XN3700
XN3700
    XDM(芯达茂)
    SSOP-28
    XN3700
XN3700 数据手册
XN3700 8Bit Single-Chip Microcontroller 1. FEATURES Embedded MCU Motor Controller (MOC)  MCS®-51 Compatible  Space Vector PWM (SVPWM)  1T 8052 Central Processing Unit  Supports Sin-Wave and Square-Wave Solutions  4.5V to 5.5V Operation Range  Supports Hall Latch and Hall Element Input  4 Level Priority Interrupt  Supports Digital OCP and Analog OCP (Over  14 Interrupt Sources ━ Two External Interrupts (INT0N, INT1N) Current Protection)  Programmable Deadband  Programmable Angle Shift Control (0° to 58° in ━ 8KB Flash Program Memory 32steps) ━ 256 x 8-bit IRAM  Memory Size: ━ 256 x 8-bit XRAM  Up to 25 General-Purpose Input / Output (GPIO) Pins  Three 16-bit Timer/Counters  Watchdog (WD) Timer  1 Channel 16-bit Capture  8 Channels 10-bit Analog-to-Digital Converter (ADC)  Full Duplex UART Serial Channel  Fast Multiplication-Division Unit (MDU): 16*16, 32/16, 16/16,32-bit L/R shifting and 32-bit normalization 2019.05 ver1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 2. Block Diagram Figure 2.1 HALL LATCH Figure 2.2 HALL ELEMENT 2019.05 ver1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 3. XN3700 Series Product Selection Guide I/O Part No UART PWM ADC [*1] XN3700 25 1 6 8 HALL Ext. Ext. Customer [*2] Crystal Reset Code 3L/3E √ √ √ A10 Package LQFP-32 TQPF-32 -xxxx0A A1/7 XN3700 25 1 8 3L/3E √ √ x A100AA LQFP-32 TQPF-32 1/7 A10 -xxxxA D4 XN3700 A100A D4 XN3700 A10 -xxxxA D2 XN3700 8KB Flash, 256B IRAM, 258B XRA M XN3700 22 1 8 3L √ √ √ SSOP-28 22 1 8 3L √ √ x SSOP-28 15 0 2 3L / 3E x x √ SSOP-20 15 0 2 3L / 3E x x x SSOP-20 15 1 3 3L x x √ QFN-20 15 1 3 3L x x x QFN-20 A100A D2 XN3700 A10 -xxxxAB 2 XN3700 A100 -AB2 Note: 1. xxxx is customer code number. 2. 3L / 3E : support 3 hall latch or 3 hall element. 3L : support 3 hall latch. 2019.05 ver1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 4. Ordering Information 4.1 Including Customer Code Code 1 8 9 A B Year 2018 2019 2020 2021 Code 2 1 Month Jan. 2 Feb. 3 Mar. 4 Apr. ● ● ● G 2026 H 2027 I 2028 J 2029 9 Sep. A Oct. B Nov. C Dec. 5. Pin Assignments 5.1 SSOP-28(AD4) 2019.05 ver1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 5.2 SSOP-20(AD2) 5.3 LQFP-32 7x7mm(AA1) / TQFP-32 7x7mm(AA7) 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 6. Pin Definitions SSOP-28 SSOP-20 L/TQFP32 7x7 Name Pin # Type Description 8 --- 1 RSTN I System Reset. 25 --- 2 CH7 I Analog Input Ch7. CAP2 I Capture Input 2 P2.7 I/O Bit 7 of Port 2. CH6 I Analog Input Ch6. P2.6 I/O Bit 6 of Port 2. CH5 I Analog Input Ch5. P2.5 I/O Bit 5 of Port 2. CH4 I Analog Input Ch4. P2.4 I/O Bit 4 of Port 2. CH3 I Analog Input Ch3. P2.3 I/O Bit 3 of Port 2. RX I Serial Data Transmit 24 23 22 9 13 --- --- --- --- --- 3 4 5 6 7 (UART) 14 --- 8 P3.0 I/O Bit 0 of Port 3. TX O Serial Data Receive (UART) P3.1 15 11 9 I/O SDAICE Bit 1 of Port 3. For ICE (In Circuit Emulator). 16 12 10 SCLICE For ICE (In Circuit Emulator). 17 --- 11 XTALI I Crystal input pin. Connect the crystal 12MHz between this pin and XTALO and a 22pF capacitor to VSS. T1 I TIMER1 External Input. 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 18 --- 12 P3.5 I/O Bit 5 of Port 3. XTALO O Crystal output pin. Connect the crystal 12MHz between this pin and XTALI and a 22pF capacitor to VSS. T0 I TIMER0 External Input. P3.4 --- --- 13 NC 19 13 14 VDD5 I/O Bit 4 of Port 3. No connect. Power 5.0V Voltage Input. A 0.1uF and 10uF (minimum) capacitor should be connected between this pin and VSS. 20 14 15 V25 O 2.5V Voltage Output. A 0.1uF and 1uF (minimum) capacitor should be connected between this pin and VSS. 21 15 16 VSS Ground Power Ground. 12 16 17 CH0 I Analog Input Ch0. CAP1 I Capture Input 1 GPWM O General PWM output. P1.6 I/O Bit 6 of Port 1. CH1 I Analog Input Ch1. INT0N I External Interrupt 0. 11 17 18 Low level trigger or falling edge trigger. 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 10 --- 19 P3.2 I/O Bit 2 of Port 3. CH2 I Analog Input Ch2. INT1N I External Interrupt 1. Low level trigger or falling edge trigger. --- 10 20 P3.3 I/O Bit 3 of Port 3. HWN I Hall Element negative input. (HALL W) 26 9 21 P0.6 I/O Bit 6 of Port 0. HWP I Hall Latch input or HALL Element positive input. (HALL W) --- 8 22 P0.2 I/O Bit 2 of Port 0. HVN I Hall Element negative input. (HALL V) 27 7 23 P0.5 I/O Bit 5 of Port 0. HVP I Hall Latch input or HALL Element positive input. (HALL V) --- 6 24 P0.1 I/O Bit 1 of Port 0. HUN I Hall Element negative input. (HALL U) 28 5 25 P0.4 I/O Bit 4 of Port 0. HUP I Hall Latch input or HALL Element positive input.(HALL U) 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 1 18 26 P0.0 I/O Bit 0 of Port 0. OCPN I Over current protection. Active-low. 2 19 27 P0.3 I/O Bit 3 of Port 0. U O PWM output. High-side PWM of phase U. 3 20 28 P1.0 I/O Bit 0 of Port 1. X O PWM output. Low-side PWM of phase U. 4 1 29 P1.1 I/O Bit 1 of Port 1. V O PWM output. High-side PWM of phase V. 5 2 30 P1.2 I/O Bit 2 of Port 1. Y O PWM output. Low-side PWM of phase V. 6 3 31 P1.3 I/O Bit 3 of Port 1. W O PWM output. High-side PWM of phase W. 7 4 32 P1.4 I/O Bit 4 of Port 1. z O PWM output. Low-side PWM of phase W. P1.5 --- --- 2019.05 v1.0 Xindamao Micro-Electronics I/O NC www.xindamao.com.cn Bit 5 of Port 1. No connect. Datasheet XN3700 8Bit Single-Chip Microcontroller 7. Absolute Maximum Ratings Supply Voltage............................ ............ ............ ................................VSS-0.3V to VSS+6.0V Input Voltage............................ ............ ............ ................................... VSS -0.3V to VDD+0.3V Storage Temperature.................... ...... ...... ...... ...... ...... ...................................-50°C to 150°C Operating Temperature..................... ...... ...... ...... ...... ...... ..............................-40°C to 125°C IOH Total........................ ...... ...... ...... ...... ...... ...... .........................................................-80mA IOL Total................... ...... ...... ...... ...... ...... ...... ...............................................................80mA ΘJA Thermal Resistance, Junction-to-ambient (SSOP-28L).... ...... ...... ...... ...... .........82°C/W ΘJA Thermal Resistance, Junction-to-ambient (SSOP-20L).. ...... ...... ...... ...... ......114.5°C/W ΘJA Thermal Resistance, Junction-to-ambient (LQFP7x7-32) ..... ............ ..... ...... ......80℃/W Total Power Dissipation.................................... ...... ...... ...... ...... ...... ...... ....................500mW Electrostatic Discharge Capability – Human Body Mode......... ...... ...... ...... ...... ............2000V Electrostatic Discharge Capability – Machine Mode...... ...... ...... ...... ...... ........................200V 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 8. D.C. Characteristics Symbol Parameter Ta=25℃ Test Conditions VDD Min. Typ. Max. Unit Conditions VDD Operating Voltage ― fsys=48MHz 4.5 5.0 5.5 V V25 V25 Output Range ― Load Current < 10mA 2.35 2.50 2.65 V IDD Operating Current 5V No load, fsys=48Mhz, ADC ― 9 12 mA off, MOC off VIL Input Low Voltage ― ― 0 ― 0.3 VDD V ― ― 0.7 ― VDD V for I/O Ports. VIH Input High Voltage for I/O Ports. VDD VLVD LVD Voltage Level ― ― VOL Output Low Voltage 5V IOL=5mA ― ― 0.5 V 5V IOH=-3.8mA 4.5 ― ― V 5V ― 10 35 50 KΩ 5V ― 10 35 50 KΩ for I/O Ports. VOH Output High Voltage for I/O Ports. RPU Pull-up Resistance for I/O Ports RPD Pull-down Resistance for I/O Ports 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 9. A.C. Characteristics Ta=25℃ Symbol fSYS Parameter System Test Conditions Timer Input Pin Typ. Max. Unit VDD Conditions 4.5V~5.5V Ta=-40℃ to 125℃ TBD 48.0 TBD MHz Ta=-20℃ to 85℃ TBD 48.0 TBD MHz Ta=25℃ -1% 48.0 +1% MHz ― ― ― ― 4 fsys ― ― 1 5 10 tsys ― ― 120 240 480 us Frequency fTIMER Min. Frequency tINT Interrupt Pulse Width tLVD Low Voltage Width to interrupt tV25 V25 Stable Time ― ― 60 120 240 us tRSDT System Reset ― ― 25 50 100 ms Delay Time (Power On Reset) 10. A/D Converter Characteristics 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller Ta=25℃ Symbol IAD Parameter Additional Power Test Conditions Min. Typ. Max. Unit VDD Conditions 5V ― ― 4.5 ― mA ― Load Current < ― ― 4 uA Consumption if A/D Converter is Used IADSTB A/D Converter Standby Current tADCCLK tCONV tSHCLK tSH DNL INL GERR 10mA A/D Converter Clock ― 4MHz ― 0.25 ― us Time ― 2MHz ― 0.5 ― us A/D Conversion Time ― 4MHz ― 3.25 ― us ― 2MHz ― 6.5 ― us A/D Sample and Hold ― 1MHz ― 1 ― us Clock Time ― 500KHz ― 2 ― us ― 400KHz ― 2.5 ― us ― 333KHz ― 3 ― us A/D Sample and Hold ― 1MHz 1 ― 2 us Time ― 500KHz 2 ― 4 us ― 400KHz 2.5 ― 5 us ― 333KHz 3 ― 6 us Differential 4.5V No load, -1 ― +3 LSB Non-linearity 5.5V tCONV=2.5us -1 ― +3 LSB 4.5V No load, -1 ― +3 LSB 5.5V tCONV=5us -1 ― +3 LSB 4.5V No load, -4 ― +4 LSB 5.5V tCONV=2.5us -4 ― +4 LSB 4.5V No load, -4 ― +4 LSB 5.5V tCONV=5us -4 ― +4 LSB ― ― -10 ― +10 LSB Integral Non-linearity Gain Error 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 11. Special Function Registers (SFR) 11.1 SFRs Memory Map F8 8 9 A B C D E F PINCONG1 PINCONG PINCONG PINCONG4 PINCONG5 PINCONG6 RSTS TAKEY FF 2 3 F0 B PINSET1 PINSET2 PINSET3 PINSET4 PINSET5 PINSET6 PINSET7 F7 E8 ASUD1_1 ASUD1_2 ASUD1_3 ASUD1_4 ASUD2_1 ASUD2_2 ASUD2_ ASUD2_4 EF 3 E0 ACC AS_MD_C MD0 MD1 MD2 MD3 MD4 MD5 E7 SVPWMA MD_CONT ASUR1 ASUR2 ASUR3 ASUR4 DF ONT D8 CAPCONT VRHALL MPFT D0 PSW PFCON ADCCONT ADCSTR ----- ADCD1 ADCD2 SYNC D7 C8 T2CON CAPT_H CAPT_L CAPH_H CAPH_L ----- ----- ----- CF C0 IRCON1 SVPWMA ----- SVPWMAM SVPWMAM ----- ----- PINCONG C7 PL PH GPWMCO GPWMMAX GPWMMAX NT L H MPWMCO MPWMCO MPWMINV TL2 TH2 NT1 NT2 IP0 MPWMDY MPWMDYV ----- VL H MCONT2 MPWMMAX NG B8 B0 A8 A0 98 IEN1 P3 IEN0 P2 SCON IP1 OCPCONT SBUF SRELL 7 ----- BF WDTC WDTK B7 MPWMDYW MPWMD ----- AF L YWH MPWMMAX MPWMDYU MPWMD MPWMD A7 L H L YUH B SRELH HALLDBT MCONT1 AOCPCO ----- 9F ROTORS ROTORS 97 PEEDL PEEDH GPWMDYL GPWMD YH NT 90 P1 HALLSET1 HALLSET2 HALLSET3 HALLST ----- 88 TCON TMOD TL0 TL1 TH0 TH1 AUX AS 8F 80 P0 SP DP0L DP0H DP1L DP1H RCON PCON 87 0 1 2 3 4 5 6 7 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 11.2 XN3700 SFRs and Reset Value SYMBOL DESCRIPTION DIRECT RESET ADDRESS VALUE ACC Accumulator E0H 00H ADCCONT ADC Control Register D2H 80H ADCD1 ADC Data Register 1 D5H 00H ADCD2 ADC Data Register 2 D6H 00H ADCSTR ADC Start Convert and Setting Register D3H 00H AOCPCONT Analog OCP Control Register 9EH 0FH AS Angle Shift Control Register 8FH 00H AS_MD_CONT ASU and MDU Control Register E1H 10H ASUD1_1 ASU Data 1 byte 1 E8H 00H ASUD1_2 ASU Data 1 byte 2 E9H 00H ASUD1_3 ASU Data 1 byte 3 EAH 00H ASUD1_4 ASU Data 1 byte 4 EBH 00H ASUD2_1 ASU Data 2 byte 1 ECH 00H ASUD2_2 ASU Data 2 byte 2 EDH 00H ASUD2_3 ASU Data 2 byte 3 EEH 00H ASUD2_4 ASU Data 2 byte 4 EFH 00H ASUR1 ASU Result Register 1 DCH 00H ASUR2 ASU Result Register 2 DDH 00H ASUR3 ASU Result Register 3 DEH 00H ASUR4 ASU Result Register 4 DFH 00H AUX Auxiliary 8EH 11H B B Register F0H 00H CAPCONT Capture Control Register D8H 03H CAPH_H Capture High-level Count High CBH 00H CAPH_L Capture High-level Count Low CCH 00H CAPT_H Capture Total Count High C9H 00H CAPT_L Capture Total Count Low CAH 00H DPTR0: Data Pointer (2 bytes) DP0H Data Pointer 0 High 83H 00H DP0L Data Pointer 0 Low 82H 00H DPTR1: Data Pointer 1 (2 bytes) DP1H Data Pointer 1 High 85H 00H DP1L Data Pointer 1 Low 84H 00H GPWMCONT General PWM Control Register BAH 00H 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller GPWMDYH General PWM Duty Register High BEH FFH GPWMDYL General PWM Duty Register Low BDH FFH GPWMMAXH General PWM Max Register High BCH 00H GPWMMAXL General PWM Max Register Low BBH 02H HALLDBT Hall De-bounce Time Register 9CH 0EH HALLSET1 Hall Setting Register 1 91H 45H HALLSET2 Hall Setting Register 2 92H 26H HALLSET3 Hall Setting Register 3 93H 13H HALLST Hall Status Register 94H XXH IEN0 Interrupt Enable Register 0 A8H 00H IEN1 Interrupt Enable Register 1 B8H 00H IP0 Interrupt Priority Register 0 A9H 00H IP1 Interrupt Priority Register 1 B9H 00H IRCON1 Interrupt Request Register 1 C0H 00H MCONT1 Motor Control Register 1 9DH X011 0000B MCONT2 Motor Control Register 2 A2H 00H MD_CONT MDU Control Register DBH 00H MD0 Multiplication Division Register 0 E2H 00H MD1 Multiplication Division Register 1 E3H 00H MD2 Multiplication Division Register 2 E4H 00H MD3 Multiplication Division Register 3 E5H 00H MD4 Multiplication Division Register 4 E6H 00H MD5 Multiplication Division Register 5 E7H 00H MPWMCONT1 MPWM Control Register 1 B1H 00H MPWMCONT2 MPWM Control Register 2 B2H 00H MPWMDB Motor PWM Deadband Register A7H 00H MPWMDYUH Motor PWM Duty Register U High (Phase U) A6H 07H MPWMDYUL Motor PWM Duty Register U Low (Phase U) A5H FFH MPWMDYVH Motor PWM Duty Register V High (Phase V) ABH 07H MPWMDYVL Motor PWM Duty Register V Low (Phase V) AAH FFH MPWMDYWH Motor PWM Duty Register W High (Phase W) AEH 07H MPWMDYWL Motor PWM Duty Register W Low (Phase W) ADH