3PEAK
LMV331TP / LMV393TP
General Purpose, 1.8V, RRI, Open-Drain Output Comparators
Features
Description
Down to 1.8V Supply Voltage: 1.8V to 5.5V
Low Supply Current: 40 μA per Channel
High-to-Low Propagation Delay: 120 ns
Internal Hysteresis Ensures Clean Switching
Offset Voltage: ± 3.5 mV Maximum
Offset Voltage Temperature Drift: 0.5 μV/°C
Input Bias Current: 6 pA Typical
Input Common-Mode Range Extends 200 mV
No Phase Reversal for Overdriven Inputs
Open-Drain Output for Maximum Flexibility
Green, Space-Saving SC70 Package Available
Applications
Peak and Zero-crossing Detectors
Threshold Detectors/Discriminators
Sensing at Ground or Supply Line
Logic Level Shifting or Translation
Window Comparators
IR Receivers
Clock and Data Signal Restoration
Telecom, Portable Communications
Portable and Battery Powered Systems
LMV331TP
LMV331TPU
5-Pin SOT23
(-T Suffix)
+In
1
V-
2
-In
3
5
4
V+
Out
-In
1
V-
2
+In
3
3PEAK and the 3PEAK logo are registered trademarks of
3PEAK INCORPORATED. All other trademarks are the property
of their respective owners.
﹣In A
2
﹢In A
3
V-
4
www.3peakic.com
A
B
DEVICE
DESCRIPTION
Fast 30ns, Low Power, Internal Hysteresis,
V+
TP1951/TP1951N
± 3mV Maximum VOS, – 0.2V to VDD + 0.2V RRI,
/TP1952/TP1954 Push-Pull (CMOS/TTL) Output Comparators
4
8-Pin SOIC/MSOP/TSSOP/DIP
(-S, -V, -T and -D Suffixes)
1
Related Products
5
LMV393TP
Out A
The chips incorporate 3PEAK’s proprietary and
patented design techniques to achieve the ultimate
combination of high-speed (120ns high-to-low
propagation delay) and low power consuming (40μA
quiescent current per comparator). These
comparators are optimized for low power 1.8V,
single-supply applications with greater than
rail-to-rail input operation, and also operate with
±0.9V to ±2.75V dual supplies. The input commonmode voltage range extends 200mV below ground
and 200mV above supply, allowing both ground and
supply sensing. The internal input hysteresis
eliminates output switching due to internal input
noise voltage, reducing current draw.
The LMV331 single comparator is available in tiny
SC70 package for space-conservative designs. All
chips are specified for the temperature range of
–40°C to +85°C.
Pin Configuration (Top View)
5-Pin SOT23/SC70
(-T and -C Suffixes)
The 3PEAK INCORPORATED LMV331-393 are the
most cost-effective solutions for applications where
low-voltage operation, low power, space saving, and
price are the primary specifications in circuit design
for portable consumer products. The LMV331TP is
the single-comparator, the LMV393TP is the dual,
and both are open-drain output comparators for
maximum flexibility.
8
V+
7
Out B
6
﹣In B
5
﹢In B
Out
TP1955/TP1955N
/TP1956/TP1958 Open-Drain Output Comparators
TP1931
/TP1932/TP1934
950ns, 3µ A, 1.8V, ± 2.5mV VOS-MAX, Internal
Hysteresis, RRI, Push-Pull Output Comparators
TP1935
/TP1936/TP1938
Hysteresis, RRI, Open-Drain Comparators
TP2011
/TP2012/TP2014
Ultra-low 200nA, 13µ s, 1.6V, ± 2mV VOS-MAX,
Internal Hysteresis, RRI, Push-Pull (CMOS/TTL)
Output Comparators
TP2015
/TP2016/TP2018
Internal Hysteresis, RRI, Open-Drain Output
Comparators
REV1.0
1
LMV331TP / LMV393TP
Order Information
Model Name
LMV331TP
LMV331TPU
LMV393TP
Order Number
Package
Transport Media, Quantity
Marking
Information
LMV331TP-TR
5-Pin SOT23
Tape and Reel, 3000
CA4YW (1)
LMV331TP-CR
5-Pin SC70
Tape and Reel, 3000
CB4YW (1)
LMV331TPU-TR
5-Pin SOT23
Tape and Reel, 3000
CI4YW (1)
LMV393TP-SR
8-Pin SOIC
Tape and Reel, 4000
C46S
LMV393TP-VR
8-Pin MSOP
Tape and Reel, 3000
C46V
LMV393TP-TR
8-Pin TSSOP
Tape and Reel, 3000
C46T
LMV393TP-DR
8-Pin DIP
Tape and Reel, 3000
C46D
Note (1): ‘YW’ is date coding scheme. 'Y' stands for calendar year, and 'W' stands for single workweek coding scheme.
