DB107S
DB107S
    XCH(旭昌辉)
    DBS
    耐压:1000V 电流:1A
DB107S 数据手册
DB107S SURFACE MOUNT GLASS PASSIVATED BRIDGE RECTIFIER FEATURES: • Glass Passivated Chip Junction • Reverse Voltage - 100 to 1000 V • Forward Current - 1 A • High Surge Current Capability • Designed for Surface Mount Application MECHANICAL DATA • Case: DBS • Terminals: Solderable per MIL-STD-750, Method 2026 • A pprox. Weight: 380 mg 0.02 oz Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Symbols DB107S Units Maximum Repetitive Peak Reverse Voltage V RRM 1000 V Maximum RMS voltage V RMS 700 V Maximum DC Blocking Voltage V DC 1000 V IO 1.0 A I FSM 30 A VF 1.0 V IR 5.0 100 μA Cj 20 pF RθJA RθJC 40 8.0 °C/W T j , T stg -55 ~ +150 °C Parameter Average Rectified Output Current at T c = 118 °C Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load (JEDEC Method) Forward Voltage per element @I F =1.0A Maximum DC Reverse Current at Rated DC Blocking Voltage @ T A =125 °C @ T A =25 °C Typical Junction Capacitance(Note1) Typical Thermal Resistance(Note2) Operating and Storage Temperature Range Note: 1. Measured at 1MHz and applied reverse voltage of 4 V D.C. 2. Mounted on glass epoxy PC board with 4×1.5"×1.5"(3.81×3.81 cm)copper pad. 1/3 DB107S SURFACE MOUNT GLASS PASSIVATED BRIDGE RECTIFIER Fig.2 Typical Reverse Characteristics 1.2 1.0 0.8 0.6 0.4 0.2 Resistive or Inductive Load 0.0 25 50 75 100 125 150 175 Instaneous Reverse Current(μ A) Average Rectified Output Current (A) Fig.1 Average Rectified Output Current Derating Curve 100 T J =125°C 10 1.0 T J =25°C 0.1 00 1.0 0.1 pulse with 300μs 1% duty cycle 1.0 1.5 Instaneous Forward Voltage (V) 2.0 Peak Forward Surage Current (A) Instaneous Forward Current (A) T J =25°C 0.5 60 80 100 120 140 Fig.4 Maximum Non-Repetitive Peak Forward Surage Current Fig.3 Typical Instaneous Forward Characteristics 0.01 0.0 40 percent of Rated Peak Reverse Voltage (%) CaseTemperature (°C) 10 20 30 25 20 15 10 5 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 0 10 Number of Cycles 2/3 DB107S SURFACE MOUNT GLASS PASSIVATED BRIDGE RECTIFIER PACKAGE OUTLINE Dimensions in inches and (millimeters) Plastic surface mounted package; 4 leads .047(1.2) .037(0.95) ~ + .249(6.35) .245(6.2) .249(6.35) .245(6.2) ~ .390(9 . 9) .386(9 .85) .140(0.35) .008(0.2) .327(8.2) .325(8.15) .134(2.5) .124(2.4) .060(1.5) .055(1.4) .205(5.2) .197(5.0) 3/3
DB107S 价格&库存
很抱歉,暂时无法提供与“DB107S”相匹配的价格&库存,您可以联系我们找货
DB107S
    • 10+0.24819
    • 100+0.19570
    • 300+0.16946
    • 1500+0.14321
    • 4500+0.12741
    • 10500+0.11956
    库存:286
