1415899-5
1415899-5
    OTHER
1415899-5 数据手册
CERTIFICATE NO.: CQC12002066685 Valid from: Feb.23,2022 Valid until:long-term NAME AND REGISTERED Tyco Electronics Austria GmbH ADDRESS OF THE APPLICANT Schrackstrasse 1 3830 Waidhofen / Thaya Austria NAME AND REGISTERED Tyco Electronics Austria GmbH ADDRESS OF THE Schrackstrasse 1 3830 Waidhofen / Thaya Austria MANUFACTURER NAME AND LOCATION Tyco Electronics Austria GmbH OF THE FACTORY Schrackstrasse 1 3830 Waidhofen / Thaya Austria PRODUCT NAME, MODEL Relay RZ series,RZH9 series Coil:3VDC、5VDC、6VDC、9VDC、12VDC、15VDC、18VDC、24VDC、28VDC、 34VDC、36VDC、48VDC;0.40W~0.43W;Mechanical endurance:200000cycles;Ambinet temperature:-40℃~85℃(RZ0 series)、-40℃~105℃(RZH series,RZH9 series);RTⅡ。 RZH9 and RZ.(0,H).(1,2,3,H)-1.(A;C).(3,4) series description as follow: Contacts load:12A 250V,12A 24VDC,16A 250VAC; Electrical endurance:20000cycles(250VAC),1000cycles(24VDC). AND SPECIFICATION THE STANDARDS AND GB/T 21711.1-2008 TECHNICAL REQUIREMENTS FOR THE PRODUCTS TYPE OF CERTIFICATION Type Testing of Product + Initial Factory Inspection + Follow up Factory Inspection SCHEMES This is to certify that the above mentioned product(s) complies with the requirements of certification rules of CQC11-462155-2010. Date of original issued: Jan.09,2012 The validity of the certificate is subject to positive result of the regular follow up inspection by issuing certification body. The certificate information is available through the QR code below or CNCA’s website: www.cnca.gov.cn SIGNATURE: CERTIFICATE NO.:CQC12002066685 page 1 of 2 paper: This certificate and attachments shall be used at the same time, and the verification instructions can be found in the main certificate. CERTIFICATE NO.:CQC12002066685 page 2 of 2 paper: This certificate and attachments shall be used at the same time, and the verification instructions can be found in the main certificate. RZH9 及 RZ.(0,H).(1,2,3,H)-1.(A;C).(3,4)系列参数如下: 触点负载:12A 250VAC,12A 24VDC,16A 250VAC; 电气寿命:20000 周期(250VAC),1000 周期 (24VDC) 证书编号:CQC12002066685 发证日期:2022 年 02 月 23 日 有效期至:长期有效 委托人名称 泰科电子奥地利股份有限公司 及注册地址 Schrackstrasse 1 3830 Waidhofen / Thaya Austria 制造商名称 泰科电子奥地利股份有限公司 及注册地址 Schrackstrasse 1 3830 Waidhofen / Thaya Austria 生产企业名称 泰科电子奥地利股份有限公司 及生产地址 Schrackstrasse 1 3830 Waidhofen / Thaya Austria 产品名称和系列、 规格、型号 继电器 RZ 系列,RZH9 系列 线圈:3VDC、5VDC、6VDC、9VDC、12VDC、15VDC、18VDC、24VDC、 28VDC、34VDC、36VDC、48VDC;0.40W~0.43W;机械寿命:200000 周期;环境温度:-40℃~ 85℃(RZ0 型)、-40℃~105℃(RZH 型,RZH9 系列);RTⅡ. 产品标准和技术要求 GB/T 21711.1-2008 认证模式 产品型式试验+初次工厂检查+获证后监督 上述产品符合 CQC11-462155-2010 认证规则的要求,特发此证。 本证书为变更证书,证书首次颁发日期:2012 年 01 月 09 日 本证书的有效性依据发证机构的定期监督获得保持。 可通过扫描下方二维码或登录国家认监委网站(www.cnca.gov.cn)查验证书信息 签发: 证书编号:CQC12002066685 第1页 共2页 本证书及附件应同时使用,信息查验说明见证书页 纸号: 证书编号:CQC12002066685 第2页 共2页 本证书及附件应同时使用,信息查验说明见证书页 纸号: RZH9 及 RZ.(0,H).(1,2,3,H)-1.(A;C).(3,4)系列参数如下: 触点负载:12A 250VAC,12A 24VDC,16A 250VAC; 电气寿命:20000 周期(250VAC),1000 周 期(24VDC)
1415899-5 价格&库存
很抱歉,暂时无法提供与“1415899-5”相匹配的价格&库存,您可以联系我们找货
