AL6M-M14P-R
AL6M-M14P-R
    IDEC(日本和泉)
    按动开关
AL6M-M14P-R 数据手册
Switches & Pilot Devices ø16mm - A6 Series Switches & Pilot Devices A6 Series — Miniature Switches and Pilot Devices: 16mm Key features: CSA Certified File No. LR21451 Degree of Protection IP40: Dustproof IP65 Watertight/Oiltight Contact Configuration SPDT, DPDT Maximum Voltage 250V AC/DC Thermal Current 3A Minimum Applicable Load 5V AC/DC, 1mA Contact Material Gold-clad silver Terminal Style .110” Solder/ Quick Connect Operating Temperature -25º to +55ºC (no freezing) Operating Humidity 45 to 85% RH Contact Resistance 50mΩ maximum (initial value) Insulation Resistance 100MΩ minimum (500V DC megger) Vibration Resistance 10 to 55Hz, amplitude 1.5mm p-p Shock Resistance Damage limits: 500m/sec2 (approx. 50G) Operating extremes: 200m/sec2 (approx. 20G) Electrical Life 100,000 operations minimum (at full rated load) Mechanical Life Maintained: 100,000 operations minimum Momentary: 1,000,000 operations minimum Selector/Keylock: 250,000 operations minimum Dielectric Strength Switch Unit: 2,000V AC, 1 min. between live/dead part and terminals of different poles; 1,000V AC, 1 minute between terminals of the same pole; 1,500V AC, 1 minute between contact and lamp terminals. Illumination Unit: 2,000V AC, 1 min. between live part/ground Soldering Temperature 20W/5 seconds or 260ºC/3 seconds Rated Voltage/Current Contact Ratings 240V 1.0A 0.5A Inductive — 0.7A 0.5A Resistive 1.0A 0.2A — Inductive 0.7A 0.1A — 5V DC ±5% 6V AC/DC (±10%) 12V AC/DC (±10%) 24V AC/DC (±10%) 8mA AC: A, R, W, Y: 8mA G, S: 7mA DC: A, R, W, Y: 6mA G, S: 5mA AC: 9mA DC: 8mA AC: 9mA DC: 8mA Terminal Blocks DC 120V — Contactors AC (50/60Hz) 24V Resistive Timers Operating Voltage Relays & Sockets Specifications UL Recognized File No.E55996 LED Lamp Ratings Signaling Lights • 16mm (5/8”) mounting hole • LED illumination • Compact design saves space • Momentary, Maintained, Selectors, and E-Stops • Gold-clad Silver contacts for reliable low level switching • Snap action contacts • IP40 (dustproof) or IP65 (oiltight) versions 1705151131 800-262-IDEC (4332) • USA & Canada Circuit Breakers 1. AC Inductive Load, PF = 0.6 – 0.7; DC Inductive Load, L/R = 7ms. 2. LED lamp contains a built-in current limiting resistor and a protection diode. 3. LED’s don’t “burn out.” Luminance is reduced to 50% of initial intensity after being lit for 50,000 hours continuously. 541 Switches & Pilot Devices Switches & Pilot Devices ø16mm - A6 Series Non-Illuminated Pushbuttons jButton Color Code Part Number Style Contact Momentary Dustproof (IP40) Maintained (Latching) Oiltight (IP65) Dustproof (IP40) Oiltight (IP65) Round 18mm Standard Button SPDT DPDT Signaling Lights AB6 Non-Illuminated Pushbuttons (Assembled) AB6M-M1-➀ AB6M-M2-➀ AB6M-M1P-➀ AB6M-M2P-➀ AB6M-A1-➀ AB6M-A2-➀ AB6M-A1P-➀ AB6M-A2P-➀ Color Code Black B Green G Red R Blue S White W Yellow Y Square 18mm SPDT DPDT AB6Q-M1-➀ AB6Q-M2-➀ AB6Q-M1P-➀ AB6Q-M2P-➀ AB6Q-A1-➀ AB6Q-A2-➀ AB6Q-A1P-➀ AB6Q-A2P-➀ SPDT DPDT AB6H-M1-➀ AB6H-M2-➀ AB6H-M1P-➀ AB6H-M2P-➀ AB6H-A1-j AB6H-A2-j AB6H-A1P-➀ AB6H-A2P-➀ Relays & Sockets Rectangular 18mm x 24mm Round 23.5mm Oversize Button Timers SPDT DPDT – AB6M-M1P-M➁ AB6M-M2P-M➁ – AB6M-A1P-M➀ AB6M-A2P-M➀ Square 23.5mm SPDT DPDT – AB6Q-M1P-Q➀ AB6Q-M2P-Q➀ – AB6Q-A1P-Q➀ AB6Q-A2P-Q➀ SPDT DPDT – AB6Q-M1P-H➀ AB6Q-M2P-H➀ – AB6Q-A1P-H➀ AB6Q-A2P-H➀ 1. In place of ➀ specify Button Color Code from the table at right. 