8329TCS
High Thermal Conductivity Adhesive
8329TCS is a 2-part, heat-cure, thermally
conductive epoxy adhesive with a 4-hour working
time. It is a dark grey, smooth, thixotropic paste
that cures to form a hard, durable polymer that
is thermally conductive, yet electrically insulating.
This thermal adhesive is used to glue heat
sinks to LEDs, CPUs and other heat-generating
components.
8329TCS has been designed for maximum
thermal conductivity. It is highly viscous and must
be mixed by hand prior to application. For a lower
viscosity, use 8329TFS. For a shorter working
time, use 8329TCM.
Cured Properties
Features & Benefits
• High thermal conductivity
• 1:1 mix ratio
• Provides strong electrical insulation
• High tensile strength
• Bonds well to a wide variety of substances
• Strong resistance to humidity, salt water, mild
bases, and aliphatic hydrocarbons
Resistivity
2 x 1013 Ω·cm
Hardness
62 D
Tensile Strength
11 N/mm2
Compressive Strength
43 N/mm2
Lap Shear (stainless steel)
4.7 N/mm2
(aluminum)
4.4 N/mm2
Glass Transition Temperature (Tg)
8.8 ˚C
CTE Prior Tg
36 ppm/˚C
CTE After Tg
173 ppm/˚C
Thermal Conductivity @ 25 ˚C
1.4 W/(m·K)
Service Temperature Range
-40–150 ˚C
Available Packaging
Cat. No.
Packaging
Net Vol.
Net Wt.
8329TCS-6ML
2 Syringe Kit
6 mL
13.8 g
8329TCS-50ML
2 Jar Kit
50 mL
116 g
Usage Parameters
Working Time
Mix Ratio by Volume
Mix Ratio by Weight
4 h
1:1
0.95:1
Contact Information
MG Chemicals, 1210 Corporate Drive
Burlington, Ontario, Canada L7L 5R6
Email: support@mgchemicals.com
Phone: North America: +(1)800-340-0772
International: +(1) 905-331-1396
Europe:
+(44)1663 362888
Uncured Properties
Mixed Density
Viscosity @ 25 ˚C
ISO 9001:2015 Quality Management System. Burlington, Ontario, Canada SAI Global File: 004008
2.27 g/mL
(A)
970 Pa·s
(B) 2 000 Pa·s
25 May 2023 / Ver. 4.1
1
8329TCS
Application Instructions
Cure Instructions
Read the product SDS and Application Guide for
more detailed instructions before using this product
(downloadable at www.mgchemicals.com).
This product cures only at an elevated temperature,
as per one of these time/temperature options:
Recommended Preparation
Clean the substrate with Isopropyl Alcohol, MG #824,
so the surface is free of oils, dust, and other residues.
Syringe
1. Twist and remove the cap from the syringe. Do not
discard cap.
2. Measure 1 part by volume of A.
3. Measure 1 part by volume of B.
4. Dispense material on a mixing surface or container,
and thoroughly mix parts A and B together.
5. To stop the flow, pull back on the plunger.
6. Clean nozzle to prevent contamination and material
buildup.
7. Replace the cap on the syringe.
Temperature
Time
65 °C
2 hours
80 °C
1 hour
100 °C
20 minutes
Storage and Handling
Store between 16 and 27 ˚C in a dry area, away from
sunlight (see SDS). To maximize shelf life, recap
product firmly when not in use.
Can or Jar
1.
Stir each part individually to re-incorporate
material that may have separated during storage.
2. Measure 0.95 part by weight of A.
3. Measure 1 part by weight of B.
4. Thoroughly mix parts A and B together.
5. Apply adhesive to the application area.
Disclaimer
This information is believed to be accurate. It is
intended for professional end-users who have the
skills required to evaluate and use the data properly.
M.G. Chemicals Ltd. does not guarantee the accuracy
of the data and assumes no liability in connection with
damages incurred while using it.
2
很抱歉,暂时无法提供与“8329TCS-200ML”相匹配的价格&库存,您可以联系我们找货
