TAXD60K2BGKBZT2S
TAXD60K2BGKBZT2S
    YJX(雅晶鑫)
    DT-26
    无源晶振 60kHz ±50ppm 12.5pF 35kΩ -20℃~+70℃
TAXD60K2BGKBZT2S 数据手册
雅晶鑫電子 ● ELECTRICAL PARAMETERS 谐振器产品技术指标 1.Holder Type(型号规格) 3.Frequency(标称频率) 4.Load Capacitance (CL)(负载电容) 5.Drive Level(激励功率) 6.Equivalent Resistance(谐振电阻) 7.Shunt Capacitance (Co)(静态电容) 8.Motional Capacitance (C1) (动态电容) 9.Frequency Tolerance at 25℃(调整频差) 10.Temperature Coefficient 二次温度系数 11.Insulation Resistance (at DC 100V)(绝缘电阻) 12.Operating Temperature Range(工作温度范围) 13.Storage Temperature Range(储存温度范围) 14.Aging(老化率) 15.DLD2 N/A 16.FLD2 17.RLD2 18.SPDB N/A 19.Other(其它) OUTLINE DIMENSIONS(UNIT:mm)外形尺寸(单位:mm) Min Max SEAM 206 60.000000 12.5 1.000 35 0 1.5 0.0028 -50 50 Units KHZ pF uw KΩ pF fF ppm [-0.035±0.01]ppm/℃ 500 -20 -40 MΩ ℃ ℃ ppm/year Ω ppm Ω db 70 85 ±5 N/A N/A N/A N/A N/A FREQUENCY VS. TEMPERATURE CURVE 雅晶鑫電子 Shenzhen Yajingxin Electron Co.,Ltd No. 1 Test Items Test Method and Condition Requirements 振動 (1)振動頻率Vibration Frequency 10 to 55Hz 頻率變化最大:±10ppm Vibration (2)振動幅度Vibration Amplitude 1.5mm Frequency Change:±10ppm Max. (3)周期 Cycle Time 1-2min(10-55-10Hz) 電阻變化最大:5kohm (4)振動方向Direction Resistance Change:5kohm Max. X.Y.Z (5)振動時間Duration 2h/each direction 2 衝擊 從75cm高的地方自由跌落3次到30mm厚的硬木板上 頻率變化最大:±10ppm Shock 3 Times free drop from 75cm height to hard wooden Frequency Change:±10ppm Max. board of thickness more than 30mm 電阻變化最大:5kohm Resistance Change: 5kohm Max. 3 氣密性 晶體放入氦加壓罐內,充入氦氣壓力0.5-0.6Mpa保持1小時; 漏氣率小於:1x10¯8mbar.l/s Leakage 然後使用氦質譜檢漏儀測試。 Leakage:1x10¯8mbar.l/s Max. Put crystal units into a hermetic container and Helium for 0.5-0.6 Mpa,and keep it for 1h;Check the leakage by a Helium leak detector 4 5 可焊性 將引線浸入完全熔化的焊錫鍋內3-5s,焊錫溫度245℃±5℃ 浸過引線面積的95%以上被新焊錫 Solderability Put the leads of crystal units into solder melted tank for 3 to 5s 覆蓋The dipped surface of the leads Temperature of solder melted tank is 245℃±5℃ should be at least 95% covered with 350℃±10℃,3+1/-0 sec 頻率變化最大:±10ppm 手工焊接耐热 Soldering iron Frequency Change:±10ppm Max. resistance 電阻變化最大:10kohm Resistance Change: 10kohm Max. 6 波峰焊耐热 推荐使用下面的波峰焊温度曲线进行波峰焊接。 Wave soldering The WAVE SOLDERING PROFILE as below is recommended: 雅晶鑫電子 Shenzhen Yajingxin Electron Co.,Ltd No. 7 Test Items Test Method and Condition 引線強度(引線直插式 用0.9kg(9N)的力持續拉晶體引線30s±5s; 晶體) Lead Strength(DIP) 用0.45kg的力折引線成90°2次(折弯处离机体1.5mm以上); Requirements 引線無異常 The crystal lead is not abnormity The crystal lead with the 0.9kg(9N)power(keep it for 30s±5s) and bend the crystal lead 90° with 0.45kg power and two times (which you want to bend should be more than 1.5mm from the case) 8 9 耐高溫能力 晶體放置於85℃±2℃環境中 2小時後,常溫放置1-2小時 頻率變化最大:±10ppm High Temperature The crystal units shall be put in somewhere for 2 hours at Frequency Change:±10ppm Max. Endurance temperature of 85℃±2℃,then keep it for 1 to 2 hours under room 電阻變化最大:5kohm temperature Resistance Change:5kohm Max. 耐低溫能力 晶體放置於-25℃ 環境中2小時後,常溫放置1-2小時 Low Temperature The crystal units shall be put in somewhere for 2 hours at Endurance temperature of -25℃,then keep it for 1 to 2 hours under room temperature 10 耐濕性 晶體放置於40℃ 、相對濕度90-95%環境中48小時後,常溫放 Humidity Endurance 置1-2小時The crystal units shall be put in somewhere at 40℃ in relative humidity of 90-95% for 48 hours, then keep it for one or two hours under room temperature 11 高低溫迴圈 溫度從-40℃(保持30分鐘)升高到100℃(保持30分鐘),再降 Temperature Cycle 到-40℃(保持30分鐘)然後回到室溫25℃完成一個迴圈,共計 5個迴圈Temperature shift from low(-40℃) to high(100℃,keep 30 minutes),satisfy high(100℃) to low(-40℃,keep 30 minutes),then go up to room temperature for 5 cycles
TAXD60K2BGKBZT2S 价格&库存
很抱歉,暂时无法提供与“TAXD60K2BGKBZT2S”相匹配的价格&库存,您可以联系我们找货
TAXD60K2BGKBZT2S
  • 5+0.14881
  • 50+0.11770
  • 150+0.10215
  • 1000+0.09049
  • 2000+0.08116
  • 5000+0.07647
库存:488
