TTR8MF
Voltage Range - 1000 Volts
Current - 8.0 Ampere
8A SURFACE MOUNT BRIDGE RECTIFIERS
Features
TTF
2
.209(5.30)
.193(4.90)
1
.346(8.80)
.330(8.40)
Fast reverse recovery time
Designed for Surface Mount Application
.385(9.80)
.370(9.40)
.0490(1.25)
.0330(0.85)
Reverse Voltage - 1000 V
Forward Current- 8.0 A
Mechanical Data
10°
.0216(0.55)
.0098(0.25)
Case: JEDEC TTF molded plastic body
Terminals: Solderable per MIL-STD-750,Method 2026
Polarity: Polarity symbol marking on body Mounting
Position: Any
Weight : 0.0163 ounce, 0.461 grams
Top Viev
4
Bottom View
.061(1.55)
.049(1.25)
.068(1.75)
.053(1.35)
3
∠ALL ROUND
.401(10.20)
.385(9.80)
(1)
(2)
VM
A
(3)
(4)
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
(TA=25°C unless otherwise specified)
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load currrent derate by 20% .
SYMBOL
TTR8MF
Units
Maximum Recurrent Peak Reverse Voltage
V RRM
1000
V
Maximum RMS voltage
V RMS
700
V
Maximum DC Blocking Voltage
V DC
1000
V
PARAMETER
IO
8.0
A
Peak Forward Surge Current,8.3ms Single Half Sine-wave
Superimposed on Rated Load (JEDEC method)
I FSM
220
A
IPeak Forward Surge Current 1.0ms Single
Half Sine-wave Superimposed on Rated Load
I FSM
350
A
I t
2
220
A2S
RθJA
RθJC
RθJL
60
6
14
°C/W
T j, T stg
-55 ~ +150
°C
Average Rectified Output Current at Tc = 100°C
2
I t Rating for Fusing
Typical Thermal Resistance(1)
Operating and Storage Temperature Range
PARAMETER
SYMBOL
Instantaneous forward voltage
VF
Reverse current at DC blocking voltage
IR
Maximum Reverse Recovery Time
trr
Typical Junction Capacitance
Cj
TEST CONDITIONS
MIN
TYP
MAX
Units
I F =1A
I F =4A
T J =25℃
T J =25℃
0.83
0.95
1.1
I F =1A
I F =4A
T J =125℃
T J =125℃
0.70
0.85
0.15
40
1
200
uA
500
ns
60
pF
T J =25℃
T J =125℃
Measured with
I = 0.5 A, IR = 1 A,
Irr = 0.25 A .
f=1MHz,VR=4V DC
T J =25℃
F
V
Note: 1. Measured at 1MHz and applied reverse voltage of 4 V D.C.
2. P.C.B. mounted with 4×1.5"×1.5"(3.81×3.81 cm)copper pad areas.
http://www.microdiode.com
Rev:2024A2
Page :1
TTR8MF
Typical Characterisitics
Average Rectified Output Current (A)
10
8.0
6.0
4.0
2.0
Resistive or Inductive Load
0.0
25
50
75
100
125
150
175
Instaneous Reverse Current(μ A)
Fig.2 Typical Reverse Characteristics
Fig.1 Average Rectified Output Current
Derating Curve
100
T J =125°C
10
1.0
T J =25°C
0.1
00
T J =25°C
1.0
0.1
pulse with 300μs
1% duty cycle
100
120
140
T J =25°C
100
10
1
0.5
1.0
1.5
2.0
2.5
0.1
210
180
150
120
90
60
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
10
Number of Cycles at 60Hz
100
Transient Thermal Impedance( °C /W)
240
1
1.0
10
100
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Peak Forward Surage Current (A)
80
1000
Instaneous Forward Voltage (V)
30
60
Fig.4 Typical Junction Capacitance
Junction Capacitance (pF)
Instaneous Forward Current (A)
Fig.3 Typical Instaneous Forward
Characteristics
0.01
0.0
40
percent of Rated Peak Reverse Voltage (%)
Case Temperature (°C)
10
Fig.6- Typical Transient Thermal Impedance
100
10
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
The curve above is for reference only.
Rev:2024A2
Page :2
TTR8MF
Suggested Pad Layout
5.1
201
1.8×2.1
71×83
8.7
343
Note:
1.Controlling dimension:in/millimeters.
2.General tolerance: ±0.05mm.
3.The pad layout is for reference purposes only.
Unit: m m
( mi l)
Rev:2024A2
Page :3
很抱歉,暂时无法提供与“TTR8MF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.54405
- 50+2.04088
- 150+1.82531
- 500+1.55628
- 3000+1.23920
- 6000+1.16738
- 国内价格
- 10+4.21730
- 200+2.51570
- 800+1.76100
- 3000+1.25790
- 6000+1.19500
- 30000+1.10690
