MVK 50V10M 5*5
MVK 50V10M 5*5
    SAMYOUNG(韩国三莹)
    SMD,D5xL5mm
    陶瓷电容/独石电容 SMD,D5xL5mm
MVK 50V10M 5*5 数据手册
SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS BDS(MVK) Series Solventproof •105℃ 1,000~2,000Hrs assured. WV ≦ 63VDC •Vertical SMD type. •Wide Temperature range. •For CD/DVD-ROM, Navigation, LED MT/TV. •RoHS compliant. •Halogen-free capacitors are also available. BDS MV (MVK) Wide Temp. SPECIFICATIONS Item Rated Voltage Range Operating Temperature Range Capacitance Tolerance Characteristics 6.3 ~ 450 V DC -40 ~ +105℃ ±20%(M) 6.3~100 0.01CV (㎂) or 3㎂ , whichever is greater. (at 20℃, 2 minutes) Rated Voltage(VDC) Max. Leakage current(㎂) Leakage Current (at 20℃, 120Hz) 160~450 0.04CV+100(㎂) (at 20℃, 1 minute) Where, C:Nominal capacitance(㎌), V:Rated voltage(VDC) Rated voltage(VDC) Ø4~Ø6.3 Ø8~Ø18 Dissipation Factor(Tan δ) Temperature Characteristics (Max. Impedance ratio) Rated voltage(VDC) Z(-25℃)/Z(+20℃) Z(-40℃)/Z(+20℃) 6.3 0.30 0.40 6.3 4 10 10 0.24 0.30 16 0.20 0.26 25 0.16 0.16 35 0.14 0.14 10 3 8 16 2 6 25 2 4 35 2 3 50~100 160~250 400~450 0.12 0.12 0.15 0.20 (at 20℃, at 120Hz) 50~100 160~250 400~450 3 3 6 4 6 15 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage is applied with the following conditions. Load Life BDS(MVK) Ø4~Ø6.3:105℃, 1,000 hours, Ø8~Ø18:105℃, 2,000 hours. Capacitance change Ø4~Ø6.3 ≦ ±30% of the initial value Ø8~Ø18 ≦ ±20% of the initial value Tanδ Ø4~Ø6.3 ≦ 300% of the initial specified value Ø8~Ø18 ≦ 200% of the initial specified value Leakage current ≦ The initial specified value Shelf Life Series The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for the specified time at 105℃ without voltage applied. The rated voltage shall be applied to the capacitors for a minimum of 30 minutes, at least 24 hours and not more than 48 hours before the measurements. Ø4~Ø6.3:105℃, 500 hours, Ø8~Ø18:105℃, 1,000 hours. Capacitance change Ø4~Ø6.3 ≦ ±25% of the initial value Ø8~Ø18 ≦ ±20% of the initial value Tanδ ≦ 200% of the initial specified value Leakage current ≦ The initial specified value Satisfied characteristics KS C IEC 60384-4 Others PART NUMBERING SYSTEM RATED RIPPLE CURRENT MULTIPLIERS Frequency Multipliers BDS 50 VC R47 M D55 TP With tape Case code Capacitance tolerance(±20%) Nominal capacitance code (ex. 0.1㎌:R1, 1.0㎌:1, 4.7㎌:4R7, 10㎌:10) Lead type Size code Cap.(㎌) Freq.