UJ5T568S
UJ5T568S
    L-COM(诺通)
UJ5T568S 数据手册
8 6 7 4 5 3 2 1 REVISIONS THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED. DATE DESCRIPTION REV ECN 6881: UPD DRAWING FORMAT, PKG, AND DIMENSIONS. G 6/12/13 APPROVED D. DESJARDIN D D Category 5e IN-LINE COUPLER 1.28 32.4 .36 9.0 2X .33 8.4 POSITION 1 .64 16.3 .77 19.6 1.35 34.2 C T568A/B INTERCHANGABLE HOUSING LABEL C POSITION 1 G NOTES: B .77 19.6 .67 17.0 MATERIAL: HOUSING: UL94V-0 RATED ABS, BLACK SHIELDING: STEEL CONTACTS: PHOSPHOR BRONZE CONTACT FINISH: GOLD OVER NICKEL SHIELDING FINISH: ELECTROLYTIC TIN PLATING .585 14.86 B .765 19.43 ELECTRICAL: CURRENT RATING: 1.5 AMPS INSULATION RESISTANCE: 500MΩ (MIN) DC RESISTANCE: .1Ω (MAX) RECOMMENDED PANEL OPENING PHYSICAL CHARACTERISTICS: INSERTION LIFE: 750 CYCLES TEMPERATURE RANGE : -40 °F TO 150 °F RATING: CATEGORY 5E WIRING: STRAIGHT THROUGH MAXIMUM PANEL THICKNESS: .07" A UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES [mm] OVERALL CABLE LENGTH TOLERANCE: ≤12 [305] = +1 [25] / -0 >12 [305] ≤60 [1524] = +2 [51] / -0 >60 [1524] ≤120 [3048] = +4 [102] / -0 >120 [3048] ≤300 [7620] = +6 [152] / -0 >300 [7620] = +5% / -0% COMPONENT SHALL BE INDIVIDUALLY PACKAGED IN ACCORDANCE WITH L-COM SPECIFICATION PS-0031. ALL DIMENSIONS ARE FOR REFERENCE ONLY. ALL OTHER DIMENSIONAL TOLERANCES: .X = ± .2 [5.08] .XX = ± .02 [.51] .XXX = ±.005 [.13] REGULATORY COMPLIANCE: ROHS, CE PROJECTION G APPROVALS 45 BEECHWOOD DRIVE NORTH ANDOVER, MA 01845 DATE DRAWN BY 12/7/2001 RON CARRICK CHECKED BY 12/7/2001 C.MCCORMICK TELECOM/MODULAR 12/7/2001 DOUG PARHAM CONFIGURATION DETAILS OF UNDIMENSIONED FEATURES MAY VARY COLOR VARIATIONS MAY OCCUR PRODUCT DESCRIPTION PNL CPLR 8X8 CAT5E KYSTNE SHLD SIZE A FSCM NO. 43321 SCALE: NONE 8 7 6 5 4 3 A CATEGORY APPROVED BY DWG. NO. CAD FILE: 2 REV. G UJ5T568S UJ5T568S.SLDDRW SHEET 1 OF 1 1
UJ5T568S 价格&库存
很抱歉,暂时无法提供与“UJ5T568S”相匹配的价格&库存,您可以联系我们找货
UJ5T568S
