MDD2N65F/MDD2N65P/MDD2N65D
650V N-Channel Enhancement Mode MOSFET
TO-220F-3L
VDS
650 V
ID(Tc=25℃)
2A
RDS(on),max
5.2Ω@VGS=10V
Qg,typ
10.2nC
2
12
General Features
12
3
3
Ultra low gate charge
Low reverse transfer Capacitance
Fast switching capability
Avalanche energy tested
Improved dv/dt capability, high ruggedness
TO-252
TO-220-3L
1
3
Equivalen t Circuit
Application
High efeciency switch mode power supplies
Electronic lamp ballasts based on half bridge
LED power supplies
Absolute Maximum Ratings (TA=25℃unless otherwise noted)
Parameter
Symbol
Value
Unit
Drain-Source Voltage
VDS
650
V
Gate-Source Voltage
VGS
±30
V
Continuous Drain Current
ID
2
A
Pulsed Drain Current(Note 1)
IDM
8
A
EAS
80
mJ
IS
2
A
Diode pulse current
IS,pulse
8
A
Peak Diode Recovery dv/dt (Note 3)
dv/dt
5
V/ns
27
W
35
W
Avalanche Energy
Single Pulsed (Note 2)
Continuous diode forward current
Power Dissipation TO-220F
PD
Power Dissipation TO-220/TO-252
Junction Temperature
TJ
150
Storage Temperature
Tstg
-55 ~150
Thermal Characteristics
Parameter
Symbol
Thermal resistance, Junction-to-case
Thermal resistance, Junction-to-ambient
Notes:
Value
Unit
TO-220F
TO-220/TO-252
RθJC
4.63
3.57
°C/W
RθJA
100
62
°C/W
1. Pulse width limited by maximum junction temperature.
2. L=10mH, IAS = 4A, Starting Tj= 25°C.
3. ISD = 2A, di/dt≤100A/us, VDD≤BVDS, Starting Tj= 25°C.
1/9
V 1.0
Ta = 25℃ unless otherwise specified
Symbol
Parameter
Condition
Min
Typ
Max
Unit
VGS=0V, ID=250μA
650
V
Forward
VGS=30V, VDS=0V
100
nA
Reverse
VGS=-30V, VDS=0V
-100
nA
V(BR)DSS
Drain-Source Breakdown Voltage
IGSS
Gate-Source Leakage Current
IDSS
Drain-Source Leakage Current
VDS=650V, VGS=0V
1
uA
VGS(TH)
Gate Threshold Voltage
VDS=VGS, ID=250μA
2.0
4.0
V
RDS(ON)
Drain-Source On-State Resistance
VGS=10V, ID=1A
4.2
5.2
Ω
Min
Typ
Max
Unit
338
pF
36
pF
3.4
pF
10.2
nC
2.6
nC
4.7
nC
Min
Typ
Max
Unit
17.2
ns
35.6
ns
33.9
ns
29
ns
Min
Typ
Max
Unit
Dynamic Electrical Characteristics
Symbol
Parameter
Ciss
Input Capacitance
Coss
Output Capacitance
Condition
VDS=25V
VGS=0V
Crss
Reverse Transfer Capacitance
Qg
Total Gate Charge
Qgs
Gate Source Charge
Qgd
Gate Drain Charge
f=1MHz
VDS=520V,
VGS=10V,
ID=2A
(Note1,2)
Switching Characteristics
Symbol
Parameter
td(on)
Turn on Delay Time
tr
Turn on Rise Time
td(off)
Turn Off Delay Time
tf
Turn Off Fall Time
Condition
VDS=325V,
ID=2A,
RG=10Ω (Note1,2)
Source Drain Diode Characteristics
Symbol
Parameter
Condition
ISD
Source drain current(Body Diode)
2
A
ISM
Pulsed Current
8
A
VSD
Drain-Source Diode Forward Voltage
IS=2A, VGS=0V
1.5
V
trr
Body Diode Reverse Recovery Time
VR=400
221.8
ns
Qrr
Body Diode Reverse Recovery Charge
0.75
uC
IF=2A,
-diF/dt =100A/µs
Notes:
1.Pulse test ; Pulse width≤300us, duty cycle≤2%.
2.Essentially independent of operating temperature.