FFH MPWMINV MPWM Inverse Selection Register B3H 00H MPWMMAXH Motor PWM Max Register High A4H 00H MPWMMAXL Motor PWM Max Register Low A3H 02H 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller OCPCONT OCP Control Register A1H 04H P0 Port 0 80H FFH P1 Port 1 90H FFH P2 Port 2 A0H FFH P3 Port 3 B0H FFH PCON Power Control Register 87H 00H PFCON Peripheral Frequency Control Register D1H 00H PINCONG1 Pin Configure Register 1 F8H AAH PINCONG2 Pin Configure Register 2 F9H AAH PINCONG3 Pin Configure Register 3 FAH A0H PINCONG4 Pin Configure Register 4 FBH AAH PINCONG5 Pin Configure Register 5 FCH AAH PINCONG6 Pin Configure Register 6 FDH A0H PINCONG7 Pin Configure Register 7 C7H 20H PINSET1 Pin I/O Setting Register 1 F1H AAH PINSET2 Pin I/O Setting Register 2 F2H AAH PINSET3 Pin I/O Setting Register 3 F3H 0AH PINSET4 Pin I/O Setting Register 4 F4H 00H PINSET5 Pin I/O Setting Register 5 F5H 80H PINSET6 Pin I/O Setting Register 6 F6H 2AH PINSET7 Pin I/O Setting Register 7 F7H FFH PSW Program Status Word Register D0H 00H RCON Internal RAM Control Register 86H F0H ROTORSPEE Rotor Speed Count Register High 97H FFH Rotor Speed Count Register Low 96H FFH RSTS Reset Source Register FEH 0AH SBUF Serial Port Data Buffer 99H 00H SCON Serial Port Control Register 98H 00H SP Stack Pointer 81H 07H SRELH Serial Port Reload Register High 9BH 00H SRELL Serial Port Reload Register Low 9AH 00H SVPWMAMPF SVPWM Amplitude Fine-Tune Register DAH 00H SVPWM Amplitude Register High C4H 00H DH ROTORSPEE DL T SVPWMAMPH 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller SVPWMAMPL SVPWM Amplitude Register Low C3H 00H SVPWMANG SVPWM Angle Register C1H 00H SYNC MOC Sync Register D7H 00H T2CON Timer2 Control Register C8H 00H TAKEY Time Access Key Register FFH 00H TCON Timer 0/1 Control Register 88H 00H TH0 Timer0 High byte 8CH 00H TH1 Timer1 High byte 8DH 00H TH2 Timer2 High byte B5H 00H TL0 Timer0 Low byte 8AH 00H TL1 Timer1 Low byte 8BH 00H TL2 Timer2 Low byte B4H 00H TMOD Timer 0/1 Mode Register 89H 00H VRHALL Virtual Hall Register D9H 05H WDTC Watchdog Timer Control Register B6H 04H WDTK Watchdog Timer Refresh Key B7H 00H 12. Memory The XN3700 memory structure follows the general 8052 structure. There are three memory areas: Program Memory (Flash), External Data Memory (XRAM) and Internal Data Memory (IRAM). In addition, XN3700 integrates 8Kbytes Flash, 256bytes IRAM and 256bytes XRAM. 12.1. Program Memory The XN3700 contains 8Kbytes of on-chip Flash memory for program storage. 12.2. Data Memory The XN3700 contains 256bytes of general internal data memory (IRAM) and 256bytes of external data memory (XRAM). 12.2.1 Data Memory (IRAM)(00H~FFH) The lower 128 bytes of IRAM may be accessed through both direct and indirect addressing. The upper 128 bytes of IRAM and the 128 bytes of SFR registers share the same address space. The upper 128 bytes of data memory may only be accessed using indirect addressing. The SFR registers can only be accessed through direct addressing. The lowest 32 bytes (00H -1FH) of data memory are grouped into 4 banks of 8 registers each. The RS0 and RS1 bits (PSW.3 and PSW.4) select which register bank is in use. Instructions using register addressing will only access the currently specified bank. 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 12.2.2 Data Memory (XRAM)(F000H~F0FFH) External addresses F000H to F0FFh contain the on-chip expanded SRAM. This memory can be accessed via external direct addressing mode (with MOVX instructions). The address space of instruction MOVX @Ri,A (i=0,1) is determined by RCON [7:0] of SFR 86H RCON (internal RAM control register). The default setting of RCON [7:0] is F0h (page0). One page of XRAM is 256 bytes. 13. Instruction Set The XN3700 is fully binary compatible with the MCS-51 instruction set. Arithmetic Description Bytes Cycles Hex Code ADD A,Rn Add register to accumulator 1 1 0x28-0x2F ADD A,direct Add directly addressed data to accumulator 2 2 0x25 ADD A,@Ri Add indirectly addressed data to accumulator 1 2 0x26-0x27 ADD A,#data Add immediate data to accumulator 2 2 0x24 ADDC A,Rn Add register to accumulator with carry 1 1 0x38-0x3F operations 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller ADDC A,direct Add directly addressed data to accumulator 2 2 0x35 1 2 0x36-0x37 with carry ADDC A,@Ri Add indirectly addressed data to accumulator with carry ADDC A,#data Add immediate data to accumulator with carry 2 2 0x34 SUBB A,Rn Subtract register from accumulator with 1 1 0x98-0x9F 2 2 0x95 1 2 0x96-0x97 2 2 0x94 borrow SUBB A,direct Subtract directly addressed data from accumulator with borrow SUBB A,@Ri Subtract indirectly addressed data from accumulator with borrow SUBB A,#data Subtract immediate data from accumulator with borrow INC A Increment accumulator 1 1 0x04 INC Rn Increment register 1 2 0x08-0x0F INC direct Increment directly addressed location 2 3 0x05 INC @Ri Increment indirectly addressed location 1 3 0x06-0x07 INC DPTR Increment data pointer 1 1 0xA3 DEC A Decrement accumulator 1 1 0x14 DEC Rn Decrement register 1 2 0x18-0x1F DEC direct Decrement directly addressed location 2 3 0x15 DEC @Ri Decrement indirectly addressed location 1 3 0x16-0x17 MUL AB Multiply A and B 1 5 0xA4 DIV Divide A by B 1 5 0x84 DA A Decimally adjust accumulator 1 1 0xD4 Logicoperations Description Bytes Cycles Hex Code ANL A,Rn AND register to accumulator 1 1 0x58-0x5F ANL A,direct AND directly addressed data to accumulator 2 2 0x55 ANL A,@Ri AND indirectly addressed data to accumulator 1 2 0x56-0x57 ANL A,#data AND immediate data to accumulator 2 2 0x54 ANL direct,A AND accumulator to directly addressed 2 3 0x52 3 4 0x53 location ANL direct,#data AND immediate data to directly addressed location ORL A,Rn OR register to accumulator 1 1 0x48-0x4F ORL A,direct OR directly addressed data to accumulator 2 2 0x45 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller ORL A,@Ri OR indirectly addressed data to accumulator 1 2 0x46-0x47 ORL A,#data OR immediate data to accumulator 2 2 0x44 ORL direct,A OR accumulator to directly addressed location 2 3 0x42 ORL direct,#data OR immediate data to directly addressed 3 4 0x43 location XRL A,Rn Exclusive OR register to accumulator 1 1 0x68-0x6F XRL A,direct Exclusive OR directly addressed data to 2 2 0x65 1 2 0x66-0x67 accumulator XRL A,@Ri Exclusive OR indirectly addressed data to accumulator XRL A,#data Exclusive OR immediate data to accumulator 2 2 0x64 XRL direct,A Exclusive OR accumulator to