UM213EEASR
UM213EEASR
    UNION(英联)
    SSOP-28
    UM207/208/211/213是增强型收发器,适用于RS-232和V.28串行设备。它们具有非常低的功耗和+5V单电源操作。
UM213EEASR 数据手册
UM207/208/211/213 Low Power, High ESD +5V RS-232 Transceivers UM207EESO/UM207EEAO/UM207EEAOR/UM207EEUO UM208EESO/UM208EEAO/UM208EEAOR/UM208EEUO UM211EESS/UM211EEAS/UM211EEASR/UM211EEUS UM213EESS/UM213EEAS/UM213EEASR/UM213EEUS General Description The UM207/208/211/213 are enhanced transceivers intended for use in RS-232 and V.28 serial communication and are particularly suited for those applications where ±12V is not available. These devices feature very low power consumption and +5V single supply operation making them ideal for space-constrained applications. With integrated charge pump circuitry and small 0.1µF charge pump capacitors, these devices can fully meet RS-232 voltage levels. A slow rate limited transmitter circuit improves data integrity. The receiver features hysteresis to greatly improve noise rejection. The UM211 and UM213 feature a low power shutdown mode, which reduces power supply drain to 1µA. The UM213 includes two receivers that remain active during shutdown to monitor for signal activity. The drivers maintain the ±5V EIA/TIA-232E output signal levels at data rates in excess of 250kbps when loaded in accordance with the EIA/TIA-232E specification Driver output and receiver input pins are protected against ESD to over ±15kV for both human body mode and IEC61000-4-2 air discharge mode. The UM207/208 series are available in SOP24, SSOP24 and TSSOP24 packages, the UM211/213 are available in SOP28, SSOP28 and TSSOP28 packages. Applications z z z z z Computer-Portable, Mainframe, Laptop Handheld Equipments Battery-Powered Equipments Instrumentation, UPS Printers and Terminals Features z z z z z z z z z z Meets All EIA/TIA-232 and ITU V2.8 Specifications Single +5V Supply Operation 4 ×0.1µF External Charge Pump Capacitors Typical 250kbps Transmission Rate 1mA Typical Static Supply Current 1μA Shutdown Mode (UM211/213) Two Wake-Up Receivers (UM213) Tri-State/Rx Enable (UM211/213) Enhanced ESD Specifications for RS-232 Pins: ±15kV Human Body Mode ±15kV IEC61000-4-2 Air Discharge Mode ±8kV IEC61000-4-2 Contact Discharge Mode Available in SOP24, SSOP24, TSSOP24, SOP28, SSOP28, TSSOP28 Packages http://www.union-ic.com Rev.01 Oct.2017 1/27 UM207/208/211/213 Selection Table Part Number Supply Voltage Number of Drivers Number of 232 Receivers Low Power Shutdown Number of Receivers Active in Shutdown UM207EEXX 5V 5 3 NO 0 UM208EEXX 5V 4 4 NO 0 UM211EEXX 5V 4 5 YES 0 UM213EEXX 5V 4 5 YES 2 Ordering Information Part Number Temp. Range Package Type Shipping Qty UM207EESO -40°C to +85°C SOP24 30pcs/Tube UM207EEAO -40°C to +85°C SSOP24 UM207EEAOR -40°C to +85°C SSOP24 UM207EEUO -40°C to +85°C TSSOP24 UM208EESO -40°C to +85°C SOP24 60pcs/Tube 2000pcs/13Inch Tape & Reel 3000pcs/13Inch Tape & Reel 30pcs/Tube UM208EEAO -40°C to +85°C SSOP24 UM208EEAOR -40°C to +85°C SSOP24 UM208EEUO 40°C to +85°C TSSOP24 UM211EESS -40°C to +85°C SOP28 25pcs/Tube UM211EEAS -40°C to +85°C SSOP28 UM211EEASR -40°C to +85°C