/2003 D.PARHAM USB 04/02/2003 R.CARRICK CONFIGURATION DETAILS OF UNDIMENSIONED FEATURES MAY VARY COLOR VARIATIONS MAY OCCUR 5 4 3 A CATEGORY APPROVED BY PRODUCT DESCRIPTION USB A-F PNL MNT/A-M SHLD SIZE A FSCM NO. 43321 SCALE: NONE 6 B 1.142 29 DWG. NO. CAD FILE: 2 ECF504-AAS ECF504-AAS.SLDDRW REV. L SHEET 1 OF 1 1
ECF504-36AAS 价格&库存
很抱歉,暂时无法提供与“ECF504-36AAS”相匹配的价格&库存,您可以联系我们找货
ECF504-36AAS
    • 1+151.83375
    • 10+139.10804
    库存:1
    ECF504-36AAS
    • 1+238.168241+30.68423
    • 10+202.4082810+26.07712
    • 25+189.7318325+24.44396
    • 50+180.6789450+23.27764
    • 100+172.06184100+22.16746
    • 250+161.30001250+20.78097
    • 500+153.61233500+19.79053
    库存:27