directly 2 3 0x62 3 4 0x63 addressed location XRL direct,#data Exclusive OR immediate data to directly addressed location CLR A Clear accumulator 1 1 0xE4 CPL A Complement accumulator 1 1 0xF4 RL A Rotate accumulator left 1 1 0x23 RLC A Rotate accumulator left through carry 1 1 0x33 RR A Rotate accumulator right 1 1 0x03 RRC A Rotate accumulator right through carry 1 1 0x13 SWAP A Swap nibbles within the accumulator 1 1 0xC4 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller Data transfer Description Bytes Cycles Hex Code MOV A,Rn Move register to accumulator 1 1 0xE8-0xEF MOV A,direct Move directly addressed data to 2 2 0xE5 1 2 0xE6-0xE7 operations accumulator MOV A,@Ri Move indirectly addressed data to accumulator MOV A,#data Move immediate data to accumulator 2 2 0x74 MOV Rn,A Move accumulator to register 1 2 0xF8-0xFF MOV Rn,direct Move directly addressed data to register 2 4 0xA8-0xAF MOV Rn,#data Move immediate data to register 2 2 0x78-0x7F MOV direct,A Move accumulator to direct 2 3 0xF5 MOV direct,Rn Move register to direct 2 3 0x88-0x8F MOV direct1,direct2 Move directly addressed data to directly 3 4 0x85 2 4 0x86-0x87 3 3 0x75 1 3 0xF6-0xF7 2 5 0xA6-0xA7 2 3 0x76-0x77 addressed location MOV direct,@Ri Move indirectly addressed data to directly addressed location MOV direct,#data Move immediate data to directly addressed location MOV @Ri,A Move accumulator to indirectly addressed location MOV @Ri,direct Move directly addressed data to indirectly addressed location MOV @Ri,#data Move immediate data to in directly addressed location MOV DPTR,#data16 Load data pointer with a 16-bit immediate 3 3 0x90 MOVC A,@A+DPTR Load accumulator with a code byte 1 3 0x93 1 3 0x83 1 3 0xE2-0xE3 1 3 0xE0 1 4 0xF2-0xF3 relative to DPTR MOVC A,@A+PC Load accumulator with a code byte relative to PC MOVX A,@Ri Move external RAM (8-bit addr.) to accumulator MOVX A,@DPTR Move external RAM (16-bit addr.) to accumulator MOVX @Ri,A Move accumulator to external RAM (8-bit addr.) 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller MOVX @DPTR,A Move accumulator to external RAM (16-bit 1 4 0xF0 addr.) PUSH direct Push directly addressed data onto stack 2 4 0xC0 POP direct Pop directly addressed location from 2 3 0xD0 stack XCH A,Rn Exchange register with accumulator 1 2 0xC8-0xCF XCH A,direct Exchange directly addressed location with 2 3 0xC5 accumulator XCH A,@Ri Exchange indirect RAM with accumulator 1 3 0xC6-0xC7 XCHD A,@Ri Exchange low-order nibbles of indirect 1 3 0xD6-0xD7 and accumulator Program branches Description Bytes Cycles Hex Code ACALL addr11 Absolute subroutine call 2 6 xxx10001b LCALL addr16 Long subroutine call 3 6 0x12 RET Return from subroutine 1 4 0x22 RETI Return from interrupt 1 4 0x32 AJMP addr11 Absolute jump 2 3 xxx00001b LJMP addr16 Long jump 3 4 0x02 SJMP rel Short jump (relative address) 2 3 0x80 JMP @A+DPTR Jump indirect relative to the DPTR 1 2 0x73 JZ rel Jump if accumulator is zero 2 3 0x60 JNZ rel Jump if accumulator is not zero 2 3 0x70 JC rel Jump if carry flag is set 2 3 0x40 JNC Jump if carry flag is not set 2 3 0x50 JB bit,rel Jump if directly addressed bit is set 3 4 0x20 JNB bit,rel Jump if directly addressed bit is not set 3 4 0x30 JBC bit,rel Jump if directly addressed bit is set and 3 4 0x10 3 4 0xB5 3 4 0xB4 3 4 0xB8-0xBF 3 4 0xB6-0xB7 clear bit CJNE A,direct,rel Compare directly addressed data to accumulator and jump if not equal CJNE A,#data,rel Compare immediate data to accumulator and jump if not equal CJNE Rn,#data,rel Compare immediate data to register and jump if not equal CJNE @Ri,#data,rel Compare immed. to ind. and jump if not 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller equal DJNZ Rn,rel Decrement register and jump if not zero 2 3 0xD8-0xDF DJNZ direct,rel Decrement directly addressed location 3 4 0xD5 and jump if not zero NOP No operation 1 1 0 Boolean Description Bytes Cycles Hex Code CLR C Clear carry flag 1 1 0xC3 CLR bit Clear directly addressed bit 2 3 0xC2 SETB C Set carry flag 1 1 0xD3 SETB bit Set directly addressed bit 2 3 0xD2 CPL C Complement carry flag 1 1 0xB3 CPL bit Complement directly addressed bit 2 3 0xB2 ANL C,bit AND directly addressed bit to carry flag 2 2 0x82 ANL C,/bit AND complement of directly addressed bit 2 2 0xB0 mainpulation to carry ORL C,bit OR directly addressed bit to carry flag 2 2 0x72 ORL C,/bit OR complement of directly addressed bit 2 2 0xA0 to carry MOV C,bit Move directly addressed bit to carry flag 2 2 0xA2 MOV bit,C Move carry flag to directly addressed bit 2 3 0x92 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 14. MCU 14.1 8051 Engine SFR Description address Reset value ACC Accumulator E0H 00H B B Register F0H 00H PSW Program Status Word Register D0H 00H SP Stack Pointer 81H 07H DP0H Data Pointer 0 High 83H 00H DP0L Data Pointer 0 Low 82H 00H DP1H Data Pointer 1 High 85H 00H DP1L Data Pointer 1 Low 84H 00H AUX Auxiliary 8EH 11H RCON Internal RAM Control Register 86H F0H 14.1.1 ACC (Accumulator) The most important of all special function registers, that‟s the first comment about Accumulator which is also known as ACC or A. The Accumulator(sometimes referred to as Register A also) holds the result of most of arithmetic and logic operations. 14.1.2 B (B Register) The B register is used during multiplying and division instructions. It can also be used as a scratch-pad register to hold temporary data. 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 14.1.3 PSW (Program Status Word Register) The PSW register contains status bits that reflect the current state of the CPU.Note that the Parity bit can only be modified by hardware upon the state of ACC register. The state of RS1and RS0bits selects the working register bank as follows: RS1 RS0 Selected Register Bank Location 0 0 Bank 0 00H –07H 0 1 Bank 1 08H –0FH 1 0 Bank 2 10H –17H 1 1 Bank 3 18H –1FH 14.1.4 SP (Stack Pointer) This register points to the top of stack in internal data memory space. It is used to store the return address of program before executing interrupt routine or subprograms. The SP is incremented before executing PUSH or CALL instruction and it is decremented after executing POP or RET(I) instruction (it always points the top of stack). A reset initializes the stack pointer to location 0x07. Therefore, the first value pushed on the stack is placed at location 0x08. 