UPMAA-2M
UPMAA-2M
    L-COM(诺通)
UPMAA-2M 数据手册
8 6 7 4 5 3 2 1 REVISIONS THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED. DESCRIPTION REV J D APPROVED DATE ECN 7195: REVISE 3D MODEL TO VENDOR, ROHS, FORMAT 12/11/13 LENGTH D.FRISIELLO .55 14 D PIN 1 .463 11.8 MIN J 1.18 30 .71 18 PIN 1 MOLDED HOOD AND STRAIN RELIEF PVC, LIGHT GRAY (PANTONE 400C) "P1" USB SERIES "A" PLUG CONTACTS: 30 µINCHES GOLD PLATING MOLDED HOOD AND STRAIN RELIEF PVC, LIGHT GRAY (PANTONE 400C) 2X, 4-40 UNC-2B THREADED INSERT (EMBEDDED) PEM "STKB-440-4" OR EQUIVALENT C ONE 28AWG STRANDED TINNED COPPER TWISTED PAIR TWO 20AWG STRANDED TINNED COPPER CONDUCTORS OVERALL ALUMINIZED POLYESTER SHIELD WITH DRAIN WIRE PLUS TINNED COPPER BRAIDED SHIELD. PVC OUTER JACKET, LIGHT GRAY (PANTONE 400C) C "J1" USB SERIES "A" RECEPTACLE PANEL MOUNT CONTACTS: 30 µINCHES GOLD PLATING .39 10 2X, B .63 16 MODEL NUMBER UPMAA-03M UPMAA-05M UPMAA-075M UPMAA-1M UPMAA-2M UPMAA-3M UPMAA-4M UPMAA-5M .125 3.2 1.180 30 RECOMMENDED PANEL CUT-OUT A J LENGTH METERS [FEET] 0.3 [.98] 0.5 [1.64] 0.75 [2.46] 1.0 [3.28] 2.0 [6.56] 3.0 [9.84] 4.0 [13.12] 5.0 [16.41] B 1 1 WHITE 2 2 - DATA GREEN 3 3 + DATA BLACK 4 4 GND (CABLE GROUND) OVERALL CABLE LENGTH TOLERANCE: ≤12 [305] = +1 [25] / -0 >12 [305] ≤60 [1524] = +2 [51] / -0 >60 [1524] ≤120 [3048] = +4 [102] / -0 >120 [3048] ≤300 [7620] = +6 [152] / -0 >300 [7620] = +5% / -0% CABLE ASSEMBLY SHALL HAVE 360° SHIELD TERMINATION. CABLE ASSEMBLY SHALL MEET USB 2.0 REQUIREMENTS. CABLE ASSEMBLY SHALL BE TESTED FOR CONTINUITY. MOUNTING HARDWARE INCLUDED: 2X #4-40 X .38 LG. PHILLIPS HD SCREW CABLE ASSEMBLY SHALL BE INDIVIDUALLY PACKAGED IN ACCORDANCE WITH L-COM SPECIFICATION PS-0031. REGULATORY COMPLIANCE: CE2011/65/EU(RoHS DIRECTIVE) 8 7 6 ALL OTHER DIMENSIONAL TOLERANCES: .X = ± .2 [5.08] .XX = ± .02 [.51] .XXX = ±.005 [.13] PROJECTION APPROVALS 45 BEECHWOOD DRIVE NORTH ANDOVER, MA 01845 DATE 4/18/08 D.FRISIELLO CHECKED BY 4/18/08 D.FORTIN USB 4/18/08 S.SMITH CONFIGURATION DETAILS OF UNDIMENSIONED FEATURES MAY VARY 3 A CATEGORY APPROVED BY COLOR VARIATIONS MAY OCCUR 4 J DRAWN BY PRODUCT DESCRIPTION CA USB-A PNL/USB-AM SIZE A FSCM NO. 43321 SCALE: NONE 5 VCC (CABLE POWER) DRAIN WIRE UNLESS OTHERWISE SPECIFIED, 1. 2. 3. 4. 5. "J1" RED DIMENSIONS ARE IN INCHES [mm] NOTES: WIRING DIAGRAM "P1" DWG. NO. CAD FILE: 2 REV. J UPMAA UPMAA.SLDDRW SHEET 1 OF 1 1
UPMAA-2M 价格&库存
很抱歉,暂时无法提供与“UPMAA-2M”相匹配的价格&库存,您可以联系我们找货
UPMAA-2M
    • 1+136.25465
    • 10+124.79943
    库存:16