Absolute Maximum Ratings Note 1
Supply Voltage: V+ – V–....................................6.0V
Operating Temperature Range.........–40°C to 85°C
Input Voltage............................. V – 0.3 to V + 0.3
Maximum Junction Temperature................... 150°C
Input Current: +IN, –IN,
Note 2..........................±10mA
Storage Temperature Range.......... –65°C to 150°C
Output Current: OUT.................................... ±45mA
Lead Temperature (Soldering, 10 sec) ......... 260°C
Output Short-Circuit Duration Note 3…......... Indefinite
Note 1: Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. Exposure to any
Absolute Maximum Rating condition for extended periods may affect device reliability and lifetime.
Note 2: The inputs are protected by ESD protection diodes to each power supply. If the input extends more than 500mV beyond the power
supply, the input current should be limited to less than 10mA.
Note 3: A heat sink may be required to keep the junction temperature below the absolute maximum. This depends on the power supply voltage
and how many amplifiers are shorted. Thermal resistance varies with the amount of PC board metal connected to the package. The specified
values are for short traces connected to the leads.
ESD, Electrostatic Discharge Protection
Symbol
2
Parameter
Condition
Minimum Level
Unit
HBM
Human Body Model ESD
MIL-STD-883H Method 3015.8
8
kV
CDM
Charged Device Model ESD
JEDEC-EIA/JESD22-C101E
2
kV
REV1.0
www.3peakic.com
LMV331TP / LMV393TP
Electrical Characteristics
The ● denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 27° C.
VDD = +1.8V to +5.5V, VIN+ = VDD, VIN- = 1.2V, RPU=10kΩ, CL =15pF.
SYMBOL
PARAMETER
VDD
Supply Voltage
VOS
VOS TC
VHYST
Input Offset Voltage Note 1
Input Offset Voltage Drift Note 1
Input Hysteresis Voltage Note 1
Input Hysteresis Voltage Drift Note 1
IB
IOS
RIN
Input Bias Current
Input Offset Current
Input Resistance
VCM = 1.2V
CIN
Input Capacitance
CMRR
Common Mode Rejection Ratio
Common-mode Input Voltage
Range
Power Supply Rejection Ratio
High-Level Output Voltage
Low-Level Output Voltage
Output Short-Circuit Current
Quiescent Current per Comparator
VHYST TC
VCM
PSRR
VOH
VOL
ISC
IQ
tR
CONDITIONS
MIN
TYP
1.8
VCM = 1.2V
VCM = 1.2V
VCM = 1.2V
-3.5
VCM = 1.2V
6
4
> 100
2
4
70
V– - 0.2
60
V+ - 0.3
Differential
Common Mode
VCM = VSS to VDD
IOUT=-1mA
IOUT=1mA
Sink or source current
3
MAX
5.5
± 0.6
0.5
6
+3.5
9
UNITS
V
mV
μV/° C
mV
μV/° C
pA
pA
GΩ
pF
dB
V+ + 0.2
75
V– + 0.3
V
dB
V
V
mA
μA
ns
Rising Time
25
40
5
tF
Falling Time
5
ns
tPD-
Propagation Delay (High-to-Low)
120
ns
tPD+
Propagation Delay (Low-to-High)
250
ns
Input Overdrive=100mV, VIN- =2.5V
RPU=5.1kΩ, Input Overdrive=100mV,
VIN- =2.5V
70
Note 1: The input offset voltage is the average of the input-referred trip points. The input hysteresis is the difference between the input-referred
trip points.
Note 2: Propagation Delay Skew is defined as: tPD-SKEW = tPD+ - tPD-.
www.3peakic.com
REV1.0
3
LMV331TP / LMV393TP
Pin Functions
–IN: Inverting Input of the Comparator. Voltage
range of this pin can go from V– – 0.3V to V+ + 0.3V.
between power supply pins or between supply pins
and ground.
+IN: Non-Inverting Input of Comparator. This pin has
the same voltage range as –IN.