2. To order as sub-assembled, see page 459. 3. For accessories, see page 466. 4. For dimensions, see page 468. Circuit Breakers Terminal Blocks Contactors Rectangular 17.5 X 23.5mm 542 www.IDEC.com 1705151131 Switches & Pilot Devices ø16mm - A6 Series Switches & Pilot Devices AB6 Non-Illuminated Pushbuttons (Sub-Assembled) Operator + Button = Completed Unit Style Contact Non-Illuminated Pushbuttons SPDT Part Number Operator Round Square Rectangular Momentary AB6M-M100 AB6Q-M100 AB6H-M100 Maintained AB6M-A100 AB6Q-A100 AB6H-A100 Momentary AB6M-M200 AB6Q-M200 AB6H-M200 Maintained AB6M-A200 AB6Q-A200 AB6H-A200 Relays & Sockets DPDT Signaling Lights Operators Oversize rectangular button uses square operator. Buttons Part Number Description Button Dustproof (IP40) Oiltight (IP65) Round AB6M-BK2-j Square AB6Q-BK2-j AB6H-BK1-j AB6H-BK2-j – AB6M-BK2-Mj – AB6Q-BK2-Qj – AB6Q-BK2-Hj Code Black B Green G Red R Blue S White W Yellow Y Contactors AB6Q-BK1-j Color Timers AB6M-BK1-j jButton Color Code Rectangular Round Oversize Terminal Blocks Square Oversize Rectangular Oversize Circuit Breakers 1. In place of j, specify Button Color Code from table. 2. Buttons which are rated IP65 include a waterproof rubber gasket. 3. For accessories, see page 466. 1705151131 800-262-IDEC (4332) • USA & Canada 543 Switches & Pilot Devices AL6 Illuminated Pushbuttons (Assembled) LED Illuminated Pushbuttons Part Numbers Description Style Momentary Contact Maintained (Latching) Dustproof (IP40) Oiltight (IP65) Dustproof (IP40) Oiltight (IP65) SPDT DPDT AL6M-M1➂-➁ AL6M-M2➂-➁ AL6M-M1➂P-➁ AL6M-M2➂P-➁ AL6M-A1➂-➁ AL6M-A2➂-➁ AL6M-A1➂P-➁ AL6M-A2➂P-➁ SPDT DPDT AL6Q-M1➂-➁ AL6Q-M2➂-➁ AL6Q-M1➂P-➁ AL6Q-M2➂P-➁ AL6Q-A1➂-➁ AL6Q-A2➂-➁ AL6Q-A1➂P-➁ AL6Q-A2➂P-➁ SPDT DPDT AL6H-M1l-➁ AL6H-M2l-➁ AL6H-M1lP-➁ AL6H-M2lP-➁ AL6H-A1l-➁ AL6H-A2l-➁ AL6H-A1lP-➁ AL6H-A2lP-➁ Round (18mm lens) Square (18mm lens) Standard Lens Rectangular (18mm x 24mm lens) Relays & Sockets Signaling Lights Switches & Pilot Devices ø16mm - A6 Series Timers Round (24mm lens) SPDT DPDT – AL6M-M1➂P-M➁ AL6M-M2➂P-M➁ – AL6M-A1➂P-M➁ AL6M-A2➂P-M➁ SPDT DPDT – AL6Q-M1➂P-Q➁ AL6Q-M2➂P-Q➁ – AL6Q-A1➂P-Q➁ AL6Q-A2➂P-Q➁ SPDT DPDT – AL6Q-M1➂P-H➁ AL6Q-M2➂P-H➁ – AL6Q-A1➂P-H➁ AL6Q-A2➂P-H➁ Square (24mm lens) Oversize Lens Terminal Blocks Contactors Rectangular (18mm x 24mm lens) 1. In place of ➁, specify Lens/LED Color Code from table below. 2. In place of ➂, specify Voltage Code from table below. 3. Lamps also available in 5V DC, 6V AC/DC or 12 V AC/DC, change “4” using voltage/lamp codes (ie AL6M-M13-k uses 12V AC/DC LED). 4. LED lamp is included in unit and contains a current-limiting resistor and a protection diode. (External resistor not required.) 