4-1676914-0
4-1676914-0
    TECONNECTIVITY(泰科电子)
4-1676914-0 数据手册
RoHS Ready Passive Components Passive Components Introduction Tyco Electronics is one of the major business units of Tyco International Ltd. (NYSE:TYC, LSE:TYI, BSX:TYC). Headquartered in Harrisburg, Pennsylvania, USA, Tyco Electronics is the world’s largest passive electronic components manufacturer, and a world leader in cutting-edge wireless technologies, fibre optic active components, and complete power systems. The company has facilities located in 51 countries serving customers in the aerospace, automotive, computer, communications, consumer electronics, industrial and power industries. Tyco Electronics provides advanced technology products from over thirty well-known and respected product brands, including Agastat, Alcoswitch, AMP, AMP NETCONNECT, Buchanan, CII, CoEv, Critchley, Elcon, Elo Touch Systems, HTS, M/A-COM, Madison Cable, OEG, Potter & Brumfield, Raychem, Schrack, Simel and TDI Batteries. Tyco Electronics’ product portfolio now includes a comprehensive range of passive components, including surface mount and leaded resistors, trimmers, potentiometers, PTC and NTC surface mount thermistors, as well as a wide range of inductive products covering wirewound, metal film surface mount, ceramic and ferrite bead. range from Tyco Electronics delivers the “Complete Precision Portfolio”. A range of SMD Capacitors, including Multi Layer Ceramic (MLCC), Tantalum and Aluminium Electrolytic completes the Passive Components product portfolio. For all trimming solutions, the Citec brand is the ideal design partner where your circuit requires sealed or unsealed trimmers from just 2mm square. Multiturns for precision trimming are available with 11 or 12 turn setability. Further, Citec offers a prestigious range of potentiometers, from single and multiturn versions with cermet or carbon elements, through to switched options with shafts in either plastic or metal. The Holsworthy range of precision resistors meets the requirement for economically priced components for both industrial and military applications. In SMD and leaded packages, with tolerances down to 0.05% and TCRs as low as 5ppm, the Holsworthy Sigma noise suppression and protection inductor chips from Tyco Electronics can help protect circuits in a variety of ways. The range offers solutions for high power, high speed, low frequency noise impedance as well as temperature responsive resistors in PTC and NTC. Sigma also encompasses a wide range of wound, multilayered and printed inductors in addition to noise reduction bead inductors and through-hole RF chokes. CGS high power and high voltage resistors are rated up to 100W with voltage proof to 50kV and are available in a wide variety of package styles. High power and pulse resistors in the CGS range are capable of dissipating up to 25,000 Watts for applications such as regenerative braking and power supplies. The Neohm range of commodity resistors are available with SMD and Leaded devices. This wide range of products compliments and supports the Passives range available from the Tyco Electronics portfolio. Contents Resistive Products Fixed - Surface Mount Fixed - Leaded Page 3 4-5 Trimmers - Surface Mount 6 Trimmers - Leaded 7 Potentiometers - Leaded 8 Encoders - Leaded 9 Thermistors and Varistors 9 Inductive Products Moulded 10 High Frequency 10 Inductive Products (cont) Page Ferrite Beads 10 Power - Surface Mount - Unshielded 11 Leaded - Unshielded 11 Power - Surface Mount - Shielded 12 Capacitive Products Ceramic - Surface Mount 13 Tantalum - Surface Mount 13 Aluminium Electrolytic - Surface Mount 13 Colour Codes and E-Series Grid 14 Associated Products 15 2 Catalogue No. 1309350 August 2007 Dimensions are shown in mm for reference purposes only. Specifications subject to change. tycoelectronics.com passives.tycoelectronics.com Passive Components Resistive Products, Fixed - Surface Mount Product Type Features Commodity CRG / 3520 0201 to 2512 Package Sizes 0402 to 2512 Package Sizes 1R0 to 10M Value Range 10M to 100G Value Range Tolerances down to 1% and 5% Tolerances down to 2% TCR ±200ppm/°C max. TCR's down to 100ppm/°C 500 Volt Maximum Overload Special Values Possible Product Type Features Fusible FCR Trimmable TCR Commodity MCN 0805 and 1206 Package Sizes 0805 and 2512 Package Sizes 2, 4, or 8 x 0603 Resistors 1R0 to 5IR Value Range 1R0 to 10M Value Range 10R to 1M Value Range 5% Tolerance Trimming Ratios up to 3 Times ±1%, ±2% ±5% Tolerances 2.0W or 2.5W Fusing Power TCR’s down to 100ppm/°C TCR ±200ppm/°C max. 30 Seconds Fusing Time Up to 1W Dissipation Concave or Convex Terminals Ultra Precision RN73 Precision CPF Precision Thick Film CPG Precision MRS Precision SU 0402 to 1210 Package Sizes 5R0 to 1M Value Range 0.01% Tolerance TCR 10ppm/°C max. 0805-E96 Values in Distribution 0402 to 1206 Package Sizes 5R1 to 1M Value Range Tolerances down to 0.1% TCR's down to 25ppm/°C E24 and E96 Value Grid 0603 to 1206 Package Sizes 10R to 4M7 Value Range Tolerances down to 0.5% TCR's down to 50ppm/°C E24 and E96 Value Grid 4 x 0603 Resistors 10R to 330K Value Range Tolerances down to 0.1% TCR's down to 25ppm/°C 1206 Real Estate 0.125W to 0.50W 1R0 - 2M0 Value Range Tolerances down to 0.005% TCR's down to 10ppm/°C Available in E192 Value grid Low Ohmic RL73 Low Ohmic TL / HL Low Ohmic SL Power Wirewound SP Power SM 0402 to 2512 Package Sizes Values down to R10 Tolerances down to 1% TCR 100ppm/°C or 200ppm/°C 2512 E12 Grid in Distribution 0.25W to 2.0W Dissipation R001 to 1R0 Value Range 1% Tolerance Down to TCR +50ppm/oC Non Inductive Foil Element 0.5W& 3.0W Dissipation R01 to R011 Value Range 1% - 5% Tolerance Down to 4.7nH Inductance 4 Package Sizes Product Type Features High Ohmic RH73 0.75W to 3.5W @ 25°C Dissipation 1W to 5W Dissipation R06 to 45K Value Range R10 to 2M Value Range Tolerances down to 0.1% 1% or 5% Tolerances TCR's down to 20ppm/°C 200ppm/°C Wire / 100ppm/°C Film Suited to Pulse Applications True Pick and Place Body Style 3 Catalogue No. 1309350 August 2007 Dimensions are shown in mm for reference purposes only. Specifications subject to change. tycoelectronics.com passives.tycoelectronics.com Passive Components Resistive Products, Fixed - Leaded Product Type Metal Film Precision H4P / H4 / H8 Metal Film Semi Precision R Standard Metal Film LR Precision Wirewound UPW Features 0.25W to 1.0W Dissipation 1R0 to 10M Value Range Tolerances down to 0.05% TCR’s down to 5ppm/°C Released to BS/CECC 0.25W Dissipation 4R02 to 1M Value Range 0.1% to 1% Tolerance TCR’s down to 15ppm/°C E96 Value Grid 0.25W to 0.75W Dissipation R10 to 10M Value Range 1%, 2% or 5% Tolerance TCR’s down to 10ppm/°C Taped Ammo Pack to IEC286-1 0.15W to 0.5W Dissipation R10 to 2M Value Range Tolerances down to 0.005% TCR’s down to 1ppm/°C Low Inductance Carbon Film CFR Metal Oxide RSS / ROX Fusible FRN / SQF / FKN Metal Glaze RGP High Voltage Thick Film HH / HJ Features 0.25W to 2.0W Dissipation 1R0 to 10M Value Range 2% or 5% Tolerance Small Body Sizes Available Taped Ammo Pack to IEC286-1 0.5W to 7.0W Dissipation 1R0 to 200K Value Range ±5% Tolerance Axial Leaded Ammo Packed or Reeled 1W to 10W Dissipation R10 to 150R Value Range Axial or Radial Leaded 5% Tolerance TCR 300ppm/°C max. 0.25W to 4.0W Dissipation 1M to 10G Value Range 5% or 10% Tolerance ±0.005%/V Voltage Coefficient TCR 350ppm/°C max. 0.5W to 6.0W Dissipation 100K to 50G Value Range Tolerances down to 0.5% TCR’s down to 25ppm/°C Axial Leaded Product Type High Voltage Thick Film High Voltage Thick Film High Power Thick Film HB HVR BDS High Power Thick Film MPC Thin Film Power MPR Features Dissipation up to 2W @ 70°C 1K to 1G Value Range Tolerance down to 1% Up to 15kV Voltage Rating Axial / Radial Options 3W to 10W Dissipation 1R0 to 200K Value Range 1% or 5% Tolerance TCR ±100ppm/°C max. Radial Leads 20W Dissipation (Heatsink) R22 to 51K Value Range TO220 Package 1% (E24), 5% (E12) Tolerances TCR down to ±50ppm/°C Product Type Up to 100 W Dissipation (in oil) 2K to 1G Value Range Tolerances down to 1% Up to 50KV Voltage Rating Various Mounting Styles 100W to 600W Dissipation R20 to 1M Value Range 5% or 10% Tolerance TCR 150ppm/°C max. Customised as Required 4 Catalogue No. 1309350 August 2007 Dimensions are shown in mm for reference purposes only. Specifications subject to change. tycoelectronics.com passives.tycoelectronics.com Passive Components Resistive Products, Fixed - Leaded Product Type Features Power Wirewound SBC / SBCHE Power Wirewound SQP / SQM / SQZ Power Wirewound C3A / C7 / C10 / C14 Power Wirewound ER Power Wirewound ES 3W to 40W Dissipation R10 to 22K Value Range 10% or 5% Tolerance Radial and Axial Styles 2000V Dielectric Strength 2W to 25W Dissipation R10 to 150K Value Range 5% Tolerance Radial and Axial Styles Wire or Power Oxide 3W to 14W Dissipation R10 to 100K Value Range 10%, 5% or 2% Tolerance Axial Leaded 3W and 7W Ammo Packed 3W to 14W Dissipation R01 to 100K Value Range Tolerances down to 0.5% Axial and Radial Types Custom Designs as Required 0.5W to 10W Dissipation R10 to 3K3 Value Range 5% Tolerance Super Small Size available Taped and Ammo Packed Power Wirewound HS / THS Power Wirewound FC Power Wirewound ME Power Wirewound TG Power Wirewound TT / TK 5W to 300W Dissipation R01 to 82K Value Range Tolerances down to 0.25% High Voltage Versions Low Inductance Styles 2W to 8W Dissipation R20 to 22K Value Range 5% or 10% Tolerance Radial Leads Two Height Profiles Up to 500W Dissipation R02 to 22K Value Range 5% or 10% Tolerance Fixed or Adjustable Range of Terminal Style Up to 293W Dissipation R24 to 100K Value Range 5% or 10% Tolerance Glass Bond Coated 6000J Pulse Energy 10W to 1000W Dissipation R20 to 70K Value Range 5% or 10% Tolerance Fixed or Adjustable Range of Mounting Styles Foil Low Ohmic SBL Wire Shunt OS / OP Zerohm Link ZR Carbon Moulded CBT Ceramic Composition CCR 4W and 5W Dissipation R005 to R051 Value Range 1% or 5% Tolerance 2KV Dielectric Strength Essentially Non Inductive Values from R003 to R150 2 Different Styles Current Rating to 21A 5% Tolerance as Standard Custom Designs Available Product Type Features Product Type Features Two Case Sizes 0.25W, 0.5W Dissipation 0.5, 1.0, 2.0W Power Dissipation < 2 milliohm Resistance 2R2 to 22M Value range Up to 20kV Impulse Withstand Dielectric Strength - 500V E24 - 5% E12 - 10% Tolerance Tolerance 10% > 10G Insulation Resistance Up to 750V Overload Up to 400V Working Voltage Taped Ammo Pack to IEC286-1 Low Inductance 3R3 to 390K Value Range 5 Catalogue No. 1309350 August 2007 Dimensions are shown in mm for reference purposes only. Specifications subject to change. tycoelectronics.com passives.tycoelectronics.com Passive Components Resistive Products, Trimmers - Surface Mount Product Type Features Open Frame 3121 Board Area - 2.2mm x 2.75mm Board Area - 3.75mm x 3mm Height 1.8mm Height 1.85mm Max. 200R to 1M Value Range 100R to 1M Value Range 25% Tolerance Auto Adjust Version 50V DC Operating Voltage 50V DC Operating Voltage Product Type Features Open Frame 3135 Open Frame 3142 Open Frame 3150 / 3165 3mm Square Nominal Height 1.2mm Max. 100R to 1M Value Range Delta Terminals Integrated End Stop 4mm Square Nominal Height 2.4mm 100R to 1M Value Range Delta Terminals 50V DC Operating Voltage 4mm Square Nominal Lightweight - 0.2 Grams 100R to 1M Value Range In-line or Delta Terminals Underside Adjust Version Semi Sealed 3103 Semi Sealed 3203 Semi Sealed 3204 Board Area - 3.6mm x 3.1mm Height < 1.8mm 500R to 1M Value Range 0.05W Dissipation @ 50°C Sealed for Processing Board Area - 3.4mm x 3.4mm Height < 2.1mm 100R to 1M Value Range 0.05W Dissipation Sealed for Processing Board Area - 4mm x 4.5mm Height 2.4mm 100R to 1M Value Range 0.1W