BDA50V1M4*5 4.0TP
BDA50V1M4*5 4.0TP
    SAMYOUNG(韩国三莹)
    SMD,D4xL5mm
    1UF ±20% 50V
BDA50V1M4*5 4.0TP 数据手册
SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS BDA Series Solventproof •105℃ 2,000Hrs assured. •Vertical SMD type. •Long Life. •For LED MT/TV, Copying Machine. •RoHS compliant. •Halogen-free capacitors are also available. BDS BDA (MVK) Long Life SPECIFICATIONS Item Characteristics Rated Voltage Range Operating Temperature Range Capacitance Tolerance 4 ~ 50 V DC -40 ~ +105℃ ±20%(M) (at 20℃, 120Hz) I=0.01CV(μA) or 3 μA, whichever is greater. Where, I:Max. Leakage current(μA), C:Nominal capacitance(μ F), V:Rated voltage(VDC) (at 20℃, 2 minutes) Leakage Current Dissipation Factor(Tan δ) Rated voltage(VDC) 4 6.3 10 16 25 35 Tanδ(Max.) 0.37 0.28 0.24 0.20 0.16 0.13 50 0.12 (at 20℃, 120Hz) Temperature Characteristics (Max. Impedance ratio) Rated voltage(VDC) 4 6.3 10 16 25~50 Z(-25℃)/Z(20℃) Z(-40℃)/Z(20℃) 6 12 3 8 3 5 2 4 2 3 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage applied for 2,000 hours at 105℃. Rated voltage(VDC) Load Life Capacitance change Tanδ 4 ~ 16 25 ~ 50 ≦ ±25% of the initial value ≦ ±20% of the initial value ≦ 200% of the initial specified value ≦ The initial specified value Shelf Life Rated voltage(VDC) Capacitance change Tanδ 25 ~ 50 ≦ ±25% of the initial value ≦ ±20% of the initial value ≦ 200% of the initial specified value Leakage current Others 4 ~ 16 ≦ The initial specified value Satisfied characteristics KS C IEC 60384-4 PART NUMBERING SYSTEM RATED RIPPLE CURRENT MULTIPLIERS Frequency Multipliers BDA 16 VC 100 M F60 TP With tape Case code Capacitance tolerance(±20%) Nominal capacitance code (ex. 0.1㎌:R1, 1.0㎌:1, 4.7㎌:4R7, 10㎌:10) Lead type Rated voltage Series name Cap.(㎌) Freq.(㎐) 1 2.2 ~ 10 22 ~ 100 120 1K 10K 100K 1.00 1.00 1.00 1.50 1.30 1.05 1.75 1.40 1.08 1.80 1.50 1.08 69 Series The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without voltage applied. The rated voltage shall be applied to the capacitors for a minimum of 30 minutes, at least 24 hours and not more than 48 hours before the measurements. BDA Leakage current SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS DIMENSIONS OF BDA Series Unit(mm) DIMENSIONS MARKING Note 1 : 4×5.2(D55), 5×5.2(E55) is excluded symbol mark. Note 2 : 6.3WV is marked by 6V. Recommended solder land on PC board Case code Ø D D55 4 E55 5 F55 6.3 6.3 F60 L 5.2 5.2 5.2 5.7 A 4.3 5.3 6.6 6.6 B 4.3 5.3 6.6 6.6 C 5.1 5.9 7.2 7.2 W 0.5~0.8 0.5~0.8 0.5~0.8 0.5~0.8 P 1.0 1.4 1.9 1.9 a 1.0 1.4 1.9 1.9 : Solder land on PC board RATINGS OF BDA Series VDC 4 μF 1 2.2 3.3 4.7 10 22 33 47 100 D55 E55 E55 E55 6.3 19 30 34 45 D55 E55 E55 F60 16 10 21 34 36 56 E55 E55 F55 F60 30 34 48 90 D55 E55 F55 F55 F60 25 16 30 45 48 110 D55 E55 F55 F55 F60 Rated Ripple Current (mArms/105℃, 120Hz) Case code 70 35 13 25 40 45 52 D55 E55 F55 50 15 25 40 D55 D55 D55 E55 F55 5.6 10 14 19 29 b 2.6 3.0 3.5 3.5 c 1.6 1.6 1.6 1.6
BDA50V1M4*5 4.0TP 价格&库存
很抱歉,暂时无法提供与“BDA50V1M4*5 4.0TP”相匹配的价格&库存,您可以联系我们找货
BDA50V1M4*5 4.0TP
库存:870