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 14.1.5 DP0 (Data Pointer 0) These registers are intended to hold 16-bit address in the indirect addressing mode used by MOVX (move external memory), MOVC (move program memory) or JMP (computed branch) instructions. They may be manipulated as16-bit register or as two separate 8-bit registers. DP0H holds higher byte and DP0L holds lower byte of indirect address. It is generally used to access external code or data space, e.g.:   MOVC A,@A+DPTR (code space) MOV A,@DPTR (data space) 14.1.6 DP1 (Data Pointer 1) The dual data pointer accelerates the movement of block data. The standard DPTR is a 16-bit register that is used to address external memory, or peripherals. The standard data pointer is called DPTR0 and the second data pointer is called DPTR1. The data pointer select bit chooses the active pointer. The data pointer select bit (DPS) is located in the LSB of AUX register(AUX.1). The user switches between DPTR0 and DPTR1 by toggling the DPS bit. All DPTR-related instructions use the currently selected DPTR for any activity. 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 14.1.7 AUX (Auxiliary Register) 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 14.1.8 RCON (Internal RAM Control Register) 256 bytes of on-chip expanded RAM are provided and can be accessed by external memory addressing method only (instruction MOVX). The address space of instruction MOVX @Ri,A (i= 0,1) is determined by RCON [7:0] of RCON. The default setting of RCON [7:0] is F0H. 14.2 GPIO Four I/O ports are available: Port0, Port1, Port2, and Port3. All 25 port pins on XN3700 can configure to one of four modes : quasi-bidirectional (standard 8051 port outputs), push-pull output, open drain output, or input-only. All port pins default to input-only mode after reset.Two configuration registers (PINSETx, PINCONFGx) for each port select the output mode for each port pin. SFR Description address Reset value P0 Port 0 80H FFH P1 Port 1 90H FFH P2 Port 2 A0H FFH P3 Port 3 B0H FFH PINCONG1 Pin Configure Register 1 F8H AAH PINCONG2 Pin Configure Register 2 F9H AAH PINCONG3 Pin Configure Register 3 FAH A0H PINCONG4 Pin Configure Register 4 FBH AAH PINCONG5 Pin Configure Register 5 FCH AAH PINCONG6 Pin Configure Register 6 FDH A0H PINCONG7 Pin Configure Register 7 C7H 20H PINSET1 Pin I/O Setting Register 1 F1H AAH PINSET2 Pin I/O Setting Register 2 F2H AAH PINSET3 Pin I/O Setting Register 3 F3H 0AH PINSET4 Pin I/O Setting Register 4 F4H 00H PINSET5 Pin I/O Setting Register 5 F5H 80H PINSET6 Pin I/O Setting Register 6 F6H 2AH PINSET7 Pin I/O Setting Register 7 F7H FFH 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 14.2.1 Port 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 14.2.2 PINCONG (Pin Configure Register) 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 14.2.3 PINSET (Pin I/O Setting Register) 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 14.3 Clock Structure The clock source of the device may be either external, or internal. The external crystal (12MHz) is connect to pins XTALIand XTALO. The internal clock source (on-chip oscillator) is run at 12MHz. The choice of internal, or external, clock source is setting by Writer. 14.4 Timer The XN3700 has three 16-bit timer/counter registers: Timer0, Timer1 and Timer2. All can be configured for counter, or timer, operations.In addition to the “timer” or “counter” selection, Timer0 and Timer1 have four operating modes from which to select which are selected by bit-pairs (M1, M0) in TMOD. Modes 0, 1,and 2 are the same for both timer/counters. Mode 3 is different. Two Special Function registers (TMOD and TCON) are used to select the appropriate mode. 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller SFR Description address Reset value PFCON Peripheral Frequency control Register D1H 00H TMOD Timer 0/1 Mode Register 89H 00H TCON Timer 0/1 Control Register 88H 00H T2CON Timer2 Control Register C8H 00H TH0 Timer0 High byte 8CH 00H TL0 Timer0 Low byte 8AH 00H TH1 Timer1 High byte 8DH 00H TL1 Timer1 Low byte 8BH 00H TH2 Timer2 High byte B5H 00H TL2 Timer2 Low byte B4H 00H 14.4.1 PFCON (Peripheral Frequency Control Register) 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 14.4.2 TMOD (Timer 0/1 Mode Register) TMOD register is used in configuration of MCU Timer0 and Timer1. 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 14.4.3 TCON (Timer 0/1 Control Register) TCON register is used to control operation of these modules. XN3700 includes two external digital interrupt sources INT0N and INT1N), with dedicated interrupt sources. INT0N and INT1N are configurable as falling edge or low level. The IT0 and IT1 bits in TCON select levelor edge-sensitive. IE0 and IE1 in the TCON register serve as the interrupt-pending flags for the INT0N and INT1N external interrupts, respectively. 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller The TF0, TF1 (Timer0 and Timer1 overflow flags), IE0 and IE1 (External interrupt 0 and 1 flags) will be automatically cleared by hardware when the corresponding service routine is called. 14.4.4 T2CON (Timer2 Control Register) T2CON is used to control Timer2 run/stop, mode, prescaler. 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 14.4.5 Timer0 Mode 0 14.4.6 Timer0 Mode 1 14.4.7 Timer0 Mode 2 14.4.8 Timer0 Mode 3 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 14.4.9 Timer1 Mode 0 14.4.10 Timer1 Mode 1 14.4.11 Timer1 Mode 2 14.4.12 Timer2 Mode 0 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 14.4.13 Timer2 Mode 1 14.4.14 Timer2 Mode 2 14.4.15 Timer2 Mode 3 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 14.5 Watchdog Timer The Watchdog Timer (WDT) is a 8-bit free-running counter that generates a reset signal or interrupt (WDTC.6) if it overflows. It can help the application software to recover from an abnormal condition. The WDT is independent from Timer0, Timer1, or Timer2. The F_WDT is 375KHz, it is from on-chip RC oscillator. Figure 12.5.1 WDT block diagram SFR Description address Reset value RSTS Reset Source Register FEH 0AH TAKEY Time Access Key Register FFH 00H WDTC Watchdog Timer Control B6H 04H B7H 00H Register WDTK Watchdog Timer Refresh Key 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 14.5.1 WDTC (Watchdog Timer Control Register) 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 14.5.2 TAKEY (Time Access Key Register) 14.5.3 WDTK (Watchdog Timer Refresh Key) For example, enable the watchdog with a time-out reset period of 5.461ms. Following write sequence: MOV TAKEY, #55h MOV TAKEY, #AAh MOV TAKEY, #5Ah ; WDTC write is available. MOV WDTC, #23h ; WDTM [3:0] = 0011b. WDTE =1 to enable the WDT. MOV WDTK, #55h ; Refresh WDT. 