CLZ35V100M8*10 8.0TP 数据手册
SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS
CLZ Series
Solventproof
•125℃ 1,000~5,000Hrs assured.
WV ≦ 80VDC
•Vertical SMD type.
•Wide Temp., Low ESR.
•Suitable to fit for automotive equipment.
•RoHS compliant.
•Halogen-free capacitors are also available.
CLA
CLZ
Low ESR
•AEC-Q200 compliant : Please contact us for more details, test data, information.
SPECIFICATIONS
Item
Characteristics
Rated Voltage Range
Operating Temperature Range
Capacitance Tolerance
10 ~ 400 V DC
-40 ~ +125℃
±20%(M)
Leakage Current
Rated voltage(VDC)
10~100
160~400
Max. Leakage current
(μA)
I=0.01CV(μA) or 3μA, whichever is greater.
(at 20℃, 2 minutes)
0.04CV + 100( μA)
(at 20℃, 2 minutes)
Where, C : Nominal capacitance(㎌), V : Rated voltage(V DC )
Rated voltage(VDC)
Dissipation Factor(Tan δ)
Tanδ
(Max.)
10
16
25
35
50~80
100
0.22
0.19
0.16
0.14
0.12
0.10
160~250
400
0.20
0.24
(at 20℃, 120Hz)
Temperature Characteristics
(Max. Impedance ratio)
Rated voltage(VDC)
10
16
25
35~100
160~250
400
Z(-25℃)/Z(+20℃)
4
3
2
2
Z(-40℃)/Z(+20℃)
8
6
4
3
3
6
6
10
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 20℃
after the rated voltage is applied for the specified time at 125℃. Case Code 10~80V 100V
Load Life
≦ ±30% of the initial value
≦ 300% of the initial specified value
≦ The initial specified value (where, 500% for ≧ WV 80 VDC)
Satisfied characteristics KS C IEC 60384-4
PART NUMBERING SYSTEM
CLZ 16
Series
The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing
them for 1,000 hours at 125℃ without voltage applied. The rated voltage shall be applied to the
capacitors for a minimum of 30 minutes, at least 24 hours and not more than 48 hours before
the measurements. (Where, D55 ~ F60 is 500 hours)
Capacitance change
Tan δ
Leakage current
Others
160~400V
1,000Hrs
3,000Hrs
5,000Hrs 2,000Hrs
5,000Hrs 2,000Hrs 2,000Hrs
5,000Hrs 5,000Hrs 2,000Hrs
RATED RIPPLE CURRENT MULTIPLIERS
Frequency Multipliers
VC 330 M J10 TP
With tape
Case code
Capacitance tolerance(±20%)
Nominal capacitance code
(ex. 0.1㎌:R1, 1.0㎌:1, 4.7㎌:4R7, 10㎌:10)
Lead type
Rated voltage
Series name
Rated
Freq.(㎐)
Voltage(VDC) Size code Cap.(㎌)
10
D55~J10
22 ~ 470
47 ~ 100
10~100
220
~ 1,000
K14~M22
2,200 ~ 3,300
4,700
1 ~ 33
160~400 J10~M22
47 ~ 68
CLZ
Shelf Life
Capacitance change
Tan δ
Leakage current
D55~F60
H63
H10
J10
K14~M22
120
1K
10K
100K
0.66
0.93
0.40
0.50
0.75
0.85
1.00
1.00
0.86
0.97
0.75
0.85
0.90
0.95
1.50
1.30
0.93
1.00
0.90
0.94
0.95
0.98
1.75
1.40
1.00
1.00
1.00
1.00
1.00
1.00
1.80
1.50
75
DIMENSIONS OF CLZ Series
Unit(mm)
DIMENSIONS
MARKING
●Vibration Resistance
Note 1 : L±0.5 for 8×6.3(H63)~18×21.5(M22)
Note 2 : 4×5.2(D55), 5×5.2(E55) is excluded symbol mark.
