VS4518AD
www.VBsemi.com
P-Channel 4 0 V (D-S) MOSFET
FEATURES
PRODUCT SUMMARY
VDS (V)
• TrenchFET® power MOSFET
-40
RDS(on) () at VGS = -10 V
0.017
RDS(on) () at VGS = -4.5 V
0.021
ID (A)
-40
Configuration
• Package with low thermal resistance
• 100 % Rg and UIS tested
Single
TO-252
S
G
G
D
D
S
P-Channel MOSFET
Top View
ABSOLUTE MAXIMUM RATINGS (TC = 25 °C, unless otherwise noted)
PARAMETER
SYMBOL
LIMIT
Drain-Source Voltage
VDS
-40
Gate-Source Voltage
VGS
± 20
Continuous Drain Current
TC = 25 °C a
TC = 125 °C
Continuous Source Current (Diode Conduction) a
Pulsed Drain Current b
Single Pulse Avalanche Current
Single Pulse Avalanche Energy
L = 0.1 mH
ID
TC = 25 °C
-30
-40
IDM
-150
IAS
-40
EAS
80
PD
136
A
mJ
3
TC = 125 °C
Operating Junction and Storage Temperature Range
V
-40
IS
TA = 25 °C
Maximum Power Dissipation b
UNIT
W
45
TJ, Tstg
-55 to +175
°C
SYMBOL
LIMIT
UNIT
RthJA
50
RthJC
1.1
THERMAL RESISTANCE RATINGS
PARAMETER
Junction-to-Ambient
Junction-to-Case (Drain)
PCB Mount c
°C/W
Notes
a. Package limited.
b. Pulse test; pulse width 300 μs, duty cycle 2 %.
c. When mounted on 1" square PCB (FR4 material).
d. Parametric verification ongoing.
服务热线:400-655-8788
1
VS4518AD
www.VBsemi.com
SPECIFICATIONS (TC = 25 °C, unless otherwise noted)
SYMBOL
PARAMETER
TEST CONDITIONS
MIN.
TYP.
MAX.
UNIT
Static
Drain-Source Breakdown Voltage
VDS
VGS = 0 V, ID = -250 μA
-40
VGS(th)
VDS = VGS, ID = -250 μA
-1.5
-2.5
Gate-Source Leakage
IGSS
VDS = 0 V, VGS = ± 20 V
± 100
Zero Gate Voltage Drain Current
IDSS
Gate-Source Threshold Voltage
On-State Drain
Currenta
ID(on)
Drain-Source On-State Resistancea
Forward
Transconductancea
RDS(on)
gfs
VGS = 0 V
VDS = -40 V
-1
VGS = 0 V
VDS = -40 V, TJ = 125 °C
-50
VGS = 0 V
VDS = -40 V, TJ = 175 °C
-150
VGS = -10 V
VDS -5 V
-50
VGS = -10 V
ID = -13 A
0.017
VGS = -10 V
ID = -40 A, TJ = 125 °C
0.024
VGS = -10 V
ID = -40 A, TJ = 175 °C
0.028
VGS = -4.5 V
ID = -11A
0.021
61
1372
272
212
18
30
3.7
5
7.6
11
1.5
3
4.5
10
15
12
18
40
60
16
24
VDS = -15 V, ID = -13 A
V
nA
μA
A
S
Dynamic b
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Charge c
Qg
Gate-Source Charge c
Qgs
Gate-Drain Charge c
Qgd
Gate Resistance
Turn-On Delay Time c
Rise Time c
Turn-Off Delay
Rg
Fall Time c
Source-Drain Diode Ratings and
VGS = -10 V
VDS = -25 V, f = 1 MHz
VDS = -30 V, ID = -50 A
f = 1 MHz
td(on)
tr
Time c
VGS = 0 V
td(off)
VDD = -20 V, RL = 0.4
ID -50 A, VGEN = -10 V, Rg = 1
tf
pF
nC
ns
Characteristics b
Pulsed Current a
ISM
Forward Voltage
VSD
IF = -50 A, VGS = 0 V
-150
A
-1
-1.5
V
Notes
a. Pulse test; pulse width 300 μs, duty cycle 2 %.
b. Guaranteed by design, not subject to production testing.
c. Independent of operating temperature.
Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation
of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum
rating conditions for extended periods may affect device reliability.