Dissipation Sealed for Processing Sealed 3212 Sealed 3213 Sealed 3315 Multiturn 3240 Multiturn 3270 Board Area - 2.4mm x 2.8mm Height 1.7mm 100R to 1M0 Value Range 20% Tolerance O-ring Sealed Board Area - 3.4mm x 3.4mm Height 2.0mm 10R to 1M0 Value Range 20% Tolerance O-ring Sealed Board Area - 5mm x 5mm Height 2.5mm 10R to 2M Value Range 20% Tolerance O-ring Sealed 4mm Square Nominal Top and Side Adjust Styles 10R to 2M Value Range 10% Tolerance 11 Turns 6mm Square Nominal Top and Side Adjust Styles 10R to 1M Value Range 10% Tolerance 12 Turns Product Type Features Open Frame 3130 6 Catalogue No. 1309350 August 2007 Dimensions are shown in mm for reference purposes only. Specifications subject to change. tycoelectronics.com passives.tycoelectronics.com Passive Components Resistive Products, Trimmers - Leaded Product Type Features Economy CT6 Economy 416 Economy 409 6mm Single Turn 200R to 1M Value Range 0.1W Dissipation Top and Side Adjust Versions Resin Moulded Technology 6mm Single Turn 100R to 1M Value Range 0.2W Dissipation Top and Side Adjust Versions Dust and Splash Proof 10mm Single Turn 100R to 1M Value Range 0.5W Dissipation 100 Cycles Maximum Dust and Splash Proof Professional 470 Professional 4265 Professional 4275 Product Type Features Product Type Features 6mm Single Turn 10R to 1M Value Range 10% Tolerance 0.5W Dissipation Fully Sealed 6mm Single Turn Sealed 6mm Single Turn Sealed 10R to 2M Value Range 10R to 2M Value Range 0.5W Dissipation 0.5W Dissipation 20% Tolerance Standard 10% Tolerance Standard Three Pin Layouts/Taped Versions Three Pin Layouts/Taped Versions Multiturn 433 Multiturn 4270 Multiturn 4290 19mm Multiturn Sealed 10R to 2M Value Range 0.75W Dissipation 15 Electrical Turns Panel Mount Available 6mm Multiturn Sealed 50R to 2M Value Range 0.25W Dissipation 12 Electrical Turns Wide Variety of Styles 10mm Multiturn Sealed 50R to 2M Value Range 0.5W Dissipation 25 Electrical Turns Wide Variety of Styles Economy CB10 Economy CB15 / CT15 Carbon Element Carbon Element 100R to 10M Value Range 100R to 4M7 Value Range 0.15W Log /0.25W Lin Dissipation 0.15W Log /0.25W Lin Dissipation Long Life Version (>10,000 cycles) Long Life (>10,000 cycles) Enclosed Package Plug in Shaft Available Professional 4295 10mm Single Turn Sealed 10R to 2M Value Range 0.5W Dissipation TCR ±100ppm/°C Five Pin Layouts 7 Catalogue No. 1309350 August 2007 Dimensions are shown in mm for reference purposes only. Specifications subject to change. tycoelectronics.com passives.tycoelectronics.com Passive Components Resistive Products, Potentiometers - Leaded Product Type Features Economy PC610 9mm Square Pluggable 20mm/16mm Round Body Polymer Element Printed Carbon Element 500R to 500K Value Range 1K to 1M Value Range (Linear) 0.05W Dissipation 0.25W Log/0.4W Lin Dissipation Non Linear Laws Available Non Linear Laws Available 10,000 Operations minimum Dual Gang & Switched Styles Product Type Features Economy 51 / 54 / 56 16mm Package Polymer Element 470R to 2M2 Value Range 0.25W Dissipation Non Linear Laws Available Switched Version Economy 17P Economy CP16 16mm Square all Plastic Body 16mm Square Package Polymer Thick Film Element Polymer Thick Film Element 1K to 1M Value Range (Lin) 100R to 4M7 Value Range 0.25W Dissipation 0.1W Log/0.2W Lin Dissipation Non Linear Laws Available Non Linear Laws Available Multigangs, Switches Available Switches Available Professional CS9 Professional TW Professional 5930 / 5940 Professional LC Professional MC 9mm Square Body Polymer Element 5K to 250K Value Range 0.05W Dissipation Linear or Logarithmic Laws Multigangs, Switches Available 265° Travel Wirewound Element 5R to 22K Value Range 1 Watt @ 40°C TCR - 100 ppm 5000 Operations 10 Turn Multiturn Wirewound Element 200R to 100K Value Range 2W Dissipation
4-1676914-0 价格&库存
很抱歉,暂时无法提供与“4-1676914-0”相匹配的价格&库存,您可以联系我们找货
  • 2000+2.367132000+0.30736
  • 10000+2.1321610000+0.27685
