TDG1026KS-C6
TDG1026KS-C6
    L-COM(诺通)
TDG1026KS-C6 数据手册
8 6 7 4 5 3 1 DATE DESCRIPTION REV .580 14.73 D 2 REVISIONS THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED. APPROVED E ECN 4609: ADDED COLOR BLACK TO ABS HOUSING 3/11/10 F ECN 6168: ADDED NOTE 8 FOR PACKAGING 5/14/12 D.FRISIELLO G ECN 6881: REVISED PANEL CUTOUT. UPDATED MODEL/DIMENSIONS 6/14/13 D. DESJARDIN H ECN 7409: UPDATED PER NEW SUPPLIER SPEC 5/19/14 D. CASTRO D.FRISIELLO D H .756 19.20 H RECOMMENDED PANEL OPENING .57 14.6 1.18 30 C WIRING PIN 1 PIN 1 PIN 2 PIN 2 PIN 3 PIN 3 PIN 4 PIN 4 PIN 5 PIN 5 PIN 6 PIN 6 PIN 7 PIN 7 PIN 8 PIN 8 SHIELD SHIELD B C H .79 20.1 .63 16.1 .06 1.5 POSITION 1 POSITION 1 B .32 8.1 NOTES: MATERIAL: HOUSING: ABS, UL94V-0, COLOR: BLACK. CONTACTS: PHOSPHOR BRONZE CONTACT PLATING: GOLD, 50 μ INCHES OVER NICKEL PLATE. SHIELD: BRASS WITH NICKEL PLATE. H ELECTRICAL: DC CURRENT RATING: 1.5 AMP VOLTAGE RATING: 150 VOLTS INSULATION RESISTANCE: 500MΩ MISCELLANEOUS: RATING: CATEGORY 6 OPERATING TEMPERATURE RANGE: -10 C TO +60 C. A UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES [mm] OVERALL CABLE LENGTH TOLERANCE: ≤12 [305] = +1 [25] / -0 >12 [305] ≤60 [1524] = +2 [51] / -0 >60 [1524] ≤120 [3048] = +4 [102] / -0 >120 [3048] ≤300 [7620] = +6 [152] / -0 >300 [7620] = +5% / -0% COMPONENT SHALL BE INDIVIDUALLY PACKAGED IN ACCORDANCE WITH L-COM SPECIFICATION PS-0031. ALL OTHER DIMENSIONAL TOLERANCES: .X = ± .2 [5.08] .XX = ± .02 [.51] .XXX = ±.005 [.13] ALL DIMENSIONS ARE FOR REFERENCE ONLY. H REGULATORY COMPLIANCE: CE2011/65/EU(RoHS DIRECTIVE) PROJECTION APPROVALS 45 BEECHWOOD DRIVE NORTH ANDOVER, MA 01845 DATE DRAWN BY 06/16/2003 B.MAZEJKA CHECKED BY 07/11/2003 D.PARHAM TELECOM/MODULAR 07/11/2003 C.McCORMICK CONFIGURATION DETAILS OF UNDIMENSIONED FEATURES MAY VARY COLOR VARIATIONS MAY OCCUR PRODUCT DESCRIPTION CAT 6 SHLD RJ45 KEYSTONE CPLR SIZE A FSCM NO. 43321 SCALE: NONE 8 7 6 5 4 3 A CATEGORY APPROVED BY DWG. NO. CAD FILE: 2 TDG1026KS-C6 TDG1026KS-C6.SLDDRW REV. H SHEET 1 OF 1 1
TDG1026KS-C6 价格&库存
很抱歉,暂时无法提供与“TDG1026KS-C6”相匹配的价格&库存,您可以联系我们找货
