TDG1026KC3
TDG1026KC3
    L-COM(诺通)
TDG1026KC3 数据手册
8 6 7 4 5 3 2 1 REVISIONS THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED. DESCRIPTION REV D D DATE APPROVED A INITIAL RELEASE 1/21/03 DFP B ECN1482: PANEL OPENING SIZE WAS .580 X .760 9/5/03 DFP C ECN1629: ADDED COMPONENT SPECIFICATION TABLE 12/31/03 DFP D ECN: 6881: UPDATED FORMAT/PKG, DIMENSIONS, AND PANEL OPENING 6/14/13 D. DESJARDIN D 1.06 26.9 .57 14.5 C 2X .32 8.2 POSITION 1 .74 18.8 .64 16.2 C POSITION 1 .580 14.73 D NOTES: B MATERIALS: HOUSING: GLASS FILLED POLYESTER, UL94V-0, COLOR: BLACK CONTACTS: PHOSPHOR BRONZE CONTACT PLATING: SELECTIVE GOLD OVER NICKEL PLATING B .760 19.30 ELECTRICAL; RATING: CATGORY 3 CURRENT RATING:1.5 AMPS MAX. VOLTAGE RATING:150 VAC RECOMMENDED PANEL OPENING ENVIRONMENTAL; OPERATING TEMPERATURE RANGE: -20˚C TO 85˚C A D MISCELLANEOUS: WIRING: STRAIGHT THROUGH COMPONENT SHALL BE INDIVIDUALLY PACKAGED IN ACCORDANCE WITH L-COM SPECIFICATION PS-0031. MAXIMUM PANEL THICKNESS: .06" UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES [mm] OVERALL CABLE LENGTH TOLERANCE: ≤12 [305] = +1 [25] / -0 >12 [305] ≤60 [1524] = +2 [51] / -0 >60 [1524] ≤120 [3048] = +4 [102] / -0 >120 [3048] ≤300 [7620] = +6 [152] / -0 >300 [7620] = +5% / -0% ALL DIMENSIONS ARE FOR REFERENCE ONLY. ALL OTHER DIMENSIONAL TOLERANCES: .X = ± .2 [5.08] .XX = ± .02 [.51] .XXX = ±.005 [.13] REGULATORY COMPLIANCE: ROHS, CE PROJECTION APPROVALS 45 BEECHWOOD DRIVE NORTH ANDOVER, MA 01845 DATE DRAWN BY 12/30/2002 D. PARHAM CHECKED BY 01/02/2003 C. McCORMICK TELECOM/MODULAR 01/02/2003 R. CARRICK CONFIGURATION DETAILS OF UNDIMENSIONED FEATURES MAY VARY COLOR VARIATIONS MAY OCCUR PRODUCT DESCRIPTION CAT 3 KEYSTONE FEED-THRU CPLR SIZE A FSCM NO. 43321 SCALE: NONE 8 7 6 5 4 3 A CATEGORY APPROVED BY DWG. NO. CAD FILE: 2 TDG1026KC3 TDG1026KC3.SLDDRW REV. D SHEET 1 OF 1 1
TDG1026KC3 价格&库存
很抱歉,暂时无法提供与“TDG1026KC3”相匹配的价格&库存,您可以联系我们找货
