388406-000
388406-000
    OTHER
388406-000 数据手册
TITLE SPECIFICATION CONTROL DRAWING Date FOUR CONDUCTOR CABLE, SHIELDED, JACKETED, GENERAL PURPOSE, 600 VOLT 55A1141 1-16-13 Revision B This specification sheet forms a part of the latest issue of Raychem Specification 55A. JACKET - RADIATION-CROSSLINKED, MODIFIED ETFE SHIELD - TIN-COATED COPPER COMPONENT WIRES - 55A0111 CABLE CONSTRUCTION DETAILS JACKET THICKNESS (inches) OUTSIDE DIAMETER (inches) PART NUMBER 1/ CONDUCTOR SIZE (AWG) SHIELD SIZE (AWG) MINIMUM NOMINAL NOMINAL MAXIMUM MAXIMUM WEIGHT (lbs/1000 ft.) 55A1141-30-* 30 38 .006 .008 .091 .104 7.7 55A1141-28-* 28 38 .006 .008 .098 .113 9.3 55A1141-26-* 26 38 .006 .008 .110 .127 12.1 55A1141-24-* 24 38 .006 .008 .123 .141 15.4 55A1141-22-* 22 38 .006 .008 .137 .159 19.7 55A1141-20-* 20 38 .006 .008 .154 .179 27.0 55A1141-18-* 18 38 .006 .008 .178 .208 37.7 55A1141-16-* 16 38 .006 .008 .198 .231 46.4 55A1141-14-* 14 38 .007 .009 .241 .282 69.1 55A1141-12-* 12 38 .007 .009 .284 .334 55A1141-10-* 10 38 .008 .010 .347 .408 154. 55A1141-8-* 8 34 .009 .011 .503 .593 291. 99.6 CABLE RATINGS AND ADDITIONAL REQUIREMENTS TEMPERATURE RATING: 150°C Maximum continuous conductor temperature VOLTAGE RATING: 600 volts (rms) at sea level ACCELERATED AGING: 300 ± 3°C for 7 hours BLOCKING: 200 ± 3°C for 6 hours DIELECTRIC WITHSTAND: 1500 volts (rms), 60 Hz FLAMMABILITY (Procedure 1): 3 seconds (maximum); 3 in. (maximum); no flaming of facial tissue JACKET COLOR: White preferred JACKET ELONGATION AND TENSILE STRENGTH: Elongation, 50% (minimum) Tensile Strength, 5000 lbf/in² (minimum) JACKET FLAWS: Spark Test, 1000 volts (rms) Impulse Dielectric Test, 6.0 kV (peak) LIFE CYCLE: 200 ± 3°C for 168 hours LOW TEMPERATURE-COLD BEND: -65 ± 2°C for 4 hours SHIELD COVERAGE: 85% (minimum) VOLTAGE WITHSTAND (Post Environmental): 1000 volts (rms), 60 Hz, 1 minute PART NUMBER: The “*” in the part numbers above shall be replaced by color code designators with a slash separating the component wire colors and a dash separating the component wire colors from the jacket color. Colors shown do not necessarily reflect the sequence of manufacturing. 1/ Example: AWG 22, black, brown, red and orange component wires; white jacket: 55A1141-22-0/1/2/3-9 NOTE: Nominal values are for information only. Nominal values are not requirements. Users should evaluate the suitability of this product for their application. Specifications are subject to change without notice. Tyco Electronics Corporation also reserves the right to make changes in materials or processing, which do not affect compliance with any specification, without notification to Buyer. 1/ COLORS AND COLOR CODE DESIGNATORS SHALL BE IN ACCORDANCE WITH MIL-STD-681. HOWEVER, DUE TO LENGTH LIMITATIONS OF THE RAYCHEM PART NUMBER, AN ALTERNATIVE COLOR CODE MAY REPLACE MIL-STD-681 COLOR CODE DESIGNATORS. (EXAMPLE: “901/902...” MAY BE REPLACED BY “Axxx”.) OTHER CODES AND SUFFIXES MAY BE ADDED TO THE PART NUMBER AS NECESSARY, TO CAPTURE ANY ADDITIONAL REQUIREMENTS IMPOSED BY THE PURCHASE ORDER. Raychem, TE Connectivity, TE connectivity (logo) and TE (logo) are trademarks. Page 1 of 1 DIMENSIONS ARE IN INCHES, AND UNLESS OTHERWISE DESIGNATED ARE NOMINAL. THIS SPECIFICATION SHEET TAKES PRECEDENCE OVER DOCUMENTS REFERENCED HEREIN. REFERENCED DOCUMENTS SHALL BE OF THE ISSUE IN EFFECT ON DATE OF INVITATION FOR BID. Raychem Wire & Cable 501 Oakside Avenue Redwood City, CA 94063-3800 Phone: 1-800-227-8816 Fax: 1-650-361-6297 © 2005-2013 Tyco Electronics Corporation. All rights reserved.
388406-000 价格&库存
很抱歉,暂时无法提供与“388406-000”相匹配的价格&库存,您可以联系我们找货
