BAS16
SOT-23 Plastic-Encapsulate Diodes
BAS16
SWITCHING DIODE
SOT-23
FEATURES
z
z
z
Fast Switching Speed
For General Purpose Switching Applications
High Conductance
Marking:
1
A6
3
2
A6
Maximum Ratings @Ta=25℃
Parameter
Symbol
Limit
Unit
Non-Repetitive Peak Reverse Voltage
VRM
100
V
Peak Repetitive Peak Reverse Voltage
VRRM
Working Peak Reverse Voltage
VRWM
75
V
DC Blocking Voltage
VR
RMS Reverse Voltage
VR(RMS)
53
V
Forward Continuous Current
IFM
300
mA
Average Rectified Output Current
IO
150
mA
Non-Repetitive Peak Forward Surge Current @t=8.3ms
IFSM
2.0
A
Power Dissipation
Pd
225
mW
RθJA
556
℃/W
TJ,TSTG
-55~+150
Thermal Resistance Junction to Ambient
Operation Junction and Storage Temperature Range
Electrical Characteristics @Ta=25℃
Parameter
Reverse breakdown voltage
Reverse voltage leakage current
Symbol
V(BR)
Test conditions
IR= 100µA
Forward voltage
VF
Diode capacitance
CD
VR=0, f=1MHz
Reveres recovery time
trr
Max
75
VR 75V
IR
IF=1mA
IF=10mA
IF=50mA
IF=150mA
http://www.microdiode.com
Min
IF=IR=10mA,Irr=0.1×IR,
RL=100Ω
Rev:2024A1
Unit
V
1
µA
0.715
0.855
1
1.25
V
2
pF
6
ns
Page :1
BAS16
Typical Characteristics
Forward
Reverse
Characteristics
Characteristics
1000
300
100
(nA)
REVERSE CURRENT IR
FORWARD CURRENT
10
Ta
=2
5℃
Ta
=1
00
30
IF
(mA)
300
3
1
Ta=100℃
100
30
10
Ta=25℃
3
0.3
0.1
0.0
0.4
0.8
FORWARD VOLTAGE
1.2
VF
1
1.6
(V)
REVERSE VOLTAGE
60
VR
80
(V)
Power Derating Curve
Capacitance Characteristics
1.4
300
Ta=25℃
f=1MHz
(mW)
PD
1.3
POWER DISSIPATION
CAPACITANCE BETWEEN TERMINALS
CT (pF)
250
1.2
1.1
200
150
100
50
1.0
10
REVERSE VOLTAGE
15
VR
(V)
50
75
AMBIENT TEMPERATURE
Rev:2024A1
100
Ta
125
150
Page :2
BAS16
Outlitne Drawing
SOT-23 Package Outline Dimensions
e
Suggested Pad Layout
0.037
0.95
0.037
0.95
L
L1
E
E1
Symbol
A
A1
b
c
D
E
E1
e
L
L1
θ
Dimensions In Millimeters
Min
Typ
Max
1.00
1.40
0.10
0.35
0.50
0.10
0.20
2.70
2.90
3.10
1.20
1.60
2.4
2.80
1.90
0.10
0.30
0.4
0°
10°
Note:
1. Controlling dimension:in/millimeters.
2. General tolerance: ±0.05mm.
3. The pad layout is for reference purposes only.
0.079
2.0
0.035
0.9
0.031
0.8
inches
mm
Rev:2024A1
Page :3
BAS16
SOT-23 Tape and Reel
Packaging Description:
SOT-23 parts are shipped in tape. The carrier
tape is made from a dissipative (carbon filled)
polycarbonate resin. The cover tape is a multilayer
film (Heat Activated Adhesive in nature) primarily
composed of polyester film,adhesive laye,sealant,
and anti-static sprayed agent.These reeled parts In
standard option are shipped with 3,000 units per 7"
or 17.8cm diameter reel. The reels are clear in color
and is made of polystyrene plastic (anti-static
coated).
3000 pcs
7 Inch
45,000 pcs
203×203×195
180,000 pcs
438×438×220
Rev:2024A1
Page :4
很抱歉,暂时无法提供与“BAS16”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.11610
- 100+0.09170
- 300+0.07809
- 3000+0.06761
- 6000+0.06059
- 9000+0.05670
- 国内价格
- 20+0.10642
- 300+0.07158
- 1200+0.07051
- 3000+0.06197