SSOP28 UM211EEUS 40°C to +85°C TSSOP28 48pcs/Tube 2000pcs/13Inch Tape & Reel 3000pcs/13Inch Tape & Reel UM213EESS -40°C to +85°C SOP28 25pcs/Tube UM213EEAS -40°C to +85°C SSOP28 UM213EEASR -40°C to +85°C SSOP28 UM213EEUS 40°C to +85°C TSSOP28 48pcs/Tube 2000pcs/13Inch Tape & Reel 3000pcs/13Inch Tape & Reel http://www.union-ic.com Rev.01 Oct.2017 60pcs/Tube 2000pcs/13Inch Tape & Reel 3000pcs/13Inch Tape & Reel 2/27 UM207/208/211/213 Absolute Maximum Ratings (Note 1) Symbol Parameter Value Unit VCC Supply Voltage on VCC -0.3 to +6 V V+ Voltage on V+ (VCC-0.3) to +9 V V- Voltage on V- -9 to +0.3 V Voltage on TIN_, -0.3 to (VCC+0.3) V Voltage on RIN_ ±30 V Voltage on TOUT_ (V--0.3) to (V++0.3) V Voltage on ROUT_ -0.3 to (VCC+0.3) V Short-Circuit Duration, TOUT_ to GND Continuous SOP24 SSOP24 TSSOP24 Continuous Power Dissipation at TA=70°C SOP28 SSOP28 TSSOP28 Operating Temperature Range 941 640 879 1000 762 1026 -40 to +85 Storage Temperature Range Maximum Lead Temperature for Soldering 10 Seconds -65 to +165 °C +300 °C PD TA TSTG TL mW °C Note 1: Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. http://www.union-ic.com Rev.01 Oct.2017 3/27 UM207/208/211/213 Electrical Characteristics (VCC=+5.0V ±10%, C1- C4=0.1μF, TA=TMIN to TMAX, unless otherwise noted. Typical values are at TA=25°C) Parameter Output Voltage Swing VCC Power Supply Current Shutdown Supply Current Input Logic Threshold Low Input Logic Threshold High RS-232 Input Voltage Operating Range Receiver Input Threshold Low Receiver Input Threshold High Conditions All transmitter outputs loaded with 3kΩ to ground Min Typ ±5 ±6 Max Unit V No load 0.6 1 mA UM211 UM213 0.1 0.1 10 50 μA --------- ________ ___________ --------- ________ ___________ TIN, EN , SHDN, E N , SHDN TIN, EN , SHDN, E N , SHDN 0.8 V 2.4 -30 VCC=+5V TA=25°C VCC=+5V TA=25°C Active Mode Shut down Mode Active Mode 0.8 0.6 Shut down Mode +30 1.2 1.5 1.7 2.4 1.5 2.4 V V V Input Hysteresis VCC=+5V, no hysteresis in shutdown 0.2 0.5 1.0 V Input Resistance VCC=+5V, TA=25°C 3 5 7 kΩ 0.4 V TTL/CMOS Output Voltage Low IOUT=1.6mA TTL/CMOS Output Voltage High IOUT=1.0mA TTL/CMOS Output Leakage Current 3.5 ________ E N =VCC,EN=0V, 0≤ROUT≤VCC ±0.05 UM211/213 600 ns UM211/213 200 ns Output Enable Time Output Disable Time ___________ Receiver Propagation Delay SHDN=0V SHDN=VCC ___________ UM213 UM207/208/211 Transmitter Output Resistance VCC=V+=V-=0V, VOUT=±2V 300 Transition Region Slew Rate CL=50pF to 2500pF, RL=3kΩ to7kΩ, VCC=+5V, TA=25°C, measured from +3V to -3V or -3V to +3V 3 RS-232 Output Short Circuit Current Maximum Data Rate V RL=3kΩ to7kΩ, CL=50pF to 1000pF, one transmitter http://www.union-ic.com Rev.01 Oct.2017 120 ±10 4 0.5 40 10 0.5 10 μA μs Ω 5.5 30 V/μs ±10 ±30 mA 250 kbps 4/27 UM207/208/211/213 Pin Configurations SOP24/SSOP24/TSSOP24 SOP24/SSOP24/TSSOP24 SOP28/SSOP28/TSSOP28 SOP28/SSOP28/TSSOP28 http://www.union-ic.com Rev.01 Oct.2017 5/27 UM207/208/211/213 Pin Descriptions Pin Name C1+, C2+ V+ C1-C2VTOUT_ RIN_ ROUT_ TIN_ GND VCC ---------- EN, E N ------------------ SHDN, SHDN Function Terminals for Positive