5. To order as sub-assembled, see page. 6. For accessories, see page. 7. For dimensions, see page. 8. Light independent of switch position. kLens/LED Color Code Code Amber A Voltage Code G 5V DC 1 Red R 6V AC/DC 2 Blue S 12V AC/DC 3 Warm White W 24V AC/DC 4 Cool White JW Yellow Y Green Circuit Breakers lVoltage Code Color 544 www.IDEC.com 1705151131 Switches & Pilot Devices ø16mm - A6 Series Switches & Pilot Devices AL6 Illuminated Pushbuttons (Sub-Assembled) Operator + LED Lamp + Lens = Completed Unit Operators Contact AL6 Illuminated Pushbuttons SPDT DPDT Round Square Rectangular Momentary AL6M-M100 AL6Q-M100 AL6H-M100 Maintained AL6M-A100 AL6Q-A100 AL6H-A100 Momentary AL6M-M200 AL6Q-M200 AL6H-M200 Maintained AL6M-A200 AL6Q-A200 AL6H-A200 Oversize rectangular button uses square operator. Relays & Sockets Part Number Operator Signaling Lights Style Lenses Unit Part Number Degree of Protection Dustproof (IP40) Size Standard Oiltight (IP65) Standard Oversize AL6M-LK1-k AL6M-LK2-k AL6M-LK2-M k AL6Q-LK1-k AL6Q-LK2-k AL6Q-LK2-Q k AL6H-LK1-k AL6H-LK2-k AL6Q-LK2-H k Round Timers Square Contactors Rectangular kLens/LED Color Code LED Lamps Color Code Amber A 5V DC LATD-5 k Green G 6V AC/DC LATD-6 k Red R 12V AC/DC LATD-1 k Blue S 24V AC/DC LATD-2 k Warm White W Cool White JW Yellow Y Appearance Rated Voltage Part Number Circuit Breakers 1705151131 Terminal Blocks 1. In place of k, specify Lens Color Code from table below. 2. Lenses which are rated IP65 include a waterproof rubber gasket. 3. For accessories, see page. 1. In place of k, specify LED Color Code from table at left. 800-262-IDEC (4332) • USA & Canada 545 Switches & Pilot Devices Signaling Lights Switches & Pilot Devices ø16mm - A6 Series AL6 Pilot Lights (Assembled) LED Pilot Lights Description Part Number Dustproof (IP40) Oiltight (IP65) Round (18mm Lens) AL6M-Pl-k AL6M-PlP-k AL6Q-Pl-k AL6Q-PlP-k AL6H-Pl-k AL6H-PlP-k Square (18mm Lens) Relays & Sockets Rectangular (18mm x 24mm Lens) Timers 1. In place of k, specify Lens Color Code from table below. 2. In place of l, specify Voltage Code from table below. 3. LEDs also available in 5V DC, 6V AC/DC or 12 V AC/DC, change “4” using voltage codes (ie AL6M-P3-k uses 12V AC/DC LED). 4. LED is included and contains built-in current limiting resistor and reverse polarity protection diode. (no external resistor required) 5. To order sub-assembled, see page. 6. For accessories, see page. 7. For dimensions, see page. 8. For one piece pilot lights and/or dome lens pilot lights, see AP series miniature pilot lights. lVoltage Code Color Code Voltage Code Amber A 5V DC 1 Green G 6V AC/DC 2 Red R 12V AC/DC 3 Blue S 24V AC/DC 4 Warm White W Cool White JW Yellow Y Circuit Breakers Terminal Blocks Contactors kLens/LED Color Code 546 www.IDEC.com 1705151131 Switches & Pilot Devices ø16mm - A6 Series Switches & Pilot Devices AL6 Pilot Lights (Sub-Assembled) Operator + LED Lamp + Lens = Completed Unit Operators Round Square Signaling Lights Part Number Style Rectangular AL6 Pilot Lights AL6M-P00 AL6Q-P00 AL6H-P00 Relays & Sockets Lenses Part Number Degree of Protection Dustproof IP40 Oiltight IP65 AL6M-LK1-k AL6M-LK3-k AL6Q-LK1-k AL6Q-LK3-k AL6H-LK1-k AL6H-LK3-k Round Timers Square Contactors Rectangular 1. In place of k, specify Lens Color Code from table below. 2. Lenses which are rated IP65 include a waterproof rubber gasket. 