2
服务热线:400-655-8788
VS4518AD
www.VBsemi.com
TYPICAL CHARACTERISTICS (TA = 25 °C, unless otherwise noted)
100
100
VGS = 10 V thru 5 V
80
ID - Drain Current (A)
80
60
4V
40
40
25 °C
3V
TC = 125 °C
6
9
12
2
4
6
8
VDS - Drain-to-Source Voltage (V)
VGS - Gate-to-Source Voltage (V)
Output Characteristics
Transfer Characteristics
0.05
2500
0.04
2000
C - Capacitance (pF)
RDS(on) - On-Resistance ()
- 55 °C
VGS = 4.5 V
0.02
Ciss
1500
1000
VGS = 10 V
0.01
10
Coss
500
Crss
0.00
60
80
100
15
30
On-Resistance vs. Drain Current
Capacitance
10
35
40
150
175
2.0
RDS(on) - On-Resistance (Normalized)
ID = 50 A
5
8
VDS = 20 V
6
4
2
40
Qg - Total Gate Charge (nC)
Gate Charge
50
60
VGS = 10 V
ID = 30 A
1.7
1.4
1.1
0.8
0.5
- 50
- 25
50
75
100
125
TJ - Junction Temperature (°C)
On-Resistance vs. Junction Temperature
服务热线:400-655-8788
3
VS4518AD
www.VBsemi.com
100
0.10
10
0.08
IS - Source Current (A)
TJ = 150 °C
TJ = 25 °C
1
0.1
0.01
0.06
0.04
TJ = 150 °C
0.02
TJ = 25 °C
0.001
0.00
0.4
0.6
0.8
1.0
1.2
VSD - Source-to-Drain Voltage (V)
2
4
6
8
Source Drain Diode Forward Voltage
On-Resistance vs. Gate-to Source Voltage
10
120
TC = - 55 °C
100
g fs - Transconductance (S)
0.8
VGS(th) Variance (V)
ID = 250 µA
0.5
ID = 5 mA
0.2
- 0.1
- 0.4
- 50
25 °C
125 °C
80
60
40
50
75
125
100
150
TJ - Temperature (°C)
60
40
I D - Drain Current (A)
Threshold Voltage
80
100
Transconductance
- 40
- 42
ID = 10 mA
- 44
- 46
- 48
- 50
- 50
- 25
50
75
100
125
150
175
Drain Source Breakdown vs. Junction Temperature
服务热线:400-655-8788
4
VS4518AD
www.VBsemi.com
100
IDM Limited
100 µs
Limited by RDS(on)*
ID Limited
10
1 ms
10 ms
100 ms
1 s, 10 s, DC
1
0.1
TC = 25 °C
Single Pulse
0.01
0.01
BVDSS Limited
0.1
1
10
* VGS > minimum VGS at which RDS(on) is s
100
Safe Operating Area
2
1
Normalized Effective Transient
Thermal Impedance
Duty Cycle = 0.5
0.2
0.1
0.1 0.05
0.02
Single Pulse
0.01
10 -4
10 -3
10 -2
Square Wave Pulse Duration (s)
10 -1
1
Normalized Thermal Transient Impedance, Junction-to-Case
服务热线:400-655-8788
5
VS4518AD
www.VBsemi.com
2
Thermal Impedance
1
Duty Cycle = 0.5
0.2
0.1
0.1
0.05
0.02
Single Pulse
0.01
10-4
10-3
10-2
10-1
1
10
100
1000
Normalized Thermal Transient Impedance, Junction-to-Ambient
Note
• The characteristics shown in the two graphs
- Normalized Transient Thermal Impedance Junction-to-Ambient (25 °C)
- Normalized Transient Thermal Impedance Junction-to-Case (25 °C)
are given for general guidelines only to enable the user to get a “ball park” indication of part capabilities. The data are extracted from single
pulse transient thermal impedance characteristics which are developed from empirical measurements. The latter is valid for the part
mounted on printed circuit board - FR4, size 1" x 1" x 0.062", double sided with 2 oz. copper, 100 % on both sides. The part capabilities
can widely vary depending on actual application parameters and operating conditions.
服务热线:400-655-8788
6
VS4518AD
www.VBsemi.com
TO-252AA Case Outline
E
C2
L3
H
D
b2
D1
e1
E1
L
gage plane height (0.5 mm)
e
L5
L4
b
C
A1
INCHES
MILLIMETERS
A
b3
DIM.
MIN.
MAX.
MIN.
MAX.
A
2.18
2.38
0.086
0.094
A1
0.127
0.005
b
0.64
0.88
0.025
0.035
b2
0.76
1.14
0.030
0.045
b3
4.95
5.46
0.195
0.215
0.024
C
0.46
0.61
0.018
C2
0.46
0.89
0.018
0.035
D
5.97
6.22
0.235
0.245
D1
4.10
0.161
E
6.35
6.73
0.250
0.265
E1
4.32
0.170
H
9.40
10.41
0.370
0.410
e
2.28 BSC
e1
0.090 BSC
4.56 BSC
0.180 BSC
L
1.40
1.78
0.055
0.070
L3
0.89
1.27
0.035
0.050
L4
1.02
0.040
L5
1.01
1.52
0.040
0.060
ECN: T13-0592-Rev. A, 02-Sep-13
DWG: 6019
Note
• Dimension L3 is for reference only.
服务热线:400-655-8788
7
VS4518AD
www.VBsemi.com
RECOMMENDED MINIMUM PADS FOR DPAK (TO-252)
0.224
0.243
0.087
(2.202)
0.090
(2.286)
(10.668)
0.420
(6.180)
(5.690)
0.180
0.055
(4.572)
(1.397)
Recommended Minimum Pads
Dimensions in Inches/(mm)
Return to Index
服务热线:400-655-8788
8
VS4518AD
www.VBsemi.com
Disclaimer
All products due to improve reliability, function or design or for other reasons, product specifications and
data are subject to change without notice.
Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their
representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or
incomplete data contained in the table or any other any disclosure of any information related to the
product.(www.VBsemi.com)
Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of
any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi
relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability,
including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties,
including a particular purpose, non-infringement and merchantability guarantee.
Statement on certain types of applications are based on knowledge of the product is often used in a typical
application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the
product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific
product features in the products described in the specification is appropriate for use in a particular application.
Parameter data sheets and technical specifications can be provided may vary depending on the application and
performance over time. All operating parameters, including typical parameters must be made by customer's
technical experts validated for each customer application. Product specifications do not expand or modify Taiwan
VBsemi purchasing terms and conditions, including but not limited to warranty herein.
Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving,
or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal
injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their
own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and
other terms and conditions in writing.
The information provided in this document and the company's products without a license, express or implied,
by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product
names and trademarks referred to herein are trademarks of their respective representatives will be all.
Material Category Policy
Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be
oHS compliant and meets the definition of restrictions under Directive of the European Parliament
2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and
electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com)
Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We
confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive
2011/65 /.
Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as
halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese
VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products
conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