Charge Pump Capacitor Charge Pump Output Regulated to +6.5V Terminals for Negative Charge Pump Capacitor Charge Pump Output Regulated to -6.5V RS-232 Driver Outputs RS-232 Receiver Inputs RS-232 Receiver Outputs RS-232 Driver Inputs Ground +4.5V to +5.5V Supply Voltage Input Receiver Enable Transmitters Shutdown UM211 Control Pin Configurations SHDN 0 0 1 --------- EN 0 1 0 Operation Status Transmitters T1-T5 Receivers R1-R5 Normal Operation Normal Operation Shutdown All Active All Active All High-Z All Active All High-Z All High-Z UM213 Control Pin Configurations ------------------ SHDN EN Operation Status 0 0 Shutdown 0 1 Shutdown 1 0 Normal Operation 1 1 Normal Operation Active=active with reduced performance http://www.union-ic.com Rev.01 Oct.2017 Transmitters T1-T4 All High-Z All High-Z All Active All Active Receivers R1,R2,R3 R4,R5 High-Z High-Z High-Z Active High-Z High-Z Active Active 6/27 UM207/208/211/213 Detailed Description The UM207/208/211/213 consists of three sections: charge-pump voltage converters, drivers, and receivers. These E versions provide extra protection against ESD. They survive ±15kV discharges to the RS-232 inputs and outputs, tested using the Human Body Model. When tested according to IEC61000-4-2, they survive ±8kV contact-discharges and ±15kV air-gap discharges. The rugged E versions are intended for use in harsh environments or applications where the RS-232 connection is frequently changed. RS-232 Drivers The drivers are inverting transmitters, which accept TTL or CMOS inputs and output RS-232 signals with an inverted sense relative to the input logic levels. Typically the RS-232 output voltage swing is ±6V. Even under worst case loading conditions of 3kΩ and 2500pF, the output is guaranteed to be ±5V, which is consistent with the RS-232 standard specifications. The transmitter outputs are protected against infinite short-circuits to ground without degradation in reliability. The instantaneous slew rate of the transmitter output is internally limited to a maximum of 30V/μs in order to meet the RS-232 standard. The smooth transition of the loaded output from VOL to VOH clearly meets the monotonicity requirements of the RS-232 standard. RS-232 Receivers The receivers convert RS-232 input signals to inverted TTL signals. The input thresholds are 0.8V minimum and 2.4V maximum, again well within the 3V RS-232 requirements. The receiver inputs are also protected against voltage up to 30V. A 5kΩ pull down resistor to ground will commit the output of the receiver to a high state when the pin is float. In actual system applications, it is quite possible for signals to be applied to the receiver inputs before power is applied the receiver circuitry. This occurs, for example, when a PC user attempts to print, only to realize the printer wasn’t turned on. In this case an RS-232 signal from the PC will appear on the receiver input at the printer. When the printer power is turned on, the receiver will operate normally. All of these enhanced devices are fully protected. Shutdown and Enable Control In shutdown