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 14.6 Serial Port (UART) The Serial Port provides a flexible full-duplex synchronous/asynchronous receiver/transmitter, called UART. The communication rate can be set by configuring the baud rate in SFRs. The two serial buffers consist of two separate registers, a transmit buffer and a receive buffer. Writing data to the SFR SBUF, transfers the data to the serial output buffer and starts the transmission. Reading from the SBUF, reads data from the serial receive buffer. The serial port can simultaneously transmit and receive data. It can also buffer 1 byte at receive, which prevents the receive data from being lost if the CPU reads the second byte before the transmission of the first byte is completed. SFR Description address Reset value AUX Auxiliary 8EH 11H PFCON Peripheral Frequency Control D1H 00H Register SCON Serial Port Control Register 98H 00H SBUF Serial Port Data Buffer 99H 00H SRELH Serial Port Reload Register High 9BH 00H SRELL Serial Port Reload Register Low 9AH 00H 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 14.6.1 SCON (Serial Port Control Register) The SCON register controls the function of Serial Port (UART). 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller Serial Port working in modes 1 or mode 3: When BRS = 0 (AUX.2) TIPS[1:0] = 00b TIPS[1:0] = 01b TIPS[1:0] = 10b When BRS = 1 (AUX.2) SRELPS[1:0] = 00b SRELPS [1:0] = 01b SRELPS [1:0] = 10b SRELPS [1:0] = 11b 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 14.6.2 SBUF (Serial Port Data Buffer) Writing data to this register sets data in serial output buffer and starts the transmission through Serial Port. Reading from the SBUF, reads data from the serial receive buffer. 14.6.3 SREL (Serial Port Reload Register) Serial Port Reload Register is used for Serial Port baud rate generation. Only 10 bits are used, where 8 bits from the SRELL as lower bits and 2 bits from the SRELH (SRELH.1, SRELH.0) as higher bits. 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 14.7 Power Management The Power Control Register (PCON) is used to control the XN3700 STOP and IDLE power management modes. 14.7.1 STOP MODE Setting the STOP Mode Select bit (PCON.1) causes the controller core to enter STOP mode as soon as the instruction that sets the bit completes execution. In STOP mode the CPU, GPIO, UART, and Timers are stopped, but the ADC, MOC, and WDT is still work. STOP mode can terminate by an internal or external reset. On reset, the device performs the normal reset sequence and begins program execution at address 0x0000. The assertion of an enabled interrupt will cause the STOP Mode Selection bit (PCON.1) to be cleared and the CPU to resume operation. 14.7.2 IDLE MODE Setting the IDLE Mode Select bit (PCON.0) causes the hardware to halt the CPU and enter IDLE mode as soon as the instruction that sets the bitcompletes execution. In IDLE mode only the CPU is stop. All internal registers and memory maintain their original data. IDLE mode can terminate by an internal or external reset. On reset, the device performs the normal reset sequence and begins program execution at address 0x0000. The assertion of an enabled interrupt will cause the IDLE Mode Selection bit (PCON.0) to be cleared and the CPU to resume operation. 14.8 Reset The reset logic is used to place the device into a known state. XN3700 provides Power-on Reset flag, External Reset RSTN flag and Watchdog timer Reset flag to monitor reset status. The source of the reset can be monitor. 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 14.8.1 RSTS (Reset Source Register) 14.9 Interrupt Controller The ISR - Interrupt Service Routine unit, is a subcomponent responsible for interrupt handling. It receives up to 14 interrupt requests. Each interrupt source has its own request flag that is located in devices which is a source of interrupt. No interrupt request flags are located directly in ISR. All interrupts are requested by high level on correspondent inputs to ISR. Each of the interrupt sources can be individually enabled or disabled by corresponding enable flag in IEN0, IEN1 SFR registers.. Additionally all interrupts can be globally enabled or disabled by the ―EA flag in the IEN0 SFR. All interrupt sources are divided into 6 interrupts groups. Each of the interrupt groups can have one of four interrupt priority levels assigned. The interrupt priority level is defined by flags located in the IP0 and IP1 SFR registers. Interrupt Number Interrupt Vector Address Interrupt Request Flags (use Keil C Tool) 0 0003H IE0 –External interrupt 0 1 000BH TF0 –Timer0 interrupt 2 0013H IE1 –External interrupt1 3 001BH TF1 –Timer1 interrupt 4 0023H SPIF(TI, RI)–Serial port interrupt 5 002BH TF2 –Timer2 interrupt 6 0033H ----- 7 003BH ----- 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 8 0043H OCPSIF –OCP Short interrupt 9 004BH HALLIF –HALL interrupt 10 0053H MPWMMINIF–MPWM MIN interrupt 11 005BH MPWMMAXIF–MPWM MAX interrupt 12 0063H GPWMMAXIF –GPWM MAX interrupt 13 006BH LVDIF –Low voltage detect interrupt 14 0073H WDTIF –Watchdog timer interrupt 15 007BH OCPLIF –OCP Limit interrupt Table14.9.1 Interrupt vectors Group priority Highest Lowest Interrupt Highest priority Lowest priority Group in group in group Group0 LVDIF IE0 ----- Group1 WDTIF TF0 ----- Group2 OCPSIF HALLIF IE1 Group3 MPWMMINIF MPWMMAXIF TF1 Group4 GPWMMAXIF SPIF(TI, RI) ----- Group5 OCPLIF 2TF2 ----- Table14.9.2 Interrupt Priority Groups SFR Description address Reset value IEN0 Interrupt Enable Register 0 A8H 00H IEN1 Interrupt Enable Register 1 B8H 00H IRCON1 Interrupt Request Register 1 C0H 00H IP0 Interrupt Priority Register 0 A9H 00H IP1 Interrupt Priority Register 1 B9H 00H 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 14.9.1 IEN0 (Interrupt Enable Register 0) 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 14.9.2 IEN1 (Interrupt Enable Register 1) 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 14.9.3 IRCON1 (Interrupt Request Register 1) 14.9.4 IP (Interrupt Priority Register) The 14 interrupt sources are grouped into 6 priority groups. For each of the groups, one of four priority levels can be selected. It is achieved by setting appropriate values in IP0 and IP1 registers. The contents of the Interrupt Priority Registers define the priority levels for each interrupt source according to the tables below. 