8
6
7
4
5
3
2
1
REVISIONS
THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE
PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE
WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED.
DESCRIPTION
REV
J
D
APPROVED
DATE
ECN 7195: REVISE 3D MODEL TO VENDOR, ROHS, FORMAT
12/11/13
LENGTH
D.FRISIELLO
.55 14
D
PIN 1
.463 11.8
MIN
J
1.18 30
.71 18
PIN 1
MOLDED HOOD AND
STRAIN RELIEF
PVC, LIGHT GRAY (PANTONE 400C)
"P1"
USB SERIES "A" PLUG
CONTACTS: 30 µINCHES
GOLD PLATING
MOLDED HOOD AND
STRAIN RELIEF
2X, 4-40 UNC-2B
THREADED INSERT
(EMBEDDED)
PEM "STKB-440-4"
OR EQUIVALENT
C
ONE 28AWG STRANDED TINNED COPPER TWISTED PAIR
TWO 20AWG STRANDED TINNED COPPER CONDUCTORS
OVERALL ALUMINIZED POLYESTER SHIELD WITH DRAIN WIRE PLUS
TINNED COPPER BRAIDED SHIELD.
PVC OUTER JACKET, LIGHT GRAY (PANTONE 400C)
C
"J1"
USB SERIES "A" RECEPTACLE
PANEL MOUNT
GOLD PLATING
.39 10
2X,
B
.63 16
MODEL
NUMBER
UPMAA-03M
UPMAA-05M
UPMAA-075M
UPMAA-1M
UPMAA-2M
UPMAA-3M
UPMAA-4M
UPMAA-5M
.125 3.2
1.180 30
RECOMMENDED
PANEL CUT-OUT
A
J
LENGTH
METERS [FEET]
0.3 [.98]
0.5 [1.64]
0.75 [2.46]
1.0 [3.28]
2.0 [6.56]
3.0 [9.84]
4.0 [13.12]
5.0 [16.41]
B
1
1
WHITE
2
2 - DATA
GREEN 3
3 + DATA
BLACK 4
4 GND (CABLE GROUND)
OVERALL CABLE LENGTH TOLERANCE:
≤12 [305] = +1 [25] / -0
>12 [305] ≤60 [1524] = +2 [51] / -0
>60 [1524] ≤120 [3048] = +4 [102] / -0
>120 [3048] ≤300 [7620] = +6 [152] / -0
>300 [7620] = +5% / -0%
CABLE ASSEMBLY SHALL HAVE 360° SHIELD TERMINATION.
CABLE ASSEMBLY SHALL MEET USB 2.0 REQUIREMENTS.
CABLE ASSEMBLY SHALL BE TESTED FOR CONTINUITY.
MOUNTING HARDWARE INCLUDED: 2X #4-40 X .38 LG. PHILLIPS HD SCREW
CABLE ASSEMBLY SHALL BE INDIVIDUALLY PACKAGED IN
ACCORDANCE WITH L-COM SPECIFICATION PS-0031.
REGULATORY COMPLIANCE:
CE2011/65/EU(RoHS DIRECTIVE)
8
7
6
ALL OTHER DIMENSIONAL TOLERANCES:
.X = ± .2 [5.08]
.XX = ± .02 [.51]
.XXX = ±.005 [.13]
PROJECTION
APPROVALS
45 BEECHWOOD DRIVE
NORTH ANDOVER, MA
01845
DATE
4/18/08
D.FRISIELLO
CHECKED BY
4/18/08
D.FORTIN
USB
4/18/08
S.SMITH
CONFIGURATION DETAILS OF
UNDIMENSIONED FEATURES
MAY VARY
3
A
CATEGORY
APPROVED BY
COLOR VARIATIONS
MAY OCCUR
4
J
DRAWN BY
PRODUCT DESCRIPTION
CA USB-A PNL/USB-AM
SIZE
A
FSCM NO.
43321
SCALE: NONE
5
VCC (CABLE POWER)
DRAIN WIRE
UNLESS OTHERWISE SPECIFIED,
1.
2.
3.
4.
5.
"J1"
RED
DIMENSIONS ARE IN INCHES [mm]
NOTES:
WIRING DIAGRAM
"P1"
DWG. NO.
CAD FILE:
2
REV.
J
UPMAA
UPMAA.SLDDRW
SHEET 1 OF 1
1
很抱歉,暂时无法提供与“UPMAA-1M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+147.61614
- 10+135.29657
