78L10
SOT-89 Plastic-Encapsulate Voltage Regulators
78L10
SOT-89-3L
Three-terminal positive voltage regulator
FEATURES
z
z
z
1. OUT
Maximum output current
IOM: 0.1A
Output voltage
V O: 10V
Continuous total dissipation
PD: 0.6 W (Ta= 25 ℃ )
2. GND
3. IN
ABSOLUTE MAXIMUM RATINGS (Operating temperature range applies unless otherwise specified)
Parameter
Symbol
Value
Unit
Vi
30
V
Input Voltage
Thermal Resistance from Junction to Ambient
RθJA
166.7
℃/W
Operating Junction Temperature Range
TOPR
-40~+125
Storage Temperature Range
TSTG
-65 ~+150
ELECTRICAL CHARACTERISTICS AT SPECIFIED VIRTUAL JUNCTION TEMPERATURE (Vi=16V,Io=40mA,Ci=0.33uF,,Co=0.1uF, unless otherwise specified )
Parameter
Symbol
Test conditions
25℃
Output voltage
12.5V≤V l≤25V, Io=1mA-40mA
Vo
Io=1mA-70mA
Load Regulation
△Vo
Line regulation
△Vo
Quiescent Current
Quiescent Current Change
0-125℃
Min
Typ
Max
Unit
9.60
10
10.40
V
9.30
10
10.70
V
9.30
10
10.70
V
Io=1mA-100mA
25℃
17
90
mV
Io=1mA-40mA
25℃
45
mV
12.5V≤V l≤25V
25℃
9
100
210
mV
13V≤V l≤25V
25℃
90
160
mV
25℃
6.5
mA
1.5
mA
0.1
mA
Iq
△Iq
13V≤V l≤25V
0-125℃
△Iq
1mA≤I O≤40mA
0-125℃
58
Output Noise Voltage
VN
10Hz≤f≤100KHz
25℃
Ripple Rejection
RR
13V≤V l≤24V,f=120Hz
25℃
43
dB
Dropout Voltage
Vd
25℃
1.7
V
* Pulse test.
TYPICAL APPLICATION
Vi
3
1
μV/Vo
Vo
78L10
Ci
0.33μF
2
C0
0.1μF
Note: Bypass capacitors are recommended for optimum stability and transient response and should be located as close as
http://www.microdiode.com
Rev:2024A1
Page :1
78L10
Typical Characteristics
Rev:2024A1
Page :2
78L10
Outlitne Drawing
SOT-89-3L Package Outline Dimensions
Symbol
A
b
b1
c
D
D1
E
E1
e
e1
L
Dimensions In Millimeters
Max
Min
1.400
1.600
0.320
0.520
0.400
0.580
0.350
0.440
4.400
4.600
1.550 REF.
2.300
2.600
3.940
4.250
1.500 TYP.
3.000 TYP.
0.900
1.200
Dimensions In Inches
Min
Max
0.055
0.063
0.013
0.020
0.016
0.023
0.014
0.017
0.173
0.181
0.061 REF.
0.091
0.102
0.155
0.167
0.060 TYP.
0.118 TYP.
0.035
0.047
SOT-89-3L Suggested Pad Layout
Note:
1.Controlling dimension:in/millimeters.
2.General tolerance: ±0.05mm.
3.The pad layout is for reference purposes only.
PACKAGE SPECIFICATIONS
Package Reel Size
SOT-89-3L
Reel DIA.
(mm)
Q'TY/Reel
(pcs)
Box Size
(mm)
QTY/Box
(pcs)
Carton Size
(mm)
330
1000
203×203×195
40000
438×438×220
7'
Rev:2024A1
G.W.(Kg)
180000
Page :3
很抱歉,暂时无法提供与“78L10”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.56330
- 10+0.41660
- 100+0.35720
- 1000+0.29760