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller Level Priority GxIP1 GxIP0 Level 0 Lowest 0 0 Level 1 0 1 Level 2 1 0 1 1 Level 3 Highest 15.10-bit Analog-to-Digital Converter (ADC) The XN3700 provides eight channels 10-bit ADC. The result of the conversion is provided at ADCD [9:0]. SFR Description address Reset value ADCCONT ADC Control Register D2H 80H ADCSTR ADC Start Convert and Setting Register D3H 00H ADCD1 ADC Data Register 1 D5H 00H ADCD2 ADC Data Register 2 D6H 00H 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller Figure15.1 ADC conversion timing 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 15.1 ADCCONT (ADC Control Register) 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 15.2 ADCSTR (ADC Start Convert and Setting Register) 15.3 ADCD1 (ADC Data Register 1) 15.4 ADCD2 (ADC Data Register 2) 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 16 General PWM (GPWM) XN3700 have one 16-bit general PWM output (PINSET6.4 = „1‟) and six 11-bit PWM (compensation with Deadband) for Motor Controller. GPWM is count up and down timer. (fixed) SFR Description address Reset value GPWMCONT General PWM Control Register BAH 00H GPWMMAXH General PWM Max Register High BCH 00H GPWMMAXL General PWM Max Register Low BBH 02H GPWMDYH General PWM Duty Register High BEH FFH GPWMDYL General PWM Duty Register Low BDH FFH 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 16.1 GPWMCONT (General PWM Control Register) 16.2 GPWMMAX (General PWM Max Register) 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 16.3 GPWMDY (General PWM Duty Register) 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 17. Capture SFR Description address Reset value CAPCONT Capture Control Register D8H 03H CAPH_H Capture High-level Count High CBH 00H CAPH_L Capture High-level Count Low CCH 00H CAPT_H Capture Total Count High C9H 00H CAPT_L Capture Total Count Low CAH 00H 17.1 CAPCONT (Capture Control Register) 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 17.2 CAPT (Capture Total Count) 17.3 CAPH (Capture High-level Count) 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 18. Addition and Subtraction Unit (ASU) ASU provides 32-bit Addition and Subtraction calculation. SFR Description address Reset value AS_MD_CONT ASU and MDU Control Register E1H 10H ASUD1_1 ASU Data 1 byte 1 E8H 00H ASUD1_2 ASU Data 1 byte 2 E9H 00H ASUD1_3 ASU Data 1 byte 3 EAH 00H ASUD1_4 ASU Data 1 byte 4 EBH 00H ASUD2_1 ASU Data 2 byte 1 ECH 00H ASUD2_2 ASU Data 2 byte 2 EDH 00H ASUD2_3 ASU Data 2 byte 3 EEH 00H ASUD2_4 ASU Data 2 byte 4 EFH 00H ASUR1 ASU Result Register 1 DCH 00H ASUR2 ASU Result Register 2 DDH 00H ASUR3 ASU Result Register 3 DEH 00H ASUR4 ASU Result Register 4 DFH 00H 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 18.1 AS_MD_CONT (ASU and MDU Control Register) 18.2 ASUD1 (ASU Data 1) 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 18.3 ASUD2 (ASU Data 2) 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 18.4 ASUR (ASU Result Register) 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 19. Multiplication and Division Unit (MDU) The MDU is an on-chip arithmetic co-processor which enables the XN3700 to perform additional extended arithmetic operations. All operations are singed/unsigned integer operations. Operands and results are stored in MD0 – MD5 registers. The module is controlled by the AS_MD_CONT and MD_CONT register. Any calculation of the MDU overwrites its operands. The MDU support five operations: Division 32-bit/16-bit, Division 16-bit/16-bit,Multiplication, Shift and Normalize. SFR Description address Reset value AS_MD_CONT ASU and MDU Control Register E1H 10H MD_CONT MDU Control Register DBH 00H MD0 Multiplication Division Register 0 E2H 00H MD1 Multiplication Division Register 1 E3H 00H MD2 Multiplication Division Register 2 E4H 00H MD3 Multiplication Division Register 3 E5H 00H MD4 Multiplication Division Register 4 E6H 00H MD5 Multiplication Division Register 5 E7H 00H 19.1 AS_MD_CONT (ASU and MDU Control Register) 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 19.2 MD_CONT (MDU Control Register) 19.2.1 MDEF The MDEF error flag indicates an improperly performed operation (when one of the arithmetic operations has been restarted or interrupted by a new operation). The error flag mechanism is automatically enabled with the first write operation to MD0 and disabled with the final read instruction from MD3 (multiplication or shift/norm) or MD5 (division) in phase three. The error flag is set when: There is a write access to MDx registers (any of MD0 - MD5 and MD_CONT) during phase two of MDU operation (restart or calculations interrupting) There is a read access to one of MDx registers during phase two of MDU operation when the error flag mechanism is enabled. In such condition error flag is set but the calculation is not interrupted. The error flag is reset only after read access to MD_CONT register. The error flag is read only. 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 19.2.2 MDOV The MDOV overflow flag is set when one of the following conditions occurs: Division by zero Multiplication with a result greater than FFFFH Start of normalizing if the („MD3.7‟ = „1‟) most significant bit of MD3 is set Any operation of the MDU that does not match the above conditions clears the overflow flag. Note that the overflow flag is exclusively controlled by hardware. lt cannot be written. 19.3 MD0 – MD5 (Multiplication Division Register) 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 19.4 MDU Operation Description The operation of the MDU consists of three phases: 19.4.1 Loading the MDx registers The type of calculation the MDU has to perform is selected by the order in which the MDx registers are written to. A write to MD0 is the first transfer to be done in any case. Next writes must be done as shown in the table below to determine the MDU operation. The last write will start the selected operation. 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 19.4.2 Executing calculation During the calculation period, the MDU works in parallel to the CPU. When the calculation is complete, the hardware will set the MDUF bit to one (MDUF = „1‟). The flag will be cleared at the next calculation. The following table provides the execution time for each mathematical operation. 19.4.3 Reading the result from the MDx registers The Read-out sequence of the first “MDx” registers is not critical. 