3. For accessories, see page. LED Lamps Color Code Rated Voltage Part Number Amber A 5V DC LATD-5 k Green G 6V AC/DC LATD-6 k Red R 12V AC/DC LATD-1 k Blue S 24V AC/DC LATD-2 k Warm White W Cool White JW Yellow Y 1. In place of k, specify LED Color Code from table at left. Circuit Breakers 1705151131 Appearance Terminal Blocks kLens/LED Color Code 800-262-IDEC (4332) • USA & Canada 547 Switches & Pilot Devices AS6 Selector and Keylock Switches Round Selector Function 2-Position 90º Style 3-Position 45º Round Keylock Square Selector 3-Position 45º 2-Position 90º Timers Key R AS6M-2Y2P AS6M-2KT2Pj Spring Return Right L R AS6M-21Y2P AS6M-21KT2PB Maintained L R AS6M-3Y2P AS6M-3KT2Pj Spring Return Right gCenter L R AS6M-31Y2P AS6M-31KT2Pj Spring Return Left gCenter L 2-Way ReturngCenter L Maintained Spring Return to Right C C C C L R AS6M-32Y2P AS6M-32KT2Pj R AS6M-33Y2P AS6M-33KT2PD R C AS6Q-2Y2P AS6Q-2KT2Pj AS6Q-21Y2P AS6Q-21KT2PB AS6Q-3KT2Pj R AS6Q-31Y2P AS6Q-31KT2Pj R AS6Q-32Y2P AS6Q-32KT2Pj R AS6Q-33Y2P AS6Q-33KT2PD L R AS6H-2Y2P AS6H-2KT2Pj Spring Return Right L R AS6H-21Y2P AS6H-21KT2PB Maintained L Spring Return RightgCenter L Spring Return Left gCenter L 2-Way ReturngCenter L Maintained L Spring Return LeftgCenter L 2-Way ReturngCenter L C C C C C C C Operator Position & Contact Operation Left Left Right Contact Contact NO NC NO NC C 2-pos. (DPDT) Right C Left Right Contact Contact NO NC NO NC C Left Right Contact Contact NO NC NO NC C C AS6Q-3Y2P L Contents Left R L (for all selectors) C R Spring Return Right gCenter Rectangular Keylock 3-Position 45º Contactors Rectangular Selector Knob L Maintained Maintained Square Keylock 3-pos. (DPDT) Center Left Right Contact Contact NO NC NO NC C Right C Left Right Contact Contact NO NC NO NC C C Key Retention Codes R R AS6H-3Y2P AS6H-31Y2P AS6H-3KT2Pj Code Description A Key not retained in any position (removable in all positions) B Key retained in right position only C Key retained in left position only D Key retained in left and right (3 position only) E Key retained in center only (3 position only) G Key retained right and center (3 position only) H Key retained left and center (3 position only) AS6H-31KT2Pj R AS6H-32Y2P AS6H-32KT2Pj R AS6H-33Y2P AS6H-33KT2PD Key cannot be removed in a spring return position. 1. All models are IP65 and DPDT. 2. In place of j, specify Key Retention Code. See table on right. 3. Available as assembled units only. 4. For accessories, see page 466. 5. For dimensions, see page 468. Circuit Breakers Terminal Blocks Contact Operations AS6 Selector Switches and Keylock Switches (2 & 3 Position) 2-Position 90º Relays & Sockets Signaling Lights Switches & Pilot Devices ø16mm - A6 Series 548 www.IDEC.com 1705151131 Switches & Pilot Devices ø16mm - A6 Series Switches & Pilot Devices Switch Engraving Order Form – A6 Series Copy this order form and use it to specify Letter Height, Maximum Number of Lines and Text to be engraved. To insure engraving accuracy, fax it to your IDEC representative or Distributor. Your Company: Telephone: Name: Fax: Address: Email: Part Number to be Engraved: Signaling Lights PO: Please check one of the boxes below to indicate your choice of engraving options: Round Switch Square Switch Rectangular Switch Letter Height Max. Characters Per Line # of Lines Letter Height Max. Characters Per Line 1 5/32 6 1 5/32 5 # of Lines Letter Height Max. Characters Per Line 5/32 3 1/8 3 Relays & Sockets # of Lines 1 5/32 6 2 3 5/32 5 1/8 6 2 5/32 Custom* 1/8 6 3 1/8 Custom* 4 3/32 Custom* 2 1/8 6 1/8 6 N/A 4 N/A *Engraving is possible, but character size will be smaller than standard sizes. Timers 4 3 1. Engraving is done on the button itself for non-Illuminated pushbuttons and on marking plate for illuminated pushbuttons and pilot lights. 