MVG50V47M8*6 8.0TP
MVG50V47M8*6 8.0TP
    SAMYOUNG(韩国三莹)
    SMD,D8xL6mm
    陶瓷电容/独石电容 SMD,D8xL6mm
MVG50V47M8*6 8.0TP 数据手册
SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS MVG(MV)-BP Series •85℃ 2,000Hrs assured. •Vertical SMD type. •Bi-polarized. •For LED MT / TV. •RoHS compliant. •Halogen-free capacitors are also available. BDS(MVK)-BP Series Solventproof •105℃ 1,000Hrs assured. MVG(MV) -BP MV •Vertical SMD type. •Bi-polarized. •Wide Temperature Range. •For LED MT / TV. •RoHS compliant. •Halogen-free capacitors are also available. BDS(MVK) -BP Wide Temp. Bi-polarized SPECIFICATIONS Item Characteristics Series Name Rated Voltage Range Operating Temperature Range Capacitance Tolerance Leakage Current (In both directions) MVG(MV)-BP 4 ~ 50 V DC -40 ~ +85℃ BDS(MVK)-BP 6.3 ~ 50 V DC -40 ~ +105℃ ±20%(M) (at 20℃, 120Hz) I=0.05CV(μA) or 10μA, whichever is greater. Where, I:Max. Leakage current(μA), C:Nominal capacitance(μF), V:Rated voltage(VDC) (at 20℃, after 2 minutes) Rated Voltage(VDC) 4 6.3 10 16 25 35~50 MV-BP 0.45 0.32 0.26 0.24 0.22 0.20 MVK-BP - 0.35 0.26 0.24 0.20 0.18 Dissipation Factor(Tan δ ) (at 20℃, 120Hz) Rated Voltage(VDC) Z (-25℃)/Z(20℃) Z (-40℃)/Z(20℃) Temperature Characteristics (Max. Impedance ratio) 4 7 15 6.3 4 10 10 3 8 16 2 6 25 2 4 35~50 2 3 The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage is applied with the following conditions with its polarization reversed every 250 hours. Series Name Test time & temperature Capacitance change Tanδ Leakage current Load Life MVG(MV)-BP 2,000 hours at 85℃ ≦±20% of the initial value ≦200% of the initial specified value ≦The initial specified value BDS(MVK)-BP 1,000 hours at 105℃ ≦±30% of the initial value ≦300% of the initial specified value ≦The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing MVG(MV)-BP) or 105℃(B BDS(MVK)-BP) without voltage applied. The rated them for 500 hours at 85℃(M voltage shall be applied to the capacitors for a minimum of 30 minutes, at least 24 hours and not more than 48 hours before the measurements. Shelf Life Series Name Capacitance change Tanδ Leakage current Others MVG(MV)-BP ≦±15% of the initial value ≦150% of the initial specified value ≦The initial specified value BDS(MVK)-BP ≦±25% of the initial value ≦200% of the initial specified value ≦The initial specified value Satisfied characteristics KS C IEC 60384-4 PART NUMBERING SYSTEM MVG 16 VC 22 M BP F55 TP With tape Case code Bi-polar type Capacitance tolerance(±20%) Nominal capacitance code (ex. 1.0㎌:1, 4.7㎌:4R7, 10㎌:10) Lead type Rated voltage Series name 83 MVG(MV)-BP/ BDS (MVK)-BP Series (at 120Hz) SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS DIMENSIONS OF MVG(MV)-BP, BDS(MVK)-BP Series DIMENSIONS Unit(mm) MARKING Recommended solder land on PC board Note 1 : 6.3WV is marked by 6V. Case code D55 E55 F55 F60 ØD 4 5 6.3 6.3 L 5.2 5.2 5.2 5.7 A 4.3 5.3 6.6 6.6 B 4.3 5.3 6.6 6.6 C 5.1 5.9 7.2 7.2 W 0.5~0.8 0.5~0.8 0.5~0.8 0.5~0.8 P 1.0 1.4 1.9 1.9 a 1.0 1.4 1.9 1.9 b 2.6 3.0 3.5 3.5 c 1.6 1.6 1.6 1.6 : Solder land on PC board RATINGS OF MVG(MV)-BP, BDS(MVK)-BP Se r i es MVG(MV)-BP VDC ㎌ 1.0 (1.5) 2.2 3.3 4.7 (6.8) 10 (15) 22 33 47 4 6.3 10 16 D55 D55 D55 D55 12 E55 21 13 14 E55 23 F55 36 F55 25 35 D55 9 E55 15 F55 24 11 E55 18 F55 28 50 D55 8 E55 F55 F55 13 17 21 D55 D55 E55 E55 F55 5.5 6.5 9 11 14 33 Rated Ripple Current(mArms/ 85℃, 120Hz) Case code BDS(MVK)-BP V DC ㎌ 1.0 (1.5) 2.2 3.3 4.7 (6.8) 10 (15) 22 33 47 6.3 10 16 D55 D55 E55 F60 D55 11 E55 20 F60 35 12 E55 23 F60 25 35 D55 8 E55 16 F60 28 10 18 50 D55 7 E55 14 F60 23 D55 D55 E55 E55 F60 F60 5.3 7.2 9.0 12 16 20 32 39 Rated Ripple Current (mA rms/105℃, 120Hz) Case code Note : → Use next higher voltage part. Parenthesized capacitance is not standard part. 84
MVG50V47M8*6 8.0TP 价格&库存
很抱歉,暂时无法提供与“MVG50V47M8*6 8.0TP”相匹配的价格&库存,您可以联系我们找货