2/9
V 1.0
Electrical Characteristics Diagrams
Figure 1. Typical Output Characteristics
Figure 2. Transfer Characteristics
VGS=10V
Tc = 25°C
VGS=9V
VGS=8V
VGS=7V
VGS=5.5V
VGS=6V
Tc = 150°C
VGS=4.5V
VDS ,Drain−source voltage (V)
VGS ,Gate−source voltage (V)
Figure 3. On-Resistance Variation vs. Drain Current
Figure 4. Threshold Voltage vs. Temperature
VGS = 10 V
Tc = 25°C
Pulse test
IDS=0.25 mA
Pulse test
ID ,Drain current (A)
Tj ,Junction temperature (°C)
Figure 5. Breakdown Voltage vs. Temperature
Figure 6. On-Resistance vs. Temperature
VGS=10 V
IDS=2 A
Pulse test
VGS=0 V
IDS=0.25 mA
Pulse test
3/9
V 1.0
Figure 7. Capacitance Characteristics
Figure 8. Gate Charge Characterist
Ciss
Notes:f = 1 MHz,VGS=0 V
Ciss = Cgs + Cgd (Cds = shorted)
Coss = Cds + Cgd
Crss = Cgd
VDS=520
Coss
ID = 2 A
Crss
VDS ,Drain-Source Voltage (V)
QG ,Total Gate Charge (nC)
Figure 9. Maximum Safe Operating Area
Figure 10. Maximum Safe Operating Area
TO-220F
TO-220/ TO-252
100us
100us
10ms
Limited by RDS(on)
1ms
10ms
1ms
DC
Limited by RDS(on)
Notes:
T = 25°C
c
Notes:
T = 25°C
j
T = 150°C
DC
c
T = 150°C
j
Single Pulse
Single Pulse
Figure 11. Power Dissipation vs. Temperature
Figure 12. Power Dissipation vs. Temperature
TO-220F
TO-220/ TO-252
Tc ,Case temperature (°C)
4/9
V 1.0
Figure 13. Continuous Drain Current vs. Temperature
Figure 14. Body Diode Transfer Characteristics
Tc = 150°
C
Tc = 25°C
VSD ,Source-Drain Voltage (V)
Figure 15 Transient Thermal Impendance,Junction to Case, TO-220F
P
DM
In descending order
D= 0.5, 0.2, 0.1, 0.05, 0.02, 0.01, single pulse
t
Duty = t/T
T
Z (t)=4.63°C/W Max.
θJC
t ,Pulse Width (s)
Figure 16. Transient Thermal Impendance,Junction to Case, TO-220/ TO-252
In descending order
P
DM
t
Duty = t/T
Z (t)=3.75°C/W Max.T
θJC
t ,Pulse Width (s)
5/9
V
V 1.0
1.0
RL
VDS
RG
VGS
VDD
D.U.T.
10V
Pulse Width≤ 1μs
Duty Factor≤0.1%
Switching Test Circuit
12V
0.2µF
50kΩ
0.3µF
Switching Waveforms
Same
Type as
D.U.T.
VDS
VGS
DUT
3mA
Gate Charge Test Circuit
Gate Charge Waveform
Unclamped Inductive Switching Test Circuit
Unclamped Inductive Switching Waveforms
The curve above is for reference only.
6/9
V 1.0
Mechanical Dimensions for TO-220
SYMBOL
mm
MIN
NOM
MAX
A
4.37
4.57
4.70
A1
A2
b
b2
c
D
D1
D2
E
E3
e
e1
H1
L
L1
ΦP
Q
1.25
2.20
0.70
1.17
0.45
15.10
8.80
5.50
9.70
7.00
1.30
2.40
0.80
1.27
0.50
15.60
9.10
10.00
2.54 BSC
5.08 BSC
6.50
13.50
3.10
3.60
2.80
1.40
2.60
0.95
1.47
0.60
16.10
9.40
10.30
6.25
12.75
3.40
2.60
7/9
6.85
13.80
3.40
3.80
3.00
V 1.0
Mechanical Dimensions for TO-220F
SYMBOL
E
A
A1
A4
c
D
H1
e
L
L1
ФP
ФP3
F3
G3
b1
b2
MIN
9.96
4.50
2.34
2.56
0.40
15.57
12.68
2.88
3.03
3.15
3.15
1.25
1.18
0.70
8/9
mm
NOM
10.16
4.70
2.54
2.76
0.50
15.87
6.70REF
2.54BSC
12.98
3.03
3.18
3.45
3.30
1.35
1.28
0.80
MAX
10.36
4.90
2.74
2.96
0.65
16.17
13.28
3.18
3.38
3.65
3.45
1.55
1.43
0.95
V 1.0
Mechanical Dimensions for TO-252
SYMBOL
A
A1
A2
b
b3
c
D
D1
E
E1
e
H
L2
L3
L4
θ
MIN
2.20
0.00
0.97
0.68
5.20
0.43
5.98
6.40
4.63
9.40
0.88
0.50
0°
mm
NOM
2.30
1.07
0.78
5.33
0.53
6.10
5.30REF
6.60
2.286BSC
10.10
0.51BSC
MAX
2.38
0.20
1.17
0.90
5.46
0.61
6.22
6.73
10.50
1.28
1.00
8°
Package Marking and Ordering Information
Part Number
Marking
Package
Units/Tube
MDD2N65F
2N65F
TO-220F
50
MDD2N65P
2N65P
TO-220-3L
50
MDD2N65D
2N65D
TO-252
9/9
Units/Reel
2500
V 1.0