2. Please enter text exactly how you want it engraved, take care to emphasize capital or small letters. Sample Letter Sizes Contactors Enter text to be engraved : 1/8 Letters: Line 1: 5/32 Letters: Line 2: Line 3: Line 4: Terminal Blocks For IDEC Internal Use Only: Work Order #: Circuit Breakers 1705151131 800-262-IDEC (4332) • USA & Canada 549 Switches & Pilot Devices Relays & Sockets Signaling Lights Switches & Pilot Devices ø16mm - A6 Series Accessories Appearance Description Used With Part Number Ø 5/8” (16mm) units Ø 31/64” (12mm) AP2M units MT-001 MT-002 Ø 13/32” (10mm) AP1M units MT-003 Locking Ring Wrench Made of metal. Used for tightening plastic locking ring during installation. Tightening torque should not exceed 3kgf-cm Lens Removal Tool Made of metal. Used for removing lens or button from the housing All pushbuttons and pilot lights MT-101 Lamp Holder Tool Made of rubber. Used for removing and replacing LED lamps in illuminated units All illuminated pushbuttons and pilot lights OR-77 Prevents inadvertent switch operation. IP40 dust-tight. 90 degrees opening maintained Round/Square AL-K6 Rectangular AL-KH6 Prevents inadvertent switch operation. IP65 oiltight 180 degrees opening, spring return Round/Square AL-K6SP Rectangular AL-KH6SP Made of translucent nylon. Fits over and shields the terminals All 5/8” (16mm) units AL-V6 All round units All square units AL-D6 AL-DQ6 All rectangular units AL-DH6 Switch Guard Terminal Cover Dust Cover Fits over the lens or button to provide extra protection from dust (not applicable for oversize lenses or buttons). Plug-on terminal adaptor with solder terminals Circuit Breakers Terminal Blocks Contactors Timers Adaptor Socket Mounting Hole Plug Replacement LED Lamps Plug-on terminal adaptor with PCB terminals Fills unused panel cutouts. Made of nitrile rubber. Push-in installation from front of panel. IP65 (oiltight). Fills unused panel cutouts. Made of aluminum. Screw-on locking ring from inside of panel. IP65 (oiltight). Round Mounting Hole Plug Square Mounting Hole Plug Rectangular Mounting Hole Plug LED with built in current limiting resistor (with all illuminated assemblies). AL-C6 All 5/8” (16mm) units AL-C6V Rubber AL-B6 Aluminum AL-BM6 5V DC 6V AC/DC 12V AC/DC LA9Z-BS6 LA9Z-BS7 LA9Z-BS8 LATD-5 k LATD-6 k LATD-1 k 24V AC/DC LATD-2 k Plastic (Applicable for flush mount switches only) Replacement Locking Ring Fastens operators to panel (included with all operators). All switches & pilot lights HA9Z-LN Anti-Rotation Ring Prevents rotation of switches in panel (included with all operators). All switches & pilot lights AL6-LP Replacement Engraving Inserts Engraving plates to allow legends underneath translucent lenses (included with all lenses). Round standard Square standard Rectangular standard Round oversize Square/rectangular oversize AL6M-W AL6Q-W AL6H-W AL6M-MW AL6Q-QW Replacement Keys Pair of keys (#132). All key switches use same standard key. All key selectors AS6-SK 1. In place of k specify color code. A=Amber, G=Green, Y=Yellow, R=Red, S=Blue, W=Warm White, JW=Cool White. 