15A10
Reverse Voltage - 1000 Volts
Forward Current - 15.0 Ampere
GENERAL PURPOSE SILICON RECTIFIER
Features
R-6
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
Construction utilizes void-free molded plastic technique
Low reverse leakage
1.0 (25.4)
MIN.
0.360 (9.1)
0.340(8.6)
High forward surge current capability
High temperature soldering guaranteed:
DIA.
250°C/10 seconds,0.375”(9.5mm) lead length, 5 lbs. (2.3kg) tension
0.360(9.1)
0.340(8.6)
Mechanical Data
1.0 (25.4)
MIN.
Case : JEDEC R-6 Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.072 ounce, 2.05 grams
0.052 (1.3)
0.048 (1.2)
DIA.
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
MDD
15A10
UNITS
VRRM
VRMS
VDC
1000
700
1000
V
V
V
I(AV)
15.0
A
IFSM
500
A
VF
1.0
5.0
200
V
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
0.375”(9.5mm) lead length at TA=75°C
Peak forward surge current
8.3ms single half sine-wave superimposed
on rated load (JEDEC Method)
Maximum instantaneous forward voltage at 15.0A
Maximum DC reverse current
TA=25°C
at rated DC blocking voltage
TA=100°C
Typical junction capacitance (NOTE 1)
Typical thermal resistance (NOTE 2)
Operating junction and storage temperature range
IR
CJ
RθJA
TJ,TSTG
150
15.0
-65 to +175
μA
pF
°C/W
°C
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.Thermal Resistance Junction to Ambient.
http://www.microdiode.com
Rev:2024A1
Page :1
15A10
Ratings And Characteristic Curves
FIG. 2 -- TYPICAL JUNCTION CAPACITANCE
2000
Pulse Width = 300μS
200
1000
Tj = 25 ℃
CAPACITANCE. PF
100
AMPERES
INSTANTANEOUS FORWARD CURRENT /
FIG. 1 -- TYPICAL FORWARD CHARACTERISTIC
10
100.0
1
10.0
0.4
0.6
0.8
1.0
1.2
1.4
1.6
1.8
0.1
REVERSE VOLTAGE / VOLTS
INSTANTANEOUS FORWARD VOLTAGE / VOLTS
Single Phase Half Wave 60HZ
Resistive or Inductive Load
2.0
1
50
75
100
125
150
AMBIENT TEMPERATURE / ℃
175
200
FIG. 4 -- PEAK FORWARD SURGE CURRENT
PEAK FORWARD SURGE CURRENT AMPERES
CURRENT AMPERES
AVERAGE FORWARD RECTIFIED
FIG. 3 -- FORWARD CURRENT DERATING CURVE
15
100
10
1.0
500
Tj = 125 ℃
120
8.3 ms Single
90
Half Sing -Wave
60
30
1.0
10
100
NUMBER OF CYCLES AT 60HZ
The curve above is for reference only.
Rev:2024A1
Page :2
很抱歉,暂时无法提供与“15A10”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.95667
- 50+0.77264
- 150+0.68062
- 500+0.54616
- 2500+0.49097
- 5000+0.46343
- 国内价格
- 10+1.72530
- 100+1.02920
- 200+0.72050
- 500+0.51460
- 1000+0.48890
- 5000+0.45290
