AUA
A060N08
8AG, AU
UB060N
N08AG, AUP060
0N08AG
G,
AUN
N060N08
8AG, AU
UD060N
N08AG
MO
OSFET Silic
con N-Chan
nnel MOS
1. Applicatio
ons
Synchronou
us rectificatio
on in SMPS,
Hard switch
hing and High
h speed circu
uit
DC/DC in te
elecoms and inductrial
2. Features
Low drain-ssource on-ressistance: RD
DS(ON) = 5.6
6mΩ (typ.)
High speed power switcching
Enhanced body
b
diode dv/dt
d
capability
Enhanced avalanche
a
ru
uggedness
Table 1
Key Perfformance Paramete
ers
Parameterr
V
Value
Unit
VDS @ Tj,maxx
8
80
V
RDS(on),max
6
6.0
mΩ
Qg,typ
5
55.7
nC
C
ID,pulse
2
240
A
3. Packagin
ng and Inte
ernal Circuit
Part Nam
me
Package
e
AUA060N
N08AG
AUB060N
N08AG
AUP060N08AG
AUN060N
N08AG
AUD060N
N08AG
TO220F
TO263
TO220
DFN5x6
TO252
TO22
20F
TO263
3
Marking
A
AUA060N08
8AG
AUB060N08AG
AUP060N08AG
A
AUN060N08
8AG
A
AUD060N08
8AG
TO220
TO252
DFN5x6
AUA060N08AG, AUB060N08AG, AUP060N08AG,
AUN060N08AG, AUD060N08AG
1
Maximum ratings
At Tj= 25°C, unless otherwise specified
Table 2
Maximum ratings
Parameter
Symbol
Continuous drain current1)
ID
Pulsed drain current
2)
Values
Min.
Unit
Note / Test Condition
60
A
TC=25°C
240
A
TC=25°C
Typ.
Max.
ID,pulse
Avalanche energy, single pulse
EAS
300
mJ
Gate source voltage (static)
VGS
-20
V
static;
Power dissipation (TO220F)
Ptot
30
W
TC=25°C
Ptot
150
W
TC=25°C
Ptot
74
W
TC=25°C
Storage temperature
Tstg
-55
175
°C
Operating junction temperature
Tj
-55
175
°C
Power dissipation
(TO263&TO220&TO252)
Power dissipation (DFN5x6)
1)
Limited by Tj,max. Maximum Duty Cycle D = 0.50
Pulse width tp limited by Tj,max
3)
Identical low side and high side switch with identical RG
2)
2
Thermal characteristics
Table 3
Thermal characteristics(TO220F)
Parameter
Symbol
Thermal resistance, junction - case
Values
Unit
Min.
Typ.
Max.
RthJC
5
°C/W -
Thermal resistance, junction - ambient RthJA
60
°C/W device on PCB, minimal footprint
Table
Thermal characteristics(TO263&TO220&TO252)
Parameter
Symbol
Values
Unit
Min.
Typ.
Max.
RthJC
1
°C/W -
62
Table
Thermal characteristics(DFN5x6)
Parameter
Symbol
Values
Unit
Min.
Typ.
Max.
RthJC
1.7
°C/W -
50
3
Electrical characteristics
atTj=25°C, unless otherwise specified
Table 4
Static characteristics
Parameter
Symbol
Drain-source breakdown voltage
Values
Unit
V
VGS=0V, ID=10mA
3.4
V
VDS=VGS, ID=250uA
Min.
Typ.
Max.
V(BR)DSS
80
Gate threshold voltage
V(GS)th
2.5
Zero gate voltage drain current
IDSS
Gate-source leakage current
1000
nA
VDS=80V, VGS=0V, Tj=25°C
IGSS
100
nA
VGS=20V, VDS=0V
Drain-source on-state resistance
RDS(on)
5.4
6.0
mΩ
VGS=10V, ID=20A, Tj=25°C
Gate resistance (Intrinsic)
RG
1.2
Ω
f=1MHz, open drain
Unit
Vds=40V,Vgs=0V
f=1MHz
Vds=40V,Vgs=0V
f=1MHz
Vds=40V,Vgs=0V
f=1MHz
VDD=40V,VGS=10V,RG=10Ω
ID=20A
ID=20A
ID=20A
ID=20A
Table 5
Dynamic characteristics
Parameter
Symbol
Input capacitance
Values
Min.
Typ.
Max.
Ciss
3730
pF
Output capacitance
Coss
674
pF
Reverse transfer capacitance
Crss
24.24
pF
Turn-on delay time
td(on)
16.5
ns
Rise time
tr
13.7
ns
Turn-off delay time
td(off)
35.9
ns
Fall time
tf
13.45
ns
Table 6
Gate charge characteristics
Parameter
Symbol
Gate to source charge
Values
Unit
nC
13.3
nC
55.7
nC
VDS=40V,VGS=0 to 10V
ID=20A
ID=20A
ID=20A
Min.
Typ.
Max.
Qgs
15.9
Gate to drain charge
Qgd
Gate charge total
Qg
Table 7
Reverse diode characteristics
Parameter
Symbol
Diode forward voltage
Values
Unit
V
VGS=0V, IF=1A, Tj=25°C
40.9
ns
VR=40V,IF=20A, diF/dt=200A/us
106.8
uC
VR=40V,IF=20A,diF/dt=200A/us
-3.7
A
Min.
Typ.
Max.
VSD
0.7
Reverse recovery time
trr
Reverse recovery charge
Qrr
Peak reverse recovery current
Irrm
4
Package Outlines
Figure1:Outline PG-TO220F
Figure2:Outline PG-TO263
Figure3:Outline PG-TO220
Figure4:OutlinePG-TO252
Figure5:Outline PG-DFN5x6
Revision History
Revision
Date
Subjects (major changes since last revision)
1.0
2021-01-21
Preliminary version
1.1
2021-02-04
Add package for TO263&TO220&DFN5x6&TO252
