X0502FVS-60AS-LPSN
X0502FVS-60AS-LPSN
    XKB(中国星坤)
    SMD,P=0.5mm
    板对板连接器 SMT 针脚数:60Pin 间距:0.5mm
X0502FVS-60AS-LPSN 数据手册
3.8 [0.150] 0.50 [0.020] 4.6 [0.182] 0.20 [0.008] 2.4 [0.094] 2.45 [0.097] A±0.2 Specifications: 规格: Voltage rating:100V AC/DC 额定电压:100V AC/DC Current rating:0.3A AC/DC 额定电流:0.3A AC/DC Withstanding voltage:150V AC/minute 耐受电压:150V AC/分钟 Temperature range:-40℃-+85℃ 温度范围:-40℃-+85℃ Insulation resistance:100MΩ min 绝缘电阻:100MΩ Min Contact resistance:50mΩ Max 接触电阻:50mΩ Max Socket Height 4.6 [0.182] 1.5 [0.059] B±0.1 C±0.1 X0502 F Mating Height 4.0mm There are no side two ground tags 0.10 Ø0.5 [0.020] D±0.1 V S - XX X X S - LP SN 2 3 4 5 6 7 8 9 D±0.05 1.6 [0.063] B±0.05 0.30 [0.012] 10 12 14 20 22 24 30 1.8 [0.071] 2-Ø0.6 [Ø0.024] 0.35 [0.014] Dimensions(mm) Poles 1.60 [0.063] 1.5 [0.060] 2.0 [0.078] 1.6 [0.063] Mating Height 0.50 [0.020] A B C D 4.70 5.20 5.70 7.20 7.70 8.20 9.70 2.00 2.50 3.00 4.50 5.00 5.50 7.00 3.20 3.70 4.20 5.70 6.20 6.70 8.20 4.10 4.60 5.10 6.60 7.10 7.60 9.10 X0502FVS-XXXS-LPSN Recommended PCB LAYOUT PART N0 X X X MARK DATE DESCRIPTION REVISIONS www.helloxkb.com www.helloxkb.cn www.xk-dg.cn REVISED APPROVED ±5° ±0.2 ±0.3 ±0.4 ±0.5 UNSPECIFIED TOLERANCES Poles LCP Material 32 36 40 50 60 80 PLUG SOCKET 3.0 2.1 2.2 3.4 2.2 2.3 4.0 2.2 2.9 5.0 2.7 4.3 Dimensions(mm) A B C D 10.20 7.50 8.70 9.60 11.20 8.50 9.70 10.60 12.20 9.50 10.70 11.60 14.70 12.00 13.20 14.60 17.20 14.50 15.70 16.60 22.20 19.50 20.70 21.60 / Copper Alloy X0502W Material(Pin) Suitable XKB Wafer DWN SCALE: N/A MODEL TYPE: 0.5mm BTB Connector VIEW: PART NO.: CHKD UNIT: mm/in APPD SIZE: A4 DSND ANGLAR L≤ 4 4
X0502FVS-60AS-LPSN 价格&库存
很抱歉,暂时无法提供与“X0502FVS-60AS-LPSN”相匹配的价格&库存,您可以联系我们找货
X0502FVS-60AS-LPSN
  • 1+7.94880
  • 10+6.63120
  • 30+5.89680
  • 100+5.07600
  • 500+4.71960
  • 1500+4.54680
库存:1188
