UPMBB-1M
UPMBB-1M
    L-COM(诺通)
UPMBB-1M 数据手册
8 7 6 4 5 3 2 1 REVISIONS THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED. DESCRIPTION REV D DATE ECN 6479: REVISE DESCRIPTION TO J1 FROM TYPE A TO B 10/19/12 D.FRISIELLO F ECN 7842: REVISED DIM .55 TO .58, FORMAT, ROHS 3/11/15 D.FRISIELLO LENGTH .58 14.8 .463 11.75 MIN D F 1.18 30 PIN 1 MOLDED HOOD AND STRAIN RELIEF, PVC, LIGHT GRAY (PANTONE 400C) "P1" USB SERIES "B" PLUG CONTACTS: 30 µINCHES GOLD PLATING .71 18 MOLDED HOOD AND STRAIN RELIEF, PVC, LIGHT GRAY (PANTONE 400C) PIN 1 2X, 4-40 UNC-2B THREADED INSERT (EMBEDDED) PEM "STKB-440-4" OR EQUIVALENT C ONE 28AWG STRANDED TINNED COPPER TWISTED PAIR TWO 20AWG STRANDED TINNED COPPER CONDUCTORS OVERALL ALUMINIZED POLYESTER SHIELD WITH DRAIN WIRE PLUS TINNED COPPER BRAIDED SHIELD. PVC OUTER JACKET, LIGHT GRAY (PANTONE 400C) .60 15 2X, "P1" .63 16 1.180 30 WIRING DIAGRAM RED 1 1 WHITE 2 2 - DATA GREEN 3 3 + DATA BLACK 4 4 GND (CABLE GROUND) VCC (CABLE POWER) DRAIN WIRE UNLESS OTHERWISE SPECIFIED, NOTES: 1. 2. 3. 4. 5. MODEL NUMBER UPMBB-03M UPMBB-05M UPMBB-075M UPMBB-1M UPMBB-2M UPMBB-3M UPMBB-4M UPMBB-5M "J1" RECOMMENDED PANEL CUTOUT F CABLE ASSEMBLY SHALL HAVE 360° SHIELD TERMINATION. CABLE ASSEMBLY SHALL MEET USB 2.0 REQUIREMENTS. CABLE ASSEMBLY SHALL BE TESTED FOR CONTINUITY. MOUNTING HARDWARE INCLUDED: 2X #4-40 X .38 LG. PHILLIPS HD SCREW CABLE ASSEMBLY SHALL BE INDIVIDUALLY PACKAGED IN ACCORDANCE WITH L-COM SPECIFICATION PS-0031. DIMENSIONS ARE IN INCHES [mm] OVERALL CABLE LENGTH TOLERANCE: ≤12 [305] = +1 [25] / -0 >12 [305] ≤60 [1524] = +2 [51] / -0 >60 [1524] ≤120 [3048] = +4 [102] / -0 >120 [3048] ≤300 [7620] = +6 [152] / -0 >300 [7620] = +5% / -0% ALL OTHER DIMENSIONAL TOLERANCES: .X = ± .2 [5.08] .XX = ± .02 [.51] .XXX = ±.005 [.13] REGULATORY COMPLIANCE: CE2011/65/EU(RoHS DIRECTIVE) PROJECTION APPROVALS 01/04/2010 CHECKED BY 01/12/2010 D. CASTRO COLOR VARIATIONS MAY OCCUR PRODUCT DESCRIPTION CA USB-B PNL/USB-BM SIZE A FSCM NO. 43321 SCALE: NONE 8 7 6 5 4 3 A USB 01/13/2010 CONFIGURATION DETAILS OF UNDIMENSIONED FEATURES MAY VARY B CATEGORY APPROVED BY S. SMITH LENGTH METERS [FEET] 0.3 [.98] 0.5 [1.64] 0.75 [2.46] 1.0 [3.28] 2.0 [6.56] 3.0 [9.84] 4.0 [13.12] 5.0 [16.41] 45 BEECHWOOD DRIVE NORTH ANDOVER, MA 01845 DATE DRAWN BY D. PARHAM C "J1" USB SERIES "B" RECEPTACLE PANEL MOUNT CONTACTS: 30 µINCHES GOLD PLATING .125 3.2 B A APPROVED E DWG. NO. CAD FILE: 2 REV. F UPMBB UPMBB.SLDDRW SHEET 1 OF 1 1
UPMBB-1M 价格&库存
很抱歉,暂时无法提供与“UPMBB-1M”相匹配的价格&库存,您可以联系我们找货
UPMBB-1M
  • 1+349.986511+45.09025
UPMBB-1M
    • 1+327.34856
    • 10+300.16844
    库存:3
