MM102
Metal Film MELF Resistor
bility
tion
Relia
y
t
Innova
i
al
n via
w
o
Qu
t-D
Cos
Specifications Per
• IEC 60115-1
MM102
D2
• EN140401-803
Features
• SMD enabled structure
B
L
• Excellent solderability termination
D1
• Products meet RoHS requirements and do not contain
substances of very high concern identified by European
Chemicals Agency
DIMENSIONS
Type
Body Length
(L , mm)
Cap Diameter
(D1 , mm)
Body Diameter
(D2 , mm)
Soldering spot
(B, mm)
Net Weight
Per 1000 pcs
MM102
2.1 ± 0.1
1.1 ± 0.1
D1+0.02/-0.1
0.5 Min.
7 grams
GENERAL SPECIFICATIONS
Type
Power
Rating
at 70°C
Maximum
Working
Voltage
Maximum
Overload
Voltage
MM102
0.2W
150V
300V
Minimum
Resistance
Maximum
Resistance
Resistance
Tolerance
Available
Resistance
Value
0Ω, 10Ω
221KΩ
±0.5%
E-192
0.22Ω
2.2MΩ
±1%~±5%
E-24 / E-96
Special sizes and specifications available on request.
PART NUMBER
Example: MM102F162RTKRTR3K0
MM102
F
162R
TKR
TR3K0
Type
Tolerance*
Resistance
TCR
Packaging
D (0.5%)
F (1%)
G (2%)
J (5%)
162Ω
4-character code
containing 3 significant digits
1 letter multiplier
50ppm
3-character code
OHM MULTIPLIER
R=1
K = 103
M = 106
G = 109
Insert the corresponding
Code for the temperature
coefficient available for the
specific product.
TKQ = ±25PPM
TKR = ±50PPM
TKS = ±100PPM
* May not be applicable to all product types or to all resistance values. Please check with us before placing order.
89
www.firstohm.com.tw
general@firstohm.com.tw
5-character code
TR=Tape Reel
MM102
3K0 = 3,000
6K0 = 6,000
10K = 10,000
MM102
bility
tion
Relia
y
t
Innova
i
al
n via
w
o
Qu
t-D
Cos
MM102
POWER DERATING CURVE
100%
RATED
LOAD
80%
60%
40%
20%
0%
30
40
50
60
70
80
90
100
110
120
130
o
AMBIENT TEMPERATURE ( C)
TECHNICAL SUMMARY
Characteristics
Limits
Operating Temperature Range, °C
Temperature Coefficient, PPM / °C*
Dielectric Withstanding Voltage, VAC or DC
Insulation Resistance, MΩ
Tin Whisker (JESD201 Temperature Cycling & High
Temp./Humidity Storage), µm
-55 ~ +125
±1%, ±2%
±5%
150
>104
±25, ±50, ±100
±100
221KΩ
± 0.75%
0.22Ω to 100Ω
± 2.5%
>221KΩ
± 3.0%
0.22Ω to 100Ω
>100Ω
0.22Ω to 100Ω
>100Ω to 221KΩ
± 1.5%
0.22Ω to 100Ω
± 2.5%
>100Ω
± 0.5%
125°C
0.22Ω to 100Ω
± 5.0%
>100Ω to 221KΩ
>221KΩ
± 1.5%
± 2.0%
5 cycles
±0.5%
1,000 cycles
±2.0%
± 1.0%
Climatic test
IEC 60115-1 4.23
4.23.2 - dry heat: 16 hours 125°C
4.23.3 - damp heat: 24 hours 55°C with 95% relative humidity
4.23.4 - cold: 2 hours -55°C
4.23.5 - negative air pressure: 2 hour 8.5KPa at (25±10)°C
4.23.6 - damp heat cyclic: 5 days 55°C with 95% relative humidity
4.23.7 - DC load: rated voltage at -55°C and 125°C each 1 Min.
± 2.0%
Solderability
IEC 60115-1 4.17.2
Solder area covered after (235±3)°C/(2±0.2) seconds with flux applied
Flammability
IEC 60115-1 4.35
Needle flame test 10s
www.firstohm.com.tw
± 3.5%
± 5%
IEC 60115-1 4.38
3 positive & 3 negative discharges with 1.5KV
(For continuous surge application please see Surge Performance paragraph)
IEC 60115-1 4.33
Pressing depth 2mm, 3 times
± 5%
>221KΩ
Electrostatic
discharge
(Human body model)
Bending test
± 5%
± 2.5%
Single pulse high
voltage overload
IEC 60115-1 4.22
Six hours in each parallel and axial direction with a simple harmonic motion
having an amplitude of 1.52mm and 10 to 2,000 Hz.
± 5%
>100Ω to 221KΩ
IEC 60115-1 4.27
• 5 pulses of 1.2/50µs at 10x rated voltage (not over max. overload voltage)
with interval of 12 sec.
• 10 pulses of 10/700µs at 10x rated voltage (not over max. overload voltage)
with interval of 60 sec.
Vibration
91
Test Conditions
± 1.0%
± 1.0%
95% min. coverage
±1.0%
± 0.25%
No burning after 30s
MM102
bility
tion
Relia
y
t
Innova
i
al
n via
w
o
Qu
t-D
Cos
MM102
SUGGESTED PAD LAYOUT
Type
MM102
Soldering Mode
Pad Length
(L, mm, Min.)
Pad Spacing
(P, mm)
Pad Width
(W, mm, Min.)
Reflow
0.8
0.9 ± 0.05
1.3
Wave
1.2
0.7 ± 0.05
1.5
For better heat dissipation / lower heat resistance, increase W & L.
COVER TAPE PEELING SPECIFICATION
Recommended peeling force: 50gf±5gf
Revision: 31-OCT-2018
www.firstohm.com.tw
92
很抱歉,暂时无法提供与“MM102F10R0TKRTR3K0”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.32541
- 100+0.26190
- 300+0.23004
- 3000+0.20628
- 6000+0.18717
- 9000+0.17766