mode, the UM211/213 charges pumps are turned off, V+ is pulled down to VCC, V- is pulled to ground, and the transmitter outputs are disabled. This reduces supply current typically to 1µA. The time required to exit shutdown is 1ms. All receivers except R4 and R5 on the UM213 are put into a high-impedance state in shutdown mode. The UM213’s R4 and R5 receivers still function in shutdown mode. These two receivers are useful for monitoring external activity while maintaining minimal power consumption. The enable control is used to put the receiver outputs into a high-impedance state, so that the receivers can be connected directly to a three-state bus. It has no effect on the RS-232 drivers or on the charge pumps. UM213 Receiver Operation in Shutdown During normal operation, the UM213’s receiver propagation delay is typically 1μs. When entering ------------------ shutdown with receivers active, R4 and R5 are not valid until 80μs after SHDN is driven low. In shutdown mode, propagation delays increase to 4μs for a high-to-low or a low-to-high transition. When exiting shutdown, all receiver outputs are invalid until the charge pumps reach nominal values(<2ms when using 0.1μF capacitors). http://www.union-ic.com Rev.01 Oct.2017 7/27 UM207/208/211/213 ESD Protection UM207/208/211/213 devices have standard ESD protection structures incorporated on the pins to protect against electrostatic discharges encountered during assembly and handling. In addition, the RS-232 bus pins (driver outputs and receiver input) of these devices have an extra level of ESD protection. Advanced ESD structures were designed to successfully protect these pins against ESD discharge of ±15kV Human Body Model when powered down or up. http://www.union-ic.com Rev.01 Oct.2017 8/27 UM207/208/211/213 Typical Operating Circuits http://www.union-ic.com Rev.01 Oct.2017 9/27 UM207/208/211/213 Application Information Capacitor Selection The capacitor type used for C1–C4 is not critical for proper operation. The UM207/208/211/213 series require 0.1μF capacitors, although in all cases capacitors up to 10μF can be used without harm. Ceramic dielectrics are suggested for the 0.1μF capacitors. When using the minimum recommended capacitor values, make sure the capacitance value does not degrade excessively as the operating temperature varies. If in doubt, use capacitors with a larger (e.g., 2x) nominal value. The capacitors’ effective series resistance (ESR), which usually rises at low temperatures, influences the amount of ripple on V+ and V-. Use larger capacitors (up to 10μF) to reduce the output impedance at V+ and V-. Bypass VCC to ground with at least 0.1μF capacitor. In applications sensitive to power-supply noise generated by the charge pumps, decouple VCC to ground with a capacitor the same size as (or larger than) the charge pump capacitors (C1–C4). V+ and V- as Power Supplies A small amount of power can be drawn from V+ and V-, although this will reduce both driver output swing and noise margins. Increasing the value of the charge-pump capacitors (up to 10μF) helps maintain