(㎐) 0.1 ~ 1.0 D55~J10 2.2 ~ 10 22 ~ 1,500 3.3 ~ 4.7 10 ~ 68 K14~M22 100 ~ 1,000 1,500 ~ 6,800 120 1K 10K 100K 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.50 1.30 1.05 1.75 1.50 1.30 1.05 1.75 1.40 1.08 2.30 1.75 1.40 1.08 1.80 1.50 1.08 2.50 1.80 1.50 1.08 Rated voltage Series name 55 SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS DIMENSIONS OF BDS(MVK) Series Unit(mm) MARKING DIMENSIONS ●Vibration Resistance Note 1 : L±0.5 for 8×6.3(H63) ~ 18×21.5(M22) Note 2 : 4×5.2(D55), 5×5.2(E55) is excluded symbol mark. Note 3 : 6.3WV is marked by 6V. : Dummy terminals Recommended Solder land on PC board : Solder land on PC board Case code D55 E55 F55 F60 F80 H63 H10 J10 K14 L17 L22 M17 M22 ØD 4 5 6.3 6.3 6.3 8 8 10 12.5 16 16 18 18 L 5.2 5.2 5.2 5.7 7.7 6.3 10 10 13.5 16.5 21.5 16.5 21.5 A 4.3 5.3 6.6 6.6 6.6 8.3 8.3 10.3 13.0 17.0 17.0 19.0 19.0 B 4.3 5.3 6.6 6.6 6.6 8.3 8.3 10.3 13.0 17.0 17.0 19.0 19.0 C 5.1 5.9 7.2 7.2 7.2 9.0 9.0 11.0 13.7 18.0 18.0 20.0 20.0 W 0.5~0.8 0.5~0.8 0.5~0.8 0.5~0.8 0.5~0.8 0.5~0.8 0.7~1.1 0.7~1.1 1.0~1.3 1.0~1.3 1.0~1.3 1.0~1.3 1.0~1.3 P 1.0 1.4 1.9 1.9 1.9 2.3 3.1 4.5 4.2 6.5 6.5 6.5 6.5 a 1.0 1.4 1.9 1.9 1.9 2.3 3.1 4.5 4.0 6.0 6.0 6.0 6.0 b 2.6 3.0 3.5 3.5 3.5 4.5 4.2 4.4 5.7 6.9 6.9 7.9 7.9 c 1.6 1.6 1.6 1.6 1.6 1.6 2.2 2.2 2.5 2.5 2.5 2.5 2.5 a c 3.1 4.2 3.5 4.5 4.4 3.5 3.4 6.3 9.3 4.7 7.8 9.6 4.7 8.8 9.6 ▲ ●Vibration Resistance ※Please inquire beforehand for 16, 18Ø size b RATINGS OF BDS(MVK) Series VDC 6.3 10 16 25 0.1 0.22 0.33 0.47 1 2.2 3.3 4.7 D55 16 E55 25 10 D55 21 E55 30 E55 30 F55 40 22 E55 34 E55 34 F55 45 F55 45 33 E55 36 F55 48 F55 48 F60 H63 52 80 47 56 F60 H63 90 F60 H10 110 180 F80 H63 135 100 F55 F60 H63 150 F80 H63 150 F80 H10 150 275 H10 275 220 450 J10 450 J10 450 330 F80 H10 127 290 J10 J10 460 J10 460 J10 460 J10 460 470 J10 520 J10 540 K14 550 K14 550 1,000 J10 550 K14 620 1,500 K14 680 L17 850 M17 1,000 M22 1,300 2,200 M17 1,000 M17 1,100 M17 1,200 3,300 L22 1,200 M22 1,350 4,700 6,800 M22 1,350 μF μF VDC 3.3 4.7 10 22 33 47 68 100 200 160 J10 K14 K14 L17 M17 L22 45 85 95 260 320 380 K14 K14 L17 M17 M22 250 80 85 220 270 330 K14 L17 L17 M17 M22 65 100 180 230 280 K14 L17 L17 M22 50 D55 E55 F55 H63 H63 H10 J10 K14 K14 L17 15 25 40 80 140 250 375 480 520 750 M22 1,450 400 Rated Ripple Current(mArms/105℃, 120Hz) Case code 56 35 450 30 60 85 130 K14 L17 L17 M22 40 60 85 130 D55 D55 D55 D55 D55 D55 D55 E55 F55 H63 H10 H10 J10 K14 K14 L17 M22 63 1.3 2.6 3.2 3.8 5.6 10 14 19 29 70 140 170 310 420 500 700 1,200 D55 D55 D55 D55 D55 D55 E55 E55 F60 H10 H10 H10 K14 K14 L17 M17 100 1.3 3.0 4.0 5.0 8.0 12 17 20 32 80 145 180 380 470 700 900 H63 H10 J10 K14 K14 M17 M22 48 90 150 250 380 750 980
MVK 50V10M 5*5 价格&库存
很抱歉,暂时无法提供与“MVK 50V10M 5*5”相匹配的价格&库存,您可以联系我们找货
MVK 50V10M 5*5
    • 10+0.61409
    • 100+0.51041
    • 300+0.45857
    • 1000+0.37790
    • 5000+0.34679
    • 10000+0.33124
    库存:3526
