BXA35V47M6.3*6 6.3TP 数据手册
SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS
BXA Series
Solventproof
•105℃ 1,000~2,000Hrs assured.
•Vertical SMD type.
•Low Impedance.
•For STB, Satellite Radio, Computer Server.
•RoHS compliant.
•Halogen-free capacitors are also available.
MVY
BXA
Low Imp.
SPECIFICATIONS
Item
Rated Voltage Range
Operating Temperature Range
Capacitance Tolerance
Leakage Current
Characteristics
6.3 ~ 50 V DC
-55 ~ +105℃
±20%(M)
(at 20℃, 120Hz)
I=0.01CV(μA) or 3 μA, whichever is greater.
Where, I:Max. Leakage current(μA), C:Nominal capacitance(μ
F), V:Rated voltage(VDC)
(at 20℃, 2 minutes)
Rated Voltage(VDC)
6.3
10
16
25
35
50
D56~H63
0.24
0.20
0.16
0.14
0.12
0.12
H10~J10
0.28
0.24
0.20
0.16
0.14
0.12
SIZE
Dissipation Factor(Tan δ)
Temperature Characteristics
(Max. Impedance ratio)
Rated voltage(VDC)
6.3
10
16
25
35
50
Z(-25℃)/Z(20℃)
Z(-55℃)/Z(20℃)
3
5
2
4
2
4
2
3
2
3
2
3
(at 20℃, 120Hz)
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated
voltage is applied with the following conditions.
Load Life
Ø4~Ø6.3 : 105℃, 1,000 hours, Ø8 & Ø10 : 105℃, 2,000 hours.
Capacitance change ≦ ±25% of the initial value
Tanδ
≦ 200% of the initial specified value
Leakage current
≦ The initial specified value
Shelf Life
Tanδ
Leakage current
Series
Others
Satisfied characteristics KS C IEC 60384-4
PART NUMBERING SYSTEM
RATED RIPPLE CURRENT MULTIPLIERS
Frequency Multipliers
BXA
16
VC
100 M
F60
TP
With tape
Case code
Capacitance tolerance(±20%)
Nominal capacitance code
(ex. 0.1㎌:R1, 1.0㎌:1, 4.7㎌:4R7, 10㎌:10)
Lead type
Rated voltage
Series name
Freq.(㎐)
Cap.(㎌)
2.2 ~ 4.7
10 ~ 100
220 ~ 470
1,000 ~ 1,500
BXA
The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing
them for 1000 hours at 105℃ without voltage applied. The rated voltage shall be applied to the
capacitors for a minimum of 30 minutes, at least 24 hours and not more than 48 hours before
the measurements.
120
1K
10K
100K
0.35
0.40
0.50
0.60
0.70
0.75
0.85
0.87
0.90
0.90
0.94
0.95
1.00
1.00
1.00
1.00
59
DIMENSIONS OF BXA Series
Unit(mm)
DIMENSIONS
MARKING
Note 1 : L±0.5 for 8×6.3(H63), 10×10(J10)
Note 2 : 4×5.3(D56), 5×5.3(E56) is excluded symbol mark.
Note 3 : 6.3WV is marked by 6V.
Case code Ø D
D56
4
E56
5
F60
6.3
F80
6.3
Recommended solder land on PC board
H63
8
H10
8
J10
10
L
A
5.3 4.3
5.3 5.3
5.7 6.6
7.7 6.6
6.3 8.3
10 8.3
10 10.3
B
4.3
5.3
6.6
6.6
8.3
8.3
10.3
C
5.1
5.9
7.2
7.2
9.0
9.0
11.0
W
0.5~0.8
0.5~0.8
0.5~0.8
0.5~0.8
0.5~0.8
0.7~1.1
0.7~1.1
P
1.0
1.4
1.9
1.9
2.3
3.1
4.5
a
1.0
1.4
1.9
1.9
2.3
3.1
4.5
b
2.6
3.0
3.5
3.5
4.5
4.2
4.4
c
1.6
1.6
1.6
1.6
1.6
2.2
2.2
: Solder land on PC board
RATINGS OF BXA Series
VDC
6.3
10
16
25
35
50
D56 4.80
30
80
E56
3.00
50
80
E56 0.90 150
F60
2.00
70
70
2.2
D56 2.10
4.7
D56 2.10
10
D56 2.10
22
33
D56 2.10
47
E56
68
F60
80
E56 0.90 150
E56
0.90
150
E56 0.90 150
F60
2.00
80
E56
0.90
150
F60
0.44 230
F60
0.44
230
F60
0.44 230
F80
1.00 170
0.90
150
F60
0.44
230
F60
0.44 230
F60
0.44
230
F60
0.44 230
H63
0.90 180
0.44
230
F60
0.44
230
F60
0.44 230
F60
0.44
230
F80
0.34 280
H10 0.44 230
F80
0.34
280
H63 0.32
300
H10 0.17 450
H10 0.44 230
J10
100
F60
0.44
230
F60
0.44
230
F60
0.44 230
220
F60
0.44
230
F80
0.34
280
F80
0.34 280
H10 0.17
450
H10 0.17 450
330
F80
0.34
280
H10 0.17
450
H10 0.17 450
H10 0.17
450
J10
470
H10 0.17
450
H10 0.17
450
H10 0.17 450
J10
670
1,000
H10 0.17
450
J10
670
1,500
J10
670
0.09
0.09
0.09
Rated Ripple Current (mArms/105℃, 100kHz)
Impedance (Ωmax./20℃, 100kHz)
Case code
60
0.09 670
0.30 350
BXA35V47M6.3*6 6.3TP 价格&库存
很抱歉,暂时无法提供与“BXA35V47M6.3*6 6.3TP”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.74531
- 50+0.61571
- 150+0.55091
- 1000+0.47240
- 2000+0.43352
- 5000+0.41397