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 19.4.4 Shifting In shift operation, 32-bit integer variable stored in MD0 to MD3 registers (the latter contains the most significant byte) is shifted left or right by a specified number of bits. The SLR bit (MD_CONT.5) defines the shift direction, and bits SC[4:0] (MD_CONT.4 – MD_CONT.0) specifies the shift count (which must not be 0). During shift operation, zeroes come into the left end of MD3 for shifting right or right end of the MD0 for shifting left. 19.4.5 Normalizing All leading zeroes of 32-bit integer variable stored in MD0 to MD3 registers, the latter contains the most significant byte are removed by shift left operations. The whole operation is completed when the MSB (most significant bit) of MD3 register contains a „1„. After normalizing, bits SC[4:0] (MD_CONT.4 – MD_CONT.0) contain the number of shift left operations, which were done. 20. Motor Controller (MOC) 20.1 HALL Interface SFR Description address Reset value HALLDBT Hall De-bounce Time Register 9CH 0EH HALLSET1 Hall Setting Register 1 91H 45H HALLSET2 Hall Setting Register 2 92H 26H HALLSET3 Hall Setting Register 3 93H 13H HALLST Hall Status Register 94H XXH ROTORSPEEDH Rotor Speed Count Register 97H FFH 96H FFH D9H 05H High ROTORSPEEDL Rotor Speed Count Register Low VRHALL Virtual Hall Register 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 20.1.1 HALLDBT (Hall De-bounce Time Register) 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 20.1.2 HALLSET (Hall Setting Register 1, 2, 3) HALLSET define forward direction HALL sequence. 1 Hall alignment select HALLALS = 0 (MCONT1) ○ Line Voltage (Line to Line) sequence is Vuv leads Vvw by 120 degrees and Vvw leads Vwu by 120 degrees. (Forward direction define in XN3700) Hall signal is alignment with Line Voltage. 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 2 Hall alignment select HALLALS = 1 (MCONT1) ○ Phase Voltage sequence is Vu leads Vv by 120 degrees and Vv leads Vw by 120 degrees. (Forward direction define in XN3700) Hall signal is alignment with Phase Voltage. 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 20.1.3 HALLST (Hall Status Register) 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 20.1.4 ROTORSPEED (Rotor Speed Count Register) ROTORSPEED is a 16-bit counter (counter is limit at FFFFH). Clock source is depends on HCKS (MCONT1 reg.). The counter input is HALL U. 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 20.1.5 VRHALL(Virtual Hall Register) 20.2 Motor PWM Engine MPWM is count up and down timer. (fixed) SFR Description address MCONT1 Motor Control Register 1 9DH Reset value X011 0000B MCONT2 Motor Control Register 2 A2H 00H MPWMMAXH Motor PWM Max Register High A4H 00H MPWMMAXL Motor PWM Max Register Low A3H 02H MPWMDYUH Motor PWM Duty Register U High A6H 07H A5H FFH ABH 07H AAH FFH AEH 07H ADH FFH (Phase U) MPWMDYUL Motor PWM Duty Register U Low (Phase U) MPWMDYVH Motor PWM Duty Register V High (Phase V) MPWMDYVL Motor PWM Duty Register V Low (Phase V) MPWMDYWH Motor PWM Duty Register W High (Phase W) MPWMDYWL Motor PWM Duty Register W Low (Phase W) MPWMDB Motor PWM Deadband Register A7H 00H MPWMCONT1 MPWM Control Register 1 B1H 00H MPWMCONT2 MPWM Control Register 2 B2H 00H MPWMINV MPWM Inverse Selection Register B3H 00H 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 20.2.1 MCONT1 (Motor Control Register 1) 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 20.2.2 MCONT2 (Motor Control Register 2) 20.2.3 MPWMMAX (Motor PWM Max Register) MPWM is 11-bit timer. The frequency of MPWM timer is 48MHz. (fixed) MPWM is count up and down timer. (fixed) 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 20.2.4 MPWMDY (Motor PWM Duty Register) MPWM is 11-bit timer. MPWMDYU is phase U PWM duty. MPWMDYV is phase V PWM duty. MPWMDYW is phase W PWM duty. 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 20.2.5 MPWMDB (Motor PWM Deadband Register) Compensation PWM output with Deadband is use to prevent short-though between high-side and low-side power device. The frequency of MPWMDB is 48MHz. (fixed) 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 20.2.6 MPWMCONT1 (MPWM Control Register 1) Motor High-side PWM output mode select : 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 20.2.7 MPWMCONT2 (MPWM Control Register 2) Motor Low-side PWM output mode select : 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 20.2.8 MPWMINV (MPWM Inverse Selection Register) Motor six PWM output Inverse select : 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 20.3 Space Vector PWM (SVPWM) SFR Description address Reset value SVPWMAMPH SVPWM Amplitude Register High C4H 00H SVPWMAMPL SVPWM Amplitude Register Low C3H 00H SVPWMAMPFT SVPWM Amplitude Fine-Tune DAH 00H Register SVPWMANG SVPWM Angle Register C1H 00H AS Angle Shift Control Register 8FH 00H 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 20.3.1 SVPWMAMP (SVPWM Amplitude Register) SVPWMAMP is control by user. 20.3.2 SVPWMAMPFT (SVPWM Amplitude Fine-Tune Register) 20.3.3 SVPWMANG (SVPWM Angle Register) 1.875∘/bit 0∘~ 358.125∘= 0 ~ 191(SVPWMANG) When MWPMA = „1‟ (auto mode), SVPWMANG is control by MOC. When MWPMA = „0‟, SVPWMANG is control by user. 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 20.3.4 AS (Angle Shift Control Register) AS is used to compensate phase lag between current and voltage 1.875∘/bit When MWPMA = „1‟ (auto mode), AS is active. Control by user. 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 20.4 Over Current Protect (OCP) 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 20.5 SYNC MOC behavior is synchronized with MPWM, many MOC SFRs have shadow register that is used to update these SFRs at the same time with SYNC register. Write SYNC any value will synchronization update these SFRs at the same time. Shadow register : (need SYNC) HALLSET1 HALLSET2 HALLSET3 AS MPWMMAXH, MPWMMAXL MPWMDYUH, MPWMDYUL MPWMDYVH, MPWMDYVL MPWMDYWH, MPWMDYWL MPWMDB MPWMINV MPWMCONT1 MPWMCONT2 GPWMMAX GPWMDY GPWMOCNT.GPMS, GPWMOCNT.GPCT, GPWMOCNT.GPCKS SVPWMAMP 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 21. Package Information 21.1 SSOP-28 150mil(AD4) Outline Dimensions 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 21.2 SSOP-20 150mil(AD2) Outline Dimensions 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet XN3700 8Bit Single-Chip Microcontroller 21.3 LQFP-32 7x7mm(AA1) Outline Dimensions 2019.05 v1.0 Xindamao Micro-Electronics www.xindamao.com.cn Datasheet
XN3700 价格&库存
很抱歉,暂时无法提供与“XN3700”相匹配的价格&库存,您可以联系我们找货