2. LEDs include built-in current limiting resistor and reverse polarity protection diode. 550 www.IDEC.com 1705151131 Switches & Pilot Devices Description Used With ø24mm round, metal (aluminum color), panel cut-out ø20.2mm Part Number Pushbuttons, pilot lights, illuminated pushbutton, selector switches, key selector switches and illuminated selector switches. ø24mm round, plastic (black), square panel cut-out ø20.2mm Flush Bezel Switches & Pilot Devices Appearance ø16mm - A6 Series LA9Z-SM61 LA9Z-S61B 24mm square, plastic (black), panel cut-out 20.2 x 20.2mm 24 x 30mm rectangular, plastic (black), rectangular panel cut-out ø20.2 x 26.2mm Rectangular, plastic (black) LA9Z-S71B Flush Bezel = LA9Z-S81B Relays & Sockets Switch Guard w/ Flush Bezel (spring return) Signaling Lights A6 Switch + LA9Z-KS8 Flush Switch Schematics — A Series: 5/8” (16mm) Terminal Arrangement (Top View) Non-illuminated Pushbuttons and Selector Switches Illuminated Pushbuttons (TOP) (TOP) NC1 NC1 NC2 NC1 NC1 NC2 NO1 NO1 NO2 NO1 NO1 NO2 C1 Lamp Terminal (–) C1 C2 Lamp Terminal (–) DPDT Contact (Double-pole/Double Throw) C1 SPDT Contact (Single-pole/Double Throw) C1 C2 Lamp Terminal (+) Lamp Terminal (–) DPDT Contact (Double-pole/Double Throw) Contactors SPDT Contact (Single-pole/Double Throw) Lamp Terminal (+) (TOP) (TOP) Timers Lamp Terminal (+) (TOP) Pilot Lights IDEC’s Superbright LED Internal Circuits LATD-1,-2,-6 (GS) LATD-5 (ARWY) LED Chip Protective Diode Terminal Blocks Zener Diode LATD-1,-2,-6 (ARWY) LATD-5 (GS) Circuit Breakers 1705151131 800-262-IDEC (4332) • USA & Canada 551 Switches & Pilot Devices Dimensions (mm) Pushbuttons, Ø 5/8” (16mm) Rubber Gasket Terminal Width 2.8×0.5t 2.5 3 Panel Thickness 0.5 to 6 Anti-rotation Ring Rectangular (TOP) Locking Ring Round Square (TOP) ø18 (TOP) 1 8 0.6 9 22 24 9 Oversize Lens Rubber Gasket Anti-rotation Ring Panel Thickness 0.5 to 6 Rectangular (TOP) 5 6 6 1 0.6 8 9 22 Round (TOP) Square (TOP) 17.5 5 Locking Ring ø23.5 Teminal Width 2.8×0.5t 2.5 3 Relays & Sockets 5.7 18  23.5 Signaling Lights 5 18 5 Switches & Pilot Devices ø16mm - A6 Series 23.5 0.6 9 15.5 0.6 15.5 12.5 Selector Switches, Ø 5/8” (16mm) Terminal Width 2.8×0.5t 2.5 3 Panel Thickness 0.5 to 6 Rubber Gasket Anti-rotation Ring Rectangular (TOP) Locking Ring Square (TOP) Round (TOP) 8 18 5 Timers 5 ø1 8 1 8 22 15.5 24 18 Key Selector Switches, Ø 5/8” (16mm) 3 TOP Contactors 2.5 Right Contact Left Contact Rubber Gasket Terminal Width 2.8×0.5t Circuit Breakers 3 Panel Thickness 0.5 to 6 Locking Ring Rectangular (TOP) Square (TOP) Round (TOP) NC NO 18 5 5 Terminal Blocks 2.5 Anti-rotation Ring C 1 8 22 26 24 18 ø18 All dimensions are in mm. 552 www.IDEC.com 1705151131 Switches & Pilot Devices ø16mm - A6 Series Switches & Pilot Devices Switch Guard, Ø 5/8” (16mm) Panel Thickness 0.5 to 5 34 Panel Thickness 0.5 to 5 26.5 minimum R2 (45.5 minimum for 180° opening type) 10.5 23.5 13 2 33 24 Rubber Gasket 14 Rubber Gasket 28 14 (90°/110° opening type) 19 minimum Signaling Lights 26.5 minimum 10.5 23.5 13 18 (45.5 minimum for 180° opening type) 32 28 (180° opening type) 25 minimum