BSD5C151U
BSD5C151U
    BORN(伯恩)
    SOD-523(SC-79)
    TVS二极管(ESD) ESD静电保护管 低结电容接口保护物料
BSD5C151U 数据手册
BSD5C151U ESD Protection Diode »Features ■ 100Watts peak pulse power (tp = 8/20μs) ■ SOD523 package ■ Bidirectional configurations ■ Solid-state silicon-avalanche technology ■ Low clamping voltage ■ Low leakage current ■ Low capacitance (Cj=0.3pF typ.) ■ Protection one data/power line ■ IEC 61000-4-2 ±15kV contact ±20kV air ■ IEC 61000-4-4 (EFT) 40A (5/50ns) ■ IEC 61000-4-5 (Lightning) 3.0A(8/20μs) »Applications »Mechanical Data ■ Cell Phone Handsets and Accessories ■ SOD523 package ■ Microprocessor based equipment ■ Molding compound flammability rating: UL 94V-0 ■ Personal Digital Assistants (PDA’s) ■ Packaging: Tape and Reel ■ Notebooks, Desktops, and Servers ■ RoHS/WEEE Compliant ■ Portable Instrumentation »Schematic & PIN Configuration SOD-523 Revision 2018 www.born-tw.com 1/4 BSD5C151U »Absolute Maximum Rating Rating Symbol Value Units Peak Pulse Power ( tp =8/20μs) PPP 100 Watts Peak Pulse Current ( tp =8/20μs )(note1) Ipp 3.0 A VESD 20 15 kV Lead SolderingTemperature TL 260(10seconds) ℃ Junction Temperature TJ -55 to + 125 ℃ Storage Temperature Tstg -55 to + 125 ℃ ESD per IEC 61000-4-2(Air) ESD per IEC 61000-4-2(Contact) »Electrical Characteristics Parameter Symbol Conditions Min Typical Max Units 15.0 V 17.5 20.0 V 0.1 0.5 μA 3.0 A Reverse Stand-Off Voltage VRWM Reverse BreakdownVoltage VBR IT=1mA Reverse LeakageCurrent IR VRWM=15V,T=25℃ Peak Pulse Current IPP tp =8/20μs Clamping Voltage VC IPP=3.0A,tp=8/20μs 35 40 V Junction Capacitance Cj VR = 0V, f = 1MHz 0.3 0.5 pF 16.7 »Electrical Parameters (TA = 25°C unless otherwisenoted) Symbol Parameter IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP V RWM IR V BR IT I IPP Working Peak Reverse Voltage Maximum Reverse Leakage Current @ V RWM V C V BR V RW M IT IR I IT R V RW M V BR V C V Breakdown Voltage @ IT Test Current IPP Note: 8/20μs pulsewaveform. Revision 2018 www.born-tw.com 2/4 BSD5C151U Figure 1: Peak Pulse Power vs. Pulse Time Figure 2: Power Derating Curve 10 110 100 Percent of Rated Power for Ipp Ppp – Peak Pulse Power - Ppp(KW) »TypicalCharacteristics 1 100w 8/20µs waveform 0.1 0.01 1 0.1 10 100 90 80 70 60 50 40 30 20 10 0 1,000 0 25 td – Pulse Duration - µs Figure3: Pulse Waveform 90 Percent Ipp 80 e-1 50 40 td=Ipp/2 20 0 30 25 Test Waveform Paramters tr=8µs td=20µs 20 15 10 0 Revision 2018 5 10 15 150 35 5 10 0 125 40 Clamping Voltage–VC (V) 100 30 100 45 Waveform Paramters tr=8µs td=20µs 60 75 Figure 4: Clamping Voltage vs.Ipp 110 70 50 Ambient Temperature - TA (℃) Time (µs) 20 25 30 0 www.born-tw.com 1 2 3 4 5 6 Peak Pulse Current–IPP (A) 3/4 BSD5C151U »Outline Drawing – SOD523 D -X-YE DIMENSIONS 2 1 SYMBOL b 2x 0.08 (0.0032) X A b C D E HE L Y A C HE L MILLIMETER MIN 0.50 0.25 0.07 1.10 0.70 1.50 0.15 MAX 0.70 0.35 0.20 1.30 0.90 1.70 0.25 INCHES MIN 0.020 0.010 0.0028 0.043 0.028 0.059 0.006 MAX 0.028 0.014 0.0079 0.051 0.035 0.067 0.010 »Marking 15R »Ordering information Order code BSD5C151U Revision 2018 Package SOD523 Base qty 5000 www.born-tw.com Delivery mode Tape and reel 4/4
BSD5C151U 价格&库存
很抱歉,暂时无法提供与“BSD5C151U”相匹配的价格&库存,您可以联系我们找货
BSD5C151U
  • 5+0.22078
  • 20+0.20083
  • 100+0.18088
  • 500+0.16093
  • 1000+0.15162
  • 2000+0.14497
库存:1657
BSD5C151U
  • 10+0.29387
  • 100+0.23771
  • 300+0.20963
  • 1000+0.18857
  • 5000+0.16568
  • 10000+0.15725
库存:19008
