LESD5Z5.0C-H
LESD5Z5.0C-H
    MDD(辰达半导体)
    SOD-523(SC-79)
    反向截止电压(Vrwm):5V;击穿电压:5.6V;最大钳位电压:16V;
LESD5Z5.0C-H 数据手册
LESD5Z5.0C-H Transient Voltage Suppressors for ESD protection DESCRIPTION SOD-523 Plastic-Encapsulate ESD Protection Diodes The LESD5Z5.0C_H is designed to protect voltage sensitive components from ESD and transient voltage events. Excellent clamping capability, low leakage, and fast response time, make these parts ideal for ESD protection on designs where board space is at a premium. This device has been specifically designed to protect sensitive components which are connected to data and transmission lines from overvoltage caused by ESD (electrostatic discharge), CDE (Cable Discharge Events), and EFT (electrical fast transients). Features Pin Configuration  Peak Power Dissipation 75 W (8/20μs)  IEC61000-4-2 (ESD) ±30kV (air), ±30kV (contact)  IEC61000-4-4 (EFT) 40A (5/50ns)  Protects one I/O line  Low clamping voltage  Working voltages : 5V  Low leakage current Circuit Diagram  Meets MSL 3 Requirements Marking 8 5C Applications        Cellular handsets and accessories High Speed Line :USB1.0/2.0, VGA, DVI, SDI Serial and Parallel Ports Notebooks, Desktops, and Servers Portable Instrumentation Peripherals Projection TV Mechanical Characteristics  Package: SOD-523  Flammability Rating: UL 94V-0  Terminals: Tin plated, solderable per MIL-STD-750, method 2026  Packaging: Tape and Reel  Reel size: 7 inch Absolute Maximum Ratings (TA=25°C unless otherwise specified) Parameter ESD per IEC 61000−4−2 (Air) ESD per IEC 61000−4−2 (Contact) Symbol VESD Value ± 30 ± 30 Unit KV Peak Pulse Power(8/20us ) PPP 75 W Operating Temperature TOPT −40 to +150 °C Storage Temperature TSTG −40 to +150 °C TL 260(10 sec.) °C Lead Solder Temperature – Maximum (10 Second Duration) The above data are for reference only. DN:T19C12A0 http://www.microdiode.com Rev:2019A0 Page :1 LESD5Z5.0C-H Transient Voltage Suppressors for ESD protection Electrical Characteristics (TA=25°C unless otherwise specified) Symbol bol Param Test Condition Min Typ Max Units 5.0 V 9.0 V VRWM Reverse Working Voltage VBR Reverse Breakdown Voltage IT = 1mA IR Reverse Leakage Current VRWM = 5V 1.0 μA IPP = 1A, tp = 8/20μs 9.5 V IPP = 5A, tp = 8/20μs 15.0 V VR = 0V, f = 1MHz 15 pF VC Clamping Voltage CJ Junction Capacitance 5.6 The above data are for reference only. http://www.microdiode.com Rev:2019A0 Page :2 LESD5Z5.0C-H Transient Voltage Suppressors for ESD protection ELECTRICAL CHARACTERISTICS CURVE The curve above is for reference only. http://www.microdiode.com Rev:2019A0 Page :3 LESD5Z5.0C-H Transient Voltage Suppressors for ESD protection Outlitne Drawing SOD-523 Package Outline Dimensions 6\PERO A A1 b c D E E1 E2 L  'LPHQVLRQV,Q0LOOLPHWHUV 0LQ 0D[ 0.510 0.770 0.500 0.700 0.250 0.350 0.080 0.150 0.750 0.850 1.100 1.300 1.500 1.700 0.200 REF 0.010 0.070 7° REF 'LPHQVLRQV,Q,QFKHV 0LQ 0D[ 0.020 0.031 0.020 0.028 0.010 0.014 0.003 0.006 0.030 0.033 0.043 0.051 0.059 0.067 0.008 REF 0.001 0.003 7° REF Suggested Pad Layout Note: 1.Controlling dimension:in/millimeters. 2.General tolerance: ±0.05mm. 3.The pad layout is for reference purposes only. PACKAGE SPECIFICATIONS Package Reel Size SOD-523 Reel DIA. (mm) Q'TY/Reel (pcs) Box Size (mm) QTY/Box (pcs) Carton Size (mm) Q'TY/Carton (pcs) 178 3000 183×188×80 18000 386×265×215 180000 7' Important Notice and Disclaimer Microdiode Electronics (Jiangsu) reserves the right to make changes to this document and its products and specifications at any time without notice. Customers should obtain and confirm the latest product information and specifications before final design,purchase or use. Microdiode Electronics (Jiangsu) makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, not does Microdiode Electronics (Jiangsu) assume any liability for application assistance or customer product design. Microdiode Electronics (Jiangsu) does not warrant or accept any liability with products which are purchased or used for any unintended or unauthorized application. No license is granted by implication or otherwise under any intellectual property rights of Microdiode Electronics (Jiangsu). Microdiode Electronics (Jiangsu) products are not authorized for use as critical components in life support devices or systems without express written approval of Microdiode Electronics (Jiangsu). http://www.microdiode.com Rev:2019A0 Page :4