Panel Thickness 0.5 to 5 34 2 10.5 45.5 min. 45.5 min. 10.5 23.5 23.5 13 Relays & Sockets 13 Waterproof Gasket for Switch Guard R2 24 33 18 Rubber Gasket 0.4 28 14 19 min. 25 min. Flush Bezel with Switch Flush Bezel Panel Thickness 0.5 to 5 14.8 4 4 ø2 2 29 2 18 24 Selector Switches Illuminated & Non-illuminated 2 Key Contactors 8.5 1 8 2 20 21.4 Square 8.5 8 ø143 9 ø2 8 ø1 0.9 0.8 9.8 Panel Thickness 0.5 to 5 Plastic Metal ø 20 ø21.4 22.6 Round Flush Bezel Gasket Timers Mounting Bracket Lever 24 18 20 21.4 Rectangular 2 18.1 2 8.5 2 Square Rectangular 26.2 +0.2 – 0.1 20.2 +0.2 – 0.1 1705151131 24 min.∗ 24 min.∗ 24 min.∗ 24 min.∗ Circuit Breakers 24 min.∗ +0.2 20.2 -0.1 ø2 0. 2 + – 0 0.2 .1 Terminal Blocks 9.3 Flush Bezel Mounting Hole Layout Round 2 17 26 27.4 23 24 30 30 min.∗ 800-262-IDEC (4332) • USA & Canada 553 Switches & Pilot Devices Switches & Pilot Devices ø16mm - A6 Series 2.5 33.5 TOP +0.3 0 2.5 Holes 3 2.4 (TOP) 5 NC2 5 5 5 NC1 NO1 NO2 16.2 6 7.5 6 16.2 Solder Terminal Type (AL-C6) 3.8 6 AL-DQ6, Square ø24 C1 C2 Lamp Terminal (–) Terminal Arrangement (Bottom View) Panel Cut-Outs For Units w/Dust Cover AL-DH6, Rectangular Round/Square 30  24 Lamp Terminal (+) PC Board Mounting Hole Layout (Bottom View) PC Board Terminal Type (AL-C6V) Terminal Sockets Dust Covers AL-D6, Round 6 ø16.2 Rectangular +0.2 0 ø16.2 +0.2 0 24 min. 24 min. 13 7.5 30 min. 24 min. Waterproof Gasket for Dust Cover 0.3 13 7.5 Waterproof Gasket for Dust Cover 0.3 13 7.5 Waterproof Gasket for Dust Cover 0.3 Relays & Sockets 24 Signaling Lights 8-1.6 Terminal 1.5×0.3t 33.5 3 Marking Plates Pushbuttons with Oversize Lens Style Round—AL6M-W Square—AL6Q-W Rectangular—AL6H-W Style Round—AL6M-MW øa a1 Engraving Area ca ❏ OD Dimensions a2 Contactors Ø 5/8” (16mm) Outside (OD) (13.8mm) (13.8mm) (OD1 x OD2) 13.8 x 19.8mm Marking Area (a) (12mm) (12mm) (a1xa2) 12 x 18mm Square/Rectangular—AL6Q-QW øOD ❏a Marking Area Marking Area 0.8 0.8 0.8 øa Engraving Area OD1 Dimensions Marking Area øOD OD2 øOD Timers Pushbuttons with Standard Size Lens Outside (OD) Ø 0.491” (12.6mm) 0.491” (12.6mm) Marking Area (a) Ø 0.429” (11mm) 0.429” (11mm) Engraving must be made on the engraving area within 0.02” (0.5mm) deep. Terminal Blocks Replacing and Marking Plate Removal Remove the lens holder assembly (lens, marking plate and holder) from the operator by holding the color lens recesses with the lens removal tool (Part No.MT-101) and pulling out. Remove marking plate by pushing the color lens from the rear to disengage the latches. Marking plate must be engraved on the side as shown in the figure on the right. Ø 5/8” (16mm) For illuminated pushbuttons: 1. Insert marking plate inside lens in correct direction 2. Press color lens on to lens holder to engage latches. 3. Insert lens holder into housing in correct direction. Do not loosen spring on illuminated pushbutton units (except on pilot light units). The marking plate must be engraved on the front side as shown above. Fitting Grooves Grooves Circuit Breakers Installation Engraving Surface Color Lens Marking Plate 554 Lens Holder www.IDEC.com 1705151131
AL6M-M14P-R 价格&库存
很抱歉,暂时无法提供与“AL6M-M14P-R”相匹配的价格&库存,您可以联系我们找货
AL6M-M14P-R
    • 1+270.15181
    • 25+257.95821
    • 50+251.68174
    库存:1