performance when power is drawn from V+ or V-. Driving Multiple Receivers Each transmitter is designed to drive a single receiver. Transmitters can be paralleled to drive multiple receivers. http://www.union-ic.com Rev.01 Oct.2017 10/27 UM207/208/211/213 Package Information UM207EESO SOP24 Outline Drawing DIMENSIONS Symbol MILLIMETERS INCHES Min Typ Max Min Typ Max A 2.35 2.55 2.80 0.093 0.100 0.110 A1 0.05 0.20 0.30 0.002 0.008 0.012 A2 2.10 - 2.65 0.083 - 0.104 b 0.33 - 0.54 0.013 - 0.021 c 0.15 - 0.34 0.006 - 0.013 D 15.20 15.40 15.60 0.598 0.606 0.614 E 7.40 7.50 7.60 0.291 0.295 0.299 E1 9.80 - 10.61 0.386 - 0.418 e 1.27BSC 0.050BSC L 0.40 - 1.27 0.016 - 0.050 θ 0° - 8° 0° - 8° Land Pattern NOTES: 1. Compound dimension: 15.40×7.50; 2. Unit: mm; 3. General tolerance ±0.05mm unless otherwise specified; 4. The layout is just for reference. http://www.union-ic.com Rev.01 Oct.2017 11/27 UM207/208/211/213 UM207EEAO SSOP24 Outline Drawing Symbol A A1 A2 b c D E E1 e L θ DIMENSIONS MILLIMETERS INCHES Min Typ Max Min Typ Max 2.00 0.079 0.05 0.002 1.40 1.75 1.85 0.056 0.069 0.073 0.22 0.30 0.38 0.009 0.012 0.015 0.09 0.17 0.25 0.004 0.007 0.010 7.90 8.20 8.50 0.316 0.328 0.340 5.00 5.30 5.60 0.197 0.209 0.220 7.40 7.80 8.20 0.291 0.307 0.323 0.65BSC 0.026BSC 0.55 1.05 0.022 0.042 0° 8° 0° 8° Land Pattern NOTES: 1. Compound dimension: 8.20×5.30; 2. Unit: mm; 3. General tolerance ±0.05mm unless otherwise specified; 4. The layout is just for reference. http://www.union-ic.com Rev.01 Oct.2017 12/27 UM207/208/211/213 UM207EEAOR SSOP24 Outline Drawing Symbol A A1 A2 b c D E E1 e L θ DIMENSIONS MILLIMETERS INCHES Min Typ Max Min Typ Max 2.00 0.079 0.05 0.002 1.40 1.75 1.85 0.056 0.069 0.073 0.22 0.30 0.38 0.009 0.012 0.015 0.09 0.17 0.25 0.004 0.007 0.010 7.90 8.20 8.50 0.316 0.328 0.340 5.00 5.30 5.60 0.197 0.209 0.220 7.40 7.80 8.20 0.291 0.307 0.323 0.65BSC 0.026BSC 0.55 1.05 0.022 0.042 0° 8° 0° 8° Land Pattern NOTES: 1. Compound dimension: 8.20×5.30; 2. Unit: mm; 3. General tolerance ±0.05mm unless otherwise specified; 4. The layout is just for reference. Tape and Reel Orientation http://www.union-ic.com Rev.01 Oct.2017 13/27 UM207/208/211/213 UM207EEUO TSSOP24 Outline Drawing Symbo l A A1 A2 A3 b c D E E1 e L L1 L2 θ1 θ2 θ3 DIMENSIONS MILLIMETERS INCHES Min Typ Max Min Typ Max 1.20 0.047 0.05 0.15 0.002 0.006 0.80 1.05 0.031 0.041 0.34 0.44 0.54 0.013 0.017 0.021 0.19 0.30 0.007 0.012 0.09 0.20 0.004 0.008 7.70 7.80 7.90 0.308 0.312 0.316 4.30 4.40 4.50 0.169 0.173 0.177 6.20 6.40 6.60 0.244 0.252 0.260 0.65BSC 0.026BSC 0.45 0.60 0.75 0.018 0.024 0.030 1.00REF 0.039REF 0.25BSC 0.010BSC 0° 8° 0° 8° 10° 12° 14° 10° 12° 14° 10° 12° 14° 10° 12° 14° Land Pattern NOTES: 1. Compound dimension: 7.80×4.40; 2. Unit: mm; 3. General tolerance ±0.05mm unless otherwise specified; 4. The layout is just for reference. Tape and Reel Orientation http://www.union-ic.com Rev.01 Oct.2017 14/27 UM207/208/211/213 UM208EESO SOP24 Outline Drawing DIMENSIONS Symbol MILLIMETERS INCHES Min Typ Max Min Typ Max A 2.35 2.55 2.80 0.093 0.100 0.110 A1 0.05 0.20 0.30 0.002 