V– (VSS): Negative Power Supply. It is normally tied to
ground. It can also be tied to a voltage other than
ground as long as the voltage between V+ and V– is
from 1.8V to 5.5V. If it is not connected to ground,
bypass it with a capacitor of 0.1μF as close to the
part as possible.
NC: No Connection.
V+ (VDD): Positive Power Supply. Typically the
voltage is from 1.8V to 5.5V. Split supplies are
possible as long as the voltage between V+ and V–
is between 1.8V and 5.5V. A bypass capacitor of
0.1μF as close to the part as possible should be used
OUT: Comparator Output. The voltage range
extends to within millivolts of each supply rail.
Operation
The LMV331-393 single-supply comparators feature
internal hysteresis, high speed, and low power. Input
signal range extends beyond the negative and
positive power supplies. The output can even extend
all the way to the negative supply. The input stage is
active over different ranges of common mode input
voltage. Rail-to-rail input voltage range and
low-voltage single-supply operation make these
devices ideal for portable equipment.
Applications Information
Inputs
The LMV331-393 comparators use CMOS transistors at the input which prevent phase inversion when the input
pins exceed the supply voltages. Figure 1 shows an input voltage exceeding both supplies with no resulting phase
inversion.
6
Vout Voltage (mV)
Input Voltage
4
2
VDD =5V
Output Voltage
-2
Time (100μs/div)
Figure 1. Comparator Response to Input Voltage
The electrostatic discharge (ESD) protection input structure of two back-to-back diodes and 1kΩ series resistors
are used to limit the differential input voltage applied to the precision input of the comparator by clamping input
voltages that exceed supply voltages, as shown in Figure 2. Large differential voltages exceeding the supply
voltage should be avoided to prevent damage to the input stage.
4
REV1.0
www.3peakic.com
LMV331TP / LMV393TP
1 kΩ
+In
1 kΩ
Core
-In
Chip
Figure 2. Equivalent Input Structure
Internal Hysteresis
Most high-speed comparators oscillate in the linear region because of noise or undesired parasitic feedback. This
tends to occur when the voltage on one input is at or equal to the voltage on the other input. To counter the
parasitic effects and noise, the LMV331-393 implement internal hysteresis.
The hysteresis in a comparator creates two trip points: one for the rising input voltage and one for the falling input
voltage. The difference between the trip points is the hysteresis. When the comparator’s input voltages are equal,
the hysteresis effectively causes one comparator input voltage to move quickly past the other, thus taking the
input out of the region where oscillation occurs. Figure 3. illustrates the case where IN- is fixed and IN+ is varied.
If the inputs were reversed, the figure would look the same, except the output would be inverted.
Vi
Vtr
Vi
Vhyst=Vtr-Vtf
Vtr+Vtf
Vos= 2 -Vin-
Hysteresis
Band
Vin-
Vtf
VDD
Vtr
Vhyst=Vtr-Vtf
Vtr+Vtf
Vos= 2 -Vin-
Hysteresis
Band
Vin-
Vtf
Time
Time
VDD
Non-Inverting Comparator Output
Figure 3. Comparator’s hysteresis and offset
External Hysteresis
Greater flexibility in selecting hysteresis is achieved by using external resistors. Hysteresis reduces output
chattering when one input is slowly moving past the other. It also helps in systems where it is best not to cycle
between high and low states too frequently (e.g., air conditioner thermostatic control). Output chatter also
increases the dynamic supply current.
Non-Inverting Comparator with Hysteresis
A non-inverting comparator with hysteresis requires a two-resistor network, as shown in Figure 4 and a voltage
reference (Vr) at the inverting input.
VPU
VPU
R2
Vi
R1
Vr
VPU
R2
RPU
Vo
Vtr
RPU
R1
Vr
R2
V+=Vr
Vo
Vtf
RPU
R1
Vr
V+=Vr
Vo
Figure 4. Non-Inverting Configuration with Hysteresis
www.3peakic.com
REV1.0
5
LMV331TP / LMV393TP
When Vi is low, the output is also low. For the output to switch from low to high, Vi must rise up to Vtr. When Vi is
high, the output is also high. In order for the comparator to switch back to a low state, Vi must equal Vtf before the
non-inverting input V+ is again equal to Vr.
R2
Vr
Vtr
R1 R 2
Vr (VDD Vtf )
Vtr
R1 R 2
R2
R1
R1 R 2 R PU
Vr
R1 R 2 R PU
Vtf
R 2 R PU
Vhy st
Vtf
R1
R 2 R PU
Vr
VDD
R1
R 2 R PU
VDD
if RPU
