LPF1005R240010K50
LPF1005R240010K50
    HEK(合康电子)
    LPF1005R240010K50
LPF1005R240010K50 数据手册
2.4GHz 1005 Low Pass Filter: LPF1005R240010K50   Applications: WLAN, 802.11b/g, Bluetooth, ISM Band… Features SMD, high reliability, ultra Impact… Part number LPF 1005 R 2400 (1) (2) (3) 10K (4) 50 (5) (1) Size Code 1.0x0.5mm (2) Packing Tape and reel (3) Frequency 2.4~2.5GHz (4) Packing Number 10K (5) TYPE 50 Electrical Specification Pass Band 2400~2500MHz Impedance 50 Ohm Insertion Loss Attenuation 0.5 dB (Max) at 25°C 25dB Min @ 4880~5000 MHz 25dB Min @ 7200~7500 MHz VSWR 2.0 (Max) Ripple 0.50dB The specification is defined on EVB. Dimension and Terminal Configuration Dimension (mm) No. Terminal Name L 1.00±0.10 P1 Input W 0.50±0.10 P2 GND T 0.35±0.10 P3 Output P1 0.30 ±0.15 P4 GND P2 0.30 ±0.15 P3 0.30 ±0.15 P4 0.30 ±0.15 D1 0.15 ±0.10 D2 0.35 ±0.15 2.4GHz 1005 Low Pass Filter: LPF1005R240010K50 Evaluation Board Reference Electrical Characteristics       2.4GHz 1005 Low Pass Filter: LPF1005R240010K50   Taping Specifications Reel and Taping Specification Reel Specification TYPE SIZE 1005 7” A 10K/Reel 2.0±0.5 ψB ψC ψD W ψM 13.5±1.0 21±1.0 60±1.0 11.5±2.0 178±2.0 Tapping Specification maker Packaging Type A B W E F G H T ψD P +0.10 Paper Type 1005 1.40±0.20 2.20±0.20 8.0±0.20 1.75±0.10 3.0±0.05 4.0±0.10 2.0±0.05 0.75±0.10 1.50 4.0±0.1 -0 2.4GHz 1005 Low Pass Filter: LPF1005R240010K50   Recommended Reflow Profile Pb free solder Soaking Temp. Working Soldering Peak Time Temp. Time Temp. Time Temp. T1 T2 t1 T3 t2 T4 t3 T5 150°C 180°C 60 to 120sec 230°C more than 30sec 247 to 253°C within 10sec 260°C Max. March 2019 Ver.H01
LPF1005R240010K50 价格&库存
很抱歉,暂时无法提供与“LPF1005R240010K50”相匹配的价格&库存,您可以联系我们找货
