WPRJ-FTCAT5E
WPRJ-FTCAT5E
    L-COM(诺通)
WPRJ-FTCAT5E 数据手册
8 6 7 4 5 3 1 A DATE DESCRIPTION REV .764±.004 19.4±0.1 D 2 REVISIONS THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED. APPROVED 3/30/10 INITIAL RELEASE D.GRIFFIN 1.45 36.8 D .748 19.0 .819±.004 20.8±0.1 RECOMMENDED PANEL CUTOUT C C .526 13.4 PIN 8 PIN 8 PIN 1 PIN 1 B B 13/16-28UN NOTES: 1. MATERIAL: NUT: NYLON, GLASS FILLED BLACK GASKET: EPDM, BLACK HOUSING: NYLON, GLASS FILLED, BLACK. PIN: BRASS, GOLD PLATED. PCB: FR-4. JACK: PBT POLYESTER, UL94V-0. SHIELD: BRASS, NICKEL PLATED. A UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES [mm] 2. MISCELLANEOUS: INGRESS PROTECTION RATING: IP67. FOR PANEL THICKNESS MAX: .110" [2.8mm]. USE WITH WATERPROOF CAP OR DUST CAP FOR PANEL THICKNESS: .063" [1.6mm]. COMPONENT SHALL BE TESTED FOR CONTINUITY. COMPONENT SHALL BE INDIVIDUALLY PACKAGED IN ACCORDANCE WITH L-COM SPEC. PS-0031 OVERALL CABLE LENGTH TOLERANCE: ≤12 [305] = +1 [25] / -0 >12 [305] ≤60 [1524] = +2 [51] / -0 >60 [1524] ≤120 [3048] = +4 [102] / -0 >120 [3048] ≤300 [7620] = +6 [152] / -0 >300 [7620] = +5% / -0% ALL OTHER DIMENSIONAL TOLERANCES: .X = ± .2 .XX = ± .02 .XXX = ±.005 PROJECTION APPROVALS 45 BEECHWOOD DRIVE NORTH ANDOVER, MA 01845 DATE DRAWN BY 3/25/10 D. CASTRO CHECKED BY 3/29/10 D. PARHAM MODULAR 3/29/10 P. MCNEIL CONFIGURATION DETAILS OF UNDIMENSIONED FEATURES MAY VARY COLOR VARIATIONS MAY OCCUR PRODUCT DESCRIPTION IP67 RJ45 FEED-THRU SHIELDED SIZE A FSCM NO. 43321 SCALE: NONE 8 7 6 5 4 3 A CATEGORY APPROVED BY DWG. NO. CAD FILE: 2 WPRJ-FTCAT5E WPRJ-FTCAT5E.SLDDRW REV. A SHEET 1 OF 1 1
WPRJ-FTCAT5E 价格&库存
很抱歉,暂时无法提供与“WPRJ-FTCAT5E”相匹配的价格&库存,您可以联系我们找货
WPRJ-FTCAT5E
  • 1+517.58853
  • 10+474.54814
库存:2