0.008 0.012 A2 2.10 - 2.65 0.083 - 0.104 b 0.33 - 0.54 0.013 - 0.021 c 0.15 - 0.34 0.006 - 0.013 D 15.20 15.40 15.60 0.598 0.606 0.614 E 7.40 7.50 7.60 0.291 0.295 0.299 E1 9.80 - 10.61 0.386 - 0.418 e 1.27BSC 0.050BSC L 0.40 - 1.27 0.016 - 0.050 θ 0° - 8° 0° - 8° Land Pattern NOTES: 1. Compound dimension: 15.40×7.50; 2. Unit: mm; 3. General tolerance ±0.05mm unless otherwise specified; 4. The layout is just for reference. http://www.union-ic.com Rev.01 Oct.2017 15/27 UM207/208/211/213 UM208EEAO SSOP24 Outline Drawing Symbol A A1 A2 b c D E E1 e L θ DIMENSIONS MILLIMETERS INCHES Min Typ Max Min Typ Max 2.00 0.079 0.05 0.002 1.40 1.75 1.85 0.056 0.069 0.073 0.22 0.30 0.38 0.009 0.012 0.015 0.09 0.17 0.25 0.004 0.007 0.010 7.90 8.20 8.50 0.316 0.328 0.340 5.00 5.30 5.60 0.197 0.209 0.220 7.40 7.80 8.20 0.291 0.307 0.323 0.65BSC 0.026BSC 0.55 1.05 0.022 0.042 0° 8° 0° 8° Land Pattern NOTES: 1. Compound dimension: 8.20×5.30; 2. Unit: mm; 3. General tolerance ±0.05mm unless otherwise specified; 4. The layout is just for reference. http://www.union-ic.com Rev.01 Oct.2017 16/27 UM207/208/211/213 UM208EEAOR SSOP24 Outline Drawing Symbol A A1 A2 b c D E E1 e L θ DIMENSIONS MILLIMETERS INCHES Min Typ Max Min Typ Max 2.00 0.079 0.05 0.002 1.40 1.75 1.85 0.056 0.069 0.073 0.22 0.30 0.38 0.009 0.012 0.015 0.09 0.17 0.25 0.004 0.007 0.010 7.90 8.20 8.50 0.316 0.328 0.340 5.00 5.30 5.60 0.197 0.209 0.220 7.40 7.80 8.20 0.291 0.307 0.323 0.65BSC 0.026BSC 0.55 1.05 0.022 0.042 0° 8° 0° 8° Land Pattern NOTES: 1. Compound dimension: 8.20×5.30; 2. Unit: mm; 3. General tolerance ±0.05mm unless otherwise specified; 4. The layout is just for reference. Tape and Reel Orientation http://www.union-ic.com Rev.01 Oct.2017 17/27 UM207/208/211/213 UM208EEUO TSSOP24 Outline Drawing Symbo l A A1 A2 A3 b c D E E1 e L L1 L2 θ1 θ2 θ3 DIMENSIONS MILLIMETERS INCHES Min Typ Max Min Typ Max 1.20 0.047 0.05 0.15 0.002 0.006 0.80 1.05 0.031 0.041 0.34 0.44 0.54 0.013 0.017 0.021 0.19 0.30 0.007 0.012 0.09 0.20 0.004 0.008 7.70 7.80 7.90 0.308 0.312 0.316 4.30 4.40 4.50 0.169 0.173 0.177 6.20 6.40 6.60 0.244 0.252 0.260 0.65BSC 0.026BSC 0.45 0.60 0.75 0.018 0.024 0.030 1.00REF 0.039REF 0.25BSC 0.010BSC 0° 8° 0° 8° 10° 12° 14° 10° 12° 14° 10° 12° 14° 10° 12° 14° Land Pattern NOTES: 1. Compound dimension: 7.80×4.40; 2. Unit: mm; 3. General tolerance ±0.05mm unless otherwise specified; 4. The layout is just for reference. Tape and Reel Orientation http://www.union-ic.com Rev.01 Oct.2017 18/27 UM207/208/211/213 UM211EESS SOP28 Outline Drawing DIMENSIONS Symbol MILLIMETERS INCHES Min Typ Max Min Typ Max A 2.35 2.55 2.80 0.093 0.100 0.110 A1 0.10 0.20 0.30 0.004 0.008 0.012 A2 2.25 - 2.65 0.089 - 0.104 b 0.33 - 0.54 0.013 - 0.021 c 0.15 - 0.33 0.006 - 0.013 D 17.40 - 18.10 0.685 - 0.713 E 7.40 7.55 7.70 0.291 0.297 0.303 E1 10.20 10.40 10.61 0.402 0.409 0.418 e 1.27BSC 0.050BSC L 0.40 - 1.27 0.016 - 0.050 θ 0° - 8° 0° - 8° 1.87 11.21 Land Pattern http://www.union-ic.com Rev.01 Oct.2017 NOTES: 1. Compound dimension: 17.75×7.55; 2. Unit: mm; 3. General tolerance ±0.05mm unless otherwise specified; 4. The layout is just for reference. 