1A1 THRU 1A7
Reverse Voltage - 50 to 1000 Volts
Forward Current - 1.0 Ampere
GENERAL PURPOSE SILICON RECTIFIER
Features
R-1
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
1.0 (25.4)
MIN.
Construction utilizes void-free molded plastic technique
Low reverse leakage
0.102 (2.6)
0.091 (2.3)
DIA.
High forward surge current capability
High temperature soldering guaranteed:
250°C/10 seconds,0.375”(9.5mm) lead length, 5 lbs. (2.3kg) tension
0.140(3.50)
0.114(2.90)
Mechanical Data
1.0 (25.4)
MIN.
Case : JEDEC R-1 Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.0023 ounce, 0.07 grams
0.025 (0.65)
0.021 (0.55)
DIA.
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
VRRM
VRMS
VDC
1A1 1A2 1A3 1A4 1A5 1A6 1A7
MDD MDD MDD MDD MDD MDD MDD
50
100
200
400
600
800 1000
35
70
140
280
420
560
700
50
100
200
400
600
800 1000
I(AV)
1.0
A
IFSM
25.0
A
VF
1.1
IR
5.0
50.0
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
0.375”(9.5mm) lead length at TA=25°C
Peak forward surge current
8.3ms single half sine-wave superimposed
on rated load (JEDEC Method)
Maximum instantaneous forward voltage at 1.0A
Maximum DC reverse current
TA=25°C
at rated DC blocking voltage
TA=100°C
Typical junction capacitance (NOTE 1)
Typical thermal resistance (NOTE 2)
Operating junction and storage temperature range
CJ
RθJA
TJ,TSTG
15.0
50.0
-50 to +150
UNITS
V
V
V
V
μ
A
pF
°C/W
°C
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.Thermal resistance from junction to ambient at 0.375”(9.5mm)lead length,P.C.B. mounted
http://www.microdiode.com
Rev:2024A1
Page :1
1A1 THRU 1A7
FIG. 1- FORWARD CURRENT DERATING CURVE
1.0
0.8
0.6
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
0.4
0.2
50
75
100
125
150
PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
Ratings And Characteristic Curves
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
30
25
10
175
5.0
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
TA=75 C
1
10
AMBIENT TEMPERATURE, C
NUMBER OF CYCLES AT 60 Hz
1
TJ=25 C
PULSE WIDTH=300 µs
1%DUTY CYCLE
0.01
0.6
0.8
1.0
1.2
1.4
1.5
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
INSTANTANEOUS REVERSE CURRENT,
MICROAMPERES
INSTANTANEOUS FORWARD
CURRENT,AMPERES
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
0.1
1,000
100
TJ=150 C
10
TJ=100 C
1
0.1
TJ=25 C
0.01
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
TJ=25 C
10
TRANSIENT THERMAL IMPEDANCE,
C/W
FIG. 5-TYPICAL JUNCTION CAPACITANCE
JUNCTION CAPACITANCE, pF
60
80
100
PERCENT OF PEAK REVERSE VOLTAGE,%
200
100
100
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
100
10
1
0.1
0.01
0.1
1
10
100
1
0.1
1.0
10
REVERSE VOLTAGE,VOLTS
100
t,PULSE DURATION,sec.
The curve above is for reference only.
Rev:2024A1
Page :2
很抱歉,暂时无法提供与“1A7”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.16773
- 100+0.13724
- 300+0.12027
- 1000+0.11000
- 5000+0.10120
- 10000+0.09649
