Z-SUBDRCF607A002
Z-SUBDRCF607A002
    NEXTRON(正凌)
    插件
Z-SUBDRCF607A002 数据手册
1 2 3 DIM C±0.38 DIM B±0.25 DIM A±0.13 4 5 6 SPECIFICATIONS: Current rating:3.0A AC/DC Voltage rating:250V AC/DC Contact resistance:30m ohm MAX Insulation resistance:5000M ohm MIN Withstanding voltage:1000V AC for one minute Operating temperature range:-40°C~+85°C 12.5 7.92 2.84 8 4#-40 2.77 A 7 18.3±0.3 B MATERIAL AND FINISH Insulator:PBT+30%G.F(UL94V-0) Contact:Copper Alloy, Nickel Undercoated Selective Gold Plated Shell:Metal Iron, With Tin Plated DIM X 5.8 2.84±0.2 10 ° A B PART NO. Z-SUBDR * F * * * * * * * 3.2 0.6x0.5 DIM B±0.15 Ø DIM Y 3. 2± 0. 1 C 37P 54.83 63.50 69.32 8.08 9.50 25P 38.38 47.04 53.04 8.08 9.50 2.84 Ø1.0 POS. NO. A B 6=SCREWED HEX SCREW ON BOARD LOCK 7=RIVETED W/ BOARD LOCK/WASHER 8=RIVETED W/BOARD LOCK/ WASHER/HEX SCREW 9=RIVETED W/ BOARD LOCK/WASHER/ ATTACHED HEX SCREW C=SCERWED HEX SCREW DIRECT RIVETING NUT LOCK C X Y DIMENSION D 7 TYPE 9 TYPE 8 TYPE H C TYPE #4-40 H H H 6 TYPE L SCREW 2PCS RIVETED W/ BOARD LOCK/WASHER SCREWED HEX SCREW ON BOARD LOCK RIVETED W/BOARD LOCK/ WASHER/HEX SCREW RIVETED W/ BOARD LOCK/WASHER/ ATTACHED HEX SCREW UNITS: mm CS RP NI CO ENGINEERING ISSUE DATE OR AT XT RO SIZE inch mm ± ** ± ** ± 0.20 ± 0.30 X°± 3° N NE IO This file is automatically issued by EPDM 1 A3 GENERAL TOLERANCE: (UNLESS SPECIFIED) B MARK MODIFY ECN-19105 B =1 NEW RELEASED A REV. DESCRIPTION and is not valid without the issue date 2 3 PLATED A=GOLD 1u"/LIGHT TIN B=GOLD 3u"/LIGHT TIN C=GOLD 5u"/LIGHT TIN E=GOLD 15u"/LIGHT TIN F=GOLD 30u"/LIGHT TIN 2019/11/21 2017/05/31 DATE 4 4 PLACE 3 PLACE 2 PLACE 1 PLACE ANGLES 5 inch ±. ** ±. ** ±. ** ±. ** NUT POST HEIGHT(H*L) B 0=5.8*12.8(STD) 1=4.8*11.8 NAME: D-SUB DR TYPE FEMALE PCB SOLDER TYPE PART NO: Z-SUBDRXFXX7XXXX APPD: DRAW: 6 E NEXTRONICS ENGINEERING CORP. TITLE: CUSTOMER DWG DWG NO: 010-0000-687 CHKD: DESIGN: D CONTACT MATERIAL 7=PHOSPHOR BRONZE SCERWED HEX SCREW DIRECT RIVETING NUT LOCK Mounting Options E C INSULATOR MATERIAL 0=PBT 2=NYLON MOUNTING OPTIONS 9P 16.33 24.99 30.81 8.08 9.50 PCB LAYOUT INSULATOR COLOR 0=BLACK 6=BLUE 9=WHITE TYPE F=FEMALE 15P 24.66 33.32 39.14 8.08 9.50 2.77 LOGO 0=NO LOGO 2=NEXTRON LOGO NO. OF CONTACTS A=9PIN B=15PIN C=25PIN E=37PIN 2019/11/21 7 SCALE SHEET REV. B 1/1 1/1 8 CON FIDEN TIAL: THIS DOC UMENT C ON TA INED THE INF OR MA TION IS P ROP RIETARY AND CONFIDE NTIAL TO Nextronics Engineering Corp. NO PERSON IS ALLOWED TO USE C OPY , PUBLISH OR OTHERW ISE D ISCLOSE THE INFOR MATION TO OTHER S, U NLESS BY TH E PRIOR WRITTEN EXPRESS AUTHORIZATION OF N extronics E ngineering C orp. (C )C OPYR IGHT- Nextronics Engineering Corp. A5 C D-PRD-034
Z-SUBDRCF607A002 价格&库存
很抱歉,暂时无法提供与“Z-SUBDRCF607A002”相匹配的价格&库存,您可以联系我们找货