19/27 UM207/208/211/213 UM211EEAS SSOP28 Outline Drawing Symbol A A1 A2 b c D E E1 e L θ DIMENSIONS MILLIMETERS INCHES Min Typ Max Min Typ Max 2.00 0.079 0.05 0.002 1.65 1.75 1.85 0.065 0.069 0.073 0.22 0.30 0.38 0.009 0.012 0.015 0.09 0.17 0.25 0.004 0.007 0.010 9.90 10.20 10.50 0.390 0.402 0.413 5.00 5.30 5.60 0.197 0.209 0.220 7.40 7.80 8.20 0.291 0.307 0.323 0.65BSC 0.026BSC 0.55 1.05 0.022 0.042 0° 8° 0° 8° Land Pattern NOTES: 1. Compound dimension: 10.20×5.30; 2. Unit: mm; 3. General tolerance ±0.05mm unless otherwise specified; 4. The layout is just for reference. http://www.union-ic.com Rev.01 Oct.2017 20/27 UM207/208/211/213 UM211EEASR SSOP28 Outline Drawing Symbol A A1 A2 b c D E E1 e L θ DIMENSIONS MILLIMETERS INCHES Min Typ Max Min Typ Max 2.00 0.079 0.05 0.002 1.65 1.75 1.85 0.065 0.069 0.073 0.22 0.30 0.38 0.009 0.012 0.015 0.09 0.17 0.25 0.004 0.007 0.010 9.90 10.20 10.50 0.390 0.402 0.413 5.00 5.30 5.60 0.197 0.209 0.220 7.40 7.80 8.20 0.291 0.307 0.323 0.65BSC 0.026BSC 0.55 1.05 0.022 0.042 0° 8° 0° 8° Land Pattern NOTES: 1. Compound dimension: 10.20×5.30; 2. Unit: mm; 3. General tolerance ±0.05mm unless otherwise specified; 4. The layout is just for reference. Tape and Reel Orientation http://www.union-ic.com Rev.01 Oct.2017 21/27 UM207/208/211/213 UM211EEUS TSSOP28 Outline Drawing Symbo l A A1 A2 A3 b c D E E1 e L L1 L2 θ1 θ2 θ3 DIMENSIONS MILLIMETERS INCHES Min Typ Max Min Typ Max 1.20 0.047 0.05 0.15 0.002 0.006 0.80 1.05 0.031 0.041 0.34 0.44 0.54 0.013 0.017 0.021 0.19 0.30 0.007 0.012 0.09 0.20 0.004 0.008 9.60 9.70 9.80 0.378 0.382 0.386 4.30 4.40 4.50 0.169 0.173 0.177 6.20 6.40 6.60 0.244 0.252 0.260 0.65BSC 0.026BSC 0.45 0.60 0.75 0.018 0.024 0.030 1.00REF 0.039REF 0.25BSC 0.010BSC 0° 8° 0° 8° 10° 12° 14° 10° 12° 14° 10° 12° 14° 10° 12° 14° Land Pattern NOTES: 1. Compound dimension: 9.70×4.40; 2. Unit: mm; 3. General tolerance ±0.05mm unless otherwise specified; 4. The layout is just for reference. Tape and Reel Orientation http://www.union-ic.com Rev.01 Oct.2017 22/27 UM207/208/211/213 UM213EESS SOP28 Outline Drawing DIMENSIONS Symbol MILLIMETERS INCHES Min Typ Max Min Typ Max A 2.35 2.55 2.80 0.093 0.100 0.110 A1 0.10 0.20 0.30 0.004 0.008 0.012 A2 2.25 - 2.65 0.089 - 0.104 b 0.33 - 0.54 0.013 - 0.021 c 0.15 - 0.33 0.006 - 0.013 D 17.40 - 18.10 0.685 - 0.713 E 7.40 7.55 7.70 0.291 0.297 0.303 E1 10.20 10.40 10.61 0.402 0.409 0.418 e 1.27BSC 0.050BSC L 0.40 - 1.27 0.016 - 0.050 θ 0° - 8° 0° - 8° 1.87 11.21 Land Pattern http://www.union-ic.com Rev.01 Oct.2017 NOTES: 1. Compound dimension: 17.75×7.55; 2. Unit: mm; 3. General tolerance ±0.05mm unless otherwise specified; 4. The layout is just for reference. 