AB24S
AB24S
    MDD(辰达半导体)
    ABS
AB24S 数据手册
AB24S THRU AB220S Voltage Range - 40 to 200 V olts Current - 2.0 Ampere SINGLE PHASE GLASS PASSIVATED BRIDGE RECTIFIERS Features ABS  Ideal for printed circuit board  Reliable low cost construction utilizing molded plastic technique  High temperature soldering guaranteed: 260°/10 seconds at 5 lbs., (2.3kg) tension  Small size, simple installation  High surge current capability Mechanical Data (2) - Case : JEDEC ABS Molded plastic body Terminals : Solder plated, solderable per MIL-STD-750,Method 2026 Polarity : Polarity symbol marking on body Mounting Position : Any ~ (3) (1) + ~ (4) Dimensions in inches and (millimeters) Maximum Ratings And Electrical Characteristics Ratings at 25°C ambient temperature unlss otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. Parameter SYMBOLS Marking Code Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) Maximum instantaneous forward voltage drop per leg at 2A Maximum DC reverse current TA=25°C at rated DC blocking voltage TA=100°C Typical thermal resistance Typical junction capacitance Operating temperature range storage temperature range VRRM VRMS VDC IF(AV) MDD MDD MDD MDD MDD AB24S AB26S AB28S AB210S AB220S 40 28 40 60 42 60 80 56 80 2.0 100 70 100 200 140 200 IFSM VF 50 0.55 0.5 10 IR 220 TJ TSTG 80 -55 to +125 -55 to +150 V V V A 40 A 0.85 V 0.3 5 70 RθJA Cj 0.70 UNITS mA mA °C/W pF °C °C NOTE:1.Measured at 1MHz and applied reverse voltage of 4 V D.C. 2.Mounted on glass epoxy P C board with 4 X (5X5mm) copper pad. http://www.microdiode.com Rev:2024A2 Page :1 AB24S THRU AB220S Voltage Range - 40 to 200 V olts Current - 2.0 Ampere Ratings And Characteristic Curves Fig.2 Typical Reverse Characteristics Average Forward Current (A) 3.0 2.5 2.0 1.5 1.0 0.5 0.0 25 75 50 100 125 150 Instaneous Reverse Current ( μA) Fig.1 Forward Current Derating Curve 10 4 T J =75°C 10 2 AB24S/AB26S AB28S-AB220S 10 1 T J =25°C 10 0 0 Case Temperature (°C) 40 20 60 80 100 Percent of Rated Peak Reverse Voltage(%) Fig.4 Typical Junction Capacitance Fig.3 Typical Forward Characteristic 500 20 Junction Capacitance (pF) Instaneous Forward Current (A) T J =100°C 10 3 10 1.0 AB24S AB26S AB28S/AB220S 0.1 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 1.8 T J =25°C 200 100 50 AB24S 20 AB26S-AB220S 10 0.1 1 10 100 Reverse Voltage (V) Instaneous Forward Voltage (V) Peak Forward Surge Current (A) Fig.5 Maximum Non-Repetitive Peak Forward Surge Current 60 8.3 ms Single Half Sine Wave (JEDEC Method) 50 40 30 20 AB24S-AB26S 10 AB28S-AB220S 00 1 10 100 Number of Cycles at 60Hz The curve above is for reference only. http://www.microdiode.com Rev:2024A2 Page :2 AB24S THRU AB220S Voltage Range - 40 to 200 V olts Current - 2.0 Ampere Suggested Pad Layout Q1 P1 Dim Min P1 5.72 P2 4.00 Q1 1.00 Q2 0.90 Q2 P2 Dimensions in millimeters http://www.microdiode.com Rev:2024A2 Page :3
AB24S 价格&库存
很抱歉,暂时无法提供与“AB24S”相匹配的价格&库存,您可以联系我们找货
AB24S
    • 10+1.75940
    • 300+1.04950
    • 1000+0.73460
    • 5000+0.52470
    • 10000+0.49850
    • 50000+0.46170
    AB24S
    • 5+0.93712
    • 50+0.75104
    • 150+0.65805
    • 500+0.58828
    • 2500+0.48341
    • 5000+0.45544
    库存:22343
