MDD80N03D
30V N-Channel Enhancement Mode MOSFET
V(BR)DSS
RDS(on)Max
6mΩ@10V
30V
9mΩ@4.5V
ID Max
TO-252
80A
2
Features
● Trench Power LV MOSFET technology
● Excellent package for heat dissipation
● High density cell design for low RDS(ON)
● Halogen Free
3
Application
● High current load applications
● Load switching
● Hard switched and high frequency circuits
● Uninterruptible power supply
Marking
Equivalen t Circuit
XXX: Date Code
MDD
1. Gate
2. Drain
3. Source
1
80N03D
XXX
Absolute Maximum Ratings (TA=25℃unless otherwise noted)
Parameter
Symbol
Value
Unit
Drain-Source Voltage
VDS
30
V
Gate-Source Voltage
VGS
±20
V
Continuous Drain Current
ID
80
A
Pulsed Drain Current (Note 1)
IDM
190
A
EAS
132
mJ
PD
44
W
RθJC
2.8
℃/ W
Junction Temperature
TJ
150
Storage Temperature
Tstg
-50 ~+150
Avalanche Energy
Single Pulsed (Note 2)
Power Dissipation
Thermal Resistance Junction-to-Case(Note 3)
Notes: 1.Pulse Test: Pulse Width≤300us,Duty cycle ≤2%.
2.Tj=25℃, VDD=25V, VG=10V, L=0.5mH, IAS=23A
3.RθJA is the sum of the junction-to-case and case-to-ambient thermal resistance, where the case thermal reference is
defined as the solder mounting surface of the drain pins. RθJC is guaranteed by design, while RθJA is determined by the
board design. The maximum rating presented here is based on mounting on a 1 in 2 pad of 2oz copper.
1/6
V 1.0
MDD80N03D
Ta = 25℃ unless otherwise specified
Symbol
Parameter
Condition
Min
Typ
Max
Unit
V(BR)DSS
Drain-Source Breakdown Voltage
VGS=0V, ID=250μA
30
V
IDSS
Drain-Source Leakage Current
VDS=30V, VGS=0V
1
uA
IGSS
Gate-Source Leakage Current
VGS=±20V, VDS=0V
±100
nA
VGS(TH)
Gate Threshold Voltage
VDS=VGS, ID=250μA
1.0
1.5
2.5
V
RDS(ON)
Drain-Source On-State Resistance
VGS=10V, ID=20A
3.8
6
mΩ
VGS=4.5V, ID=15A
4.8
9
mΩ
Min
Typ
Max
Unit
2504
pF
323
pF
283
pF
54
nC
8.5
nC
10.2
nC
Min
Typ
Max
Unit
Dynamic Electrical Characteristics
Symbol
Parameter
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
Qg
Total Gate Charge
Condition
VDS=15V
VGS=0V
f=1MHz
VDS=15V,
Qgs
Gate Source Charge
Qgd
Gate Drain Charge
VGS=10V,
ID=20A
(Note1,2)
Switching Characteristics
Symbol
Parameter
Condition
td(on)
Turn on Delay Time
VDS=20V,
11.4
ns
tr
Turn on Rise Time
VGS =10V,
20.4
ns
td(off)
Turn Off Delay Time
41
ns
tf
Turn Off Fall Time
25
ns
Min
Typ
Max
Unit
ID=2A,
RG=3Ω
(Note1,2)
Source Drain Diode Characteristics
Symbol
Parameter
Condition
ISD
Source drain current(Body Diode)
80
A
ISM
Pulsed Current
190
A
VSD
Drain-Source Diode Forward Voltage
IS=20A, VGS=0V
0.8
1.2
V
trr
Body Diode Reverse Recovery Time
15.1
ns
Qrr
Body Diode Reverse Recovery Charge
IF=20A, VGS=0V,
dI/dt=100A/µs
6.5
nC
Notes: 1.Pulse test ; Pulse width 300us, duty cycle 2%.
2.Essentially independent of operating temperature.
2/6
V 1.0
MDD80N03D
■ Typical Performance Characteristics
Figure 1. Output Characteristics
Figure 2. Transfer Characteristics
Figure 3. On-Resistance vs. Drain Current
and Gate Voltage
Figure 4. On-Resistance vs. Junction Temperature
Figure 5. Capacitance Characteristics
Figure 6. Gate Charge
3/6
V 1.0
MDD80N03D
Figure 7. Safe Operation Area
Figure 8. Maximum Continuous Drain Current
vs Case Temperature
Figure 9. Normalized Maximum Transient Thermal Impedance
4/6
V 1.0
MDD80N03D
Resistive Switching Test Circuit & Waveforms
Diode Recovery Test Circuit & Waveforms
Gate Charge Test Circuit & Waveform
Unclamped Inductive Switching (UIS) Test Circuit & Waveforms
5/6
V 1.0
MDD80N03D
Outlitne Drawing
TO-252 Package Outline Dimensions
Suggested Pad Layout
Note:
1.Controlling dimension:in/millimeters.
2.General tolerance: ±0.05mm.
3.The pad layout is for reference purposes only.
6/6
V 1.0
很抱歉,暂时无法提供与“MDD80N03D”相匹配的价格&库存,您可以联系我们找货