23/27 UM207/208/211/213 UM213EEAS SSOP28 Outline Drawing Symbol A A1 A2 b c D E E1 e L θ DIMENSIONS MILLIMETERS INCHES Min Typ Max Min Typ Max 2.00 0.079 0.05 0.002 1.65 1.75 1.85 0.065 0.069 0.073 0.22 0.30 0.38 0.009 0.012 0.015 0.09 0.17 0.25 0.004 0.007 0.010 9.90 10.20 10.50 0.390 0.402 0.413 5.00 5.30 5.60 0.197 0.209 0.220 7.40 7.80 8.20 0.291 0.307 0.323 0.65BSC 0.026BSC 0.55 1.05 0.022 0.042 0° 8° 0° 8° Land Pattern NOTES: 1. Compound dimension: 10.20×5.30; 2. Unit: mm; 3. General tolerance ±0.05mm unless otherwise specified; 4. The layout is just for reference. http://www.union-ic.com Rev.01 Oct.2017 24/27 UM207/208/211/213 UM213EEASR SSOP28 Outline Drawing Symbol A A1 A2 b c D E E1 e L θ DIMENSIONS MILLIMETERS INCHES Min Typ Max Min Typ Max 2.00 0.079 0.05 0.002 1.65 1.75 1.85 0.065 0.069 0.073 0.22 0.30 0.38 0.009 0.012 0.015 0.09 0.17 0.25 0.004 0.007 0.010 9.90 10.20 10.50 0.390 0.402 0.413 5.00 5.30 5.60 0.197 0.209 0.220 7.40 7.80 8.20 0.291 0.307 0.323 0.65BSC 0.026BSC 0.55 1.05 0.022 0.042 0° 8° 0° 8° Land Pattern NOTES: 1. Compound dimension: 10.20×5.30; 2. Unit: mm; 3. General tolerance ±0.05mm unless otherwise specified; 4. The layout is just for reference. Tape and Reel Orientation http://www.union-ic.com Rev.01 Oct.2017 25/27 UM207/208/211/213 UM213EEUS TSSOP28 Outline Drawing Symbo l A A1 A2 A3 b c D E E1 e L L1 L2 θ1 θ2 θ3 DIMENSIONS MILLIMETERS INCHES Min Typ Max Min Typ Max 1.20 0.047 0.05 0.15 0.002 0.006 0.80 1.05 0.031 0.041 0.34 0.44 0.54 0.013 0.017 0.021 0.19 0.30 0.007 0.012 0.09 0.20 0.004 0.008 9.60 9.70 9.80 0.378 0.382 0.386 4.30 4.40 4.50 0.169 0.173 0.177 6.20 6.40 6.60 0.244 0.252 0.260 0.65BSC 0.026BSC 0.45 0.60 0.75 0.018 0.024 0.030 1.00REF 0.039REF 0.25BSC 0.010BSC 0° 8° 0° 8° 10° 12° 14° 10° 12° 14° 10° 12° 14° 10° 12° 14° Land Pattern NOTES: 1. Compound dimension: 9.70×4.40; 2. Unit: mm; 3. General tolerance ±0.05mm unless otherwise specified; 4. The layout is just for reference. Tape and Reel Orientation http://www.union-ic.com Rev.01 Oct.2017 26/27 UM207/208/211/213 GREEN COMPLIANCE Union Semiconductor is committed to environmental excellence in all aspects of its operations including meeting or exceeding regulatory requirements with respect to the use of hazardous substances. Numerous successful programs have been implemented to reduce the use of hazardous substances and/or emissions. All Union components are compliant with the RoHS directive, which helps to support customers in their compliance with environmental directives. For more green compliance information, please visit: http://www.union-ic.com/index.aspx?cat_code=RoHSDeclaration IMPORTANT NOTICE The information in this document has been carefully reviewed and is believed to be accurate. Nonetheless, this document is subject to change without notice. Union assumes no responsibility for any inaccuracies that may be contained in this document, and makes no commitment to update or to keep current the contained information, or to notify a person or organization of any update. Union reserves the right to make changes, at any time, in order to improve reliability, function or design and to attempt to supply the best product possible. Union Semiconductor, Inc Add: Unit 606, No.570 Shengxia Road, Shanghai 201210 Tel: 021-51093966 Fax: 021-51026018 Website: www.union-ic.com http://www.union-ic.com Rev.01 Oct.2017 27/27
UM213EEASR 价格&库存
很抱歉,暂时无法提供与“UM213EEASR”相匹配的价格&库存,您可以联系我们找货
