TXM12.288M0004322FBCDO00T
    YJX(雅晶鑫)
    SMD3225_4P
    无源晶振 12.288MHz ±10ppm 12pF 60Ω -40℃~+85℃
TXM12.288M0004322FBCDO00T 数据手册
雅晶鑫 ● TXM12.288M0004322FBCDO00T ELECTRICAL PARAMETERS 谐振器产品技术指标 1.Holder Type(型号规格) 2.Mode of Oscillation(振动模式) 3.Frequency(标称频率) 4.Load Capacitance (CL)(负载电容) 5.Drive Level(激励功率) 6.Equivalent Resistance(谐振电阻) 7.Shunt Capacitance (Co)(静态电容) 8.Motional Capacitance (C1) (动态电容) 9.Frequency Tolerance at 25℃(调整频差) 10.Stability over operation temperance(温度频差) 11.Insulation Resistance (at DC 100V)(绝缘电阻) 12.Operating Temperature Range(工作温度范围) 13.Storage Temperature Range(储存温度范围) 14.Aging(老化率) 15.DLD2 16.FLD2 N/A 17.RLD2 18.SPDB N/A 19.Other(其它) OUTLINE DIMENSIONS(UNIT:mm)外形尺寸(单位:mm) Min Max Units SEAM 3.2*2.5 Fundamental MHZ 12.288000 pF 12 uw 100 Ω 60 pF 0 5 fF N/A ppm -10 10 ppm ± 20 MΩ 500 -40 85 ℃ -40 85 ℃ ±5 ppm/year N/A Ω N/A ppm N/A Ω N/A db N/A
TXM12.288M0004322FBCDO00T 价格&库存
很抱歉,暂时无法提供与“TXM12.288M0004322FBCDO00T”相匹配的价格&库存,您可以联系我们找货
库存:32698
  • 1+0.52470
  • 200+0.33770
  • 1500+0.29480
  • 3000+0.25960
库存:4891