Case code
D55
E55
F55
F60
H63
H10
J10
K14
L17
L22
M17
M22
: Dummy terminals
Recommended solder land on PC board
: Solder land on PC board
ØD
4
5
6.3
6.3
8
8
10
12.5
16
16
18
18
L
5.2
5.2
5.2
5.7
6.3
10
10
13.5
16.5
21.5
16.5
21.5
A
4.3
5.3
6.6
6.6
8.3
8.3
10.3
13.0
17.0
17.0
19.0
19.0
B
4.3
5.3
6.6
6.6
8.3
8.3
10.3
13.0
17.0
17.0
19.0
19.0
C
5.1
5.9
7.2
7.2
9.0
9.0
11.0
13.7
18.0
18.0
20.0
20.0
※Please inquire beforehand for 16, 18Ø size
W
0.5~0.8
0.5~0.8
0.5~0.8
0.5~0.8
0.5~0.8
0.7~1.1
0.7~1.1
1.0~1.3
1.0~1.3
1.0~1.3
1.0~1.3
1.0~1.3
P
1.0
1.4
1.9
1.9
2.3
3.1
4.5
4.2
6.5
6.5
6.5
6.5
a
1.0
1.4
1.9
1.9
2.3
3.1
4.5
4.0
6.0
6.0
6.0
6.0
b
2.6
3.0
3.5
3.5
4.5
4.2
4.4
5.7
6.9
6.9
7.9
7.9
c
1.6
1.6
1.6
1.6
1.6
2.2
2.2
2.5
2.5
2.5
2.5
2.5
a
b
c
3.1
4.5
3.4
4.2
4.4
6.3
3.5
3.5
9.3
4.7
7.8
9.6
4.7
8.8
9.6
RATINGS OF CLZ Series
VDC
10
μF
10
22
33
47
100
220
330
470
1,000
2,200
3,300
4,700
16
D55
E55 3.30 49.5 23 E55
E55 3.30 49.5 23 F55
F55 2.00 30.0 40 F60
H63 0.90 14.0 110 H63
H10 0.40 6.0 220 H10
J10 0.30 4.5 296 J10
J10 0.30 4.5 296 K14
K14 0.14 2.1 750 M17
L17 0.10 1.5 1,000
M17 0.10 1.5 1,200
M22 0.058 0.87 1,550
7.00
3.30
2.00
1.60
0.90
0.40
0.30
0.14
0.10
25
105 12
49.5 23
30.0 40
24.0 69
14.0 110
6.0 220
4.5 296
2.1 750
1.5 1,200
35
E55 3.30 49.5 23
F55 2.00 30.0 40
F60 1.60 24.0 69
H63 0.90 14.0 110
H10 0.40 6.0 220
J10 0.30 4.5 296
K14 0.14 2.1 750
L17 0.10 1.5 1,000
F60
F60
H63
H10
H10
J10
K14
M17
1.60
1.60
0.90
0.40
0.40
0.30
0.14
0.10
24.0 69
24.0 69
14.0 110
6.0 220
6.0 220
4.5 296
2.1 750
1.5 1,000
Rated Ripple Current (mArms/125℃, 100kHz)
ESR (Ωmax./-40℃, 100kHz)
ESR (Ωmax./20℃, 100kHz)
Case code
VDC
μF
1
2.2
3.3
4.7
10
22
33
47
68
160
K14
L17
M17
M22
M22
200
100
180
245
315
380
K14
L17
M17
M22
250
100
180
245
315
L17
M17
M22
400
120
205
260
J10
J10
J10
K14
L22
18
26
37
70
140
Rated Ripple Current (mArms/125℃, 120Hz)
Case code
76
50
F60
H63
H10
J10
J10
K14
L17
M17
2.80
1.60
0.70
0.50
0.50
0.23
0.15
0.15
42.0
30.0
11.0
7.5
7.5
3.5
2.3
2.3
63
51
83
160
247
247
550
850
920
H63
H10
J10
J10
K14
L17
L17
L22
2.00
1.00
0.55
0.55
0.33
0.24
0.24
0.16
110
50.0
27.5
27.5
16.5
12.0
12.0
8.0
80
60
70
115
115
450
650
650
950
H10
J10
J10
K14
L17
M17
1.20
0.55
0.55
0.33
0.24
0.16
80.4
35.0
35.0
21.1
15.4
10.2
100
70
115
115
450
650
950
H10
J10
J10
K14
K14
1.60 107.2
1.00 64.0
0.80 51.2
0.33 19.8
0.33 19.8
70
95
